Skip to content
View in the app
Armbian Community Forums
Nanopi Neo Air and WiringNP
Featured Replies
All, I downloaded and built WiringNP according to the FriendlyARM instructions. Running 'gpio read all' gives me an error saying
piBoardRev: Unable to determine board revision from /proc/cpuinfo
for the rest the Neo Air Armbian runs fine.
any ideas what's wrong?
  • Author
I believe it has to do with the Armbian Kernel where there may be no model name specified? Like H3 or something? The file /proc/cpuinfo, which is a virtual file and I believe its contents are determined by what is in the kernel, doesn't give any model name and gpio is looking for a model name.
So gpio readall fails:
$ gpio -v readall
gives:
gpio version: 2.20
Copyright (c) 2012-2014 Gordon Henderson
This is free software with ABSOLUTELY NO WARRANTY.
For details type: gpio -warranty
Your NanoPi has an unknown model type. Please report this to
    support@friendlyarm.com
with a copy of your /proc/cpuinfo if possible
  • Author
Where should I start in the code? Any suggestions on which file to look in?
I started in wiringPi.c and I see that I probably have to tweak the function getBoardType().
But where can I find that function?
your help is appreciated.
It is opening /proc/cpuinfo there : https://github.com/WiringPi/WiringPi/blob/master/wiringPi/wiringPi.c#L698
Then it is checking if it is an Raspberry there : https://github.com/WiringPi/WiringPi/blob/master/wiringPi/wiringPi.c#L723
You need to tweak that port, either by skipping it or provide check for H3 SoC.
Anyway, maybe someone already done that by forking this original WiringPi to make it compatible with NanoPiNeoAir ...
I had the same issue with wiringNP on nanoPi NEO. The issue was resolved by adding a line to the file "boardtype_friendlyelec.c" in the array "BoardHardwareInfo gAllBoardHardwareInfo[]"
The line added is:
{"sun8i", 0, NanoPi_NEO, "NanoPi-NEO-Armbian", "-1(-1)"},
The critical parameter is the -1(-1), which is the board type reported by the kernel for this board.
I have not carried our thorough testing, but the gpio readall reports properly and I am able to toggle outputs and read inputs correctly using the gpio command.
There is 2 Repository.
https://github.com/friendlyarm/WiringNP
https://github.com/wertyzp/WiringNP
friendlyarm's WiringNP have a mapping bug.
gpio of pin#35 and #36 won't work.
static int pinToGpio_m1 [64] ={
    0, 6, // 0, 1
    2, 3, // 2, 3
    200, 201, // 4  5
    1, 203, // 6, 7
    12, 11, // 8, 9
    67, 17, //10,11
    64, 65, //12,13
    66, 198, //14,15
    199, -1, //16,17
    -1, -1, //18,19
    -1, 20, //20,21
    21, 8, //22,23
//    13, 9, //24,25 /nopnop2002
    16, 9, //24,25
//    7, 16, //26,27 /nopnop2002
    7, 13, //26,27
    15, 14, //28,29
    19, 18, //30,31
  • Author
The line added is:
I will try this on the Neo Air
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
