Skip to content
View in the app
Armbian Community Forums
ARM64 Armbian Collabora & Nextcloud -> nginx/caddy proxy for Local Domains on NanoPi R4S
Featured Replies
Hi Everybody,
I'm trying to set up Nextcloud with Collabora Office on NanoPi R4S running Armbian, but I'm having trouble configuring the reverse proxy (nginx/Caddy) for HTTPS with local domains.
Current Setup:
    Running via docker-compose.yml (shown below)
    Without HTTPS, everything works: Collabora can open documents in Nextcloud's web UI
    With HTTPS enabled, Collabora integration breaks
    Added to /etc/hosts:
    127.0.0.1 nextcloud.lan collabora.nextcloud.lan
What I Need:
    HTTPS configuration for both services
    Reverse proxy to local domains:
        Nextcloud: https://nextcloud.lan
        Collabora: https://collabora.nextcloud.lan
My docker-compose.yml (HTTP-only version):
networks:
  network:
    driver: bridge
volumes:
  mariadb_config:
  mariadb_data:
  nextcloud_config:
  nextcloud_data:
services:
  collabora:
    image: collabora/code
    restart: unless-stopped
    container_name: collabora
    hostname: collabora
    domainname: collabora.nextcloud.lan
    networks:
      - network
    ports:
      - "9980:9980"
    cap_add:
      - MKNOD
  nextcloud_db:
    image: linuxserver/mariadb
    container_name: nextcloud_db
    hostname: nextcloud_db
    networks:
      - network
    volumes:
      - mariadb_config:/config
      - mariadb_data:/data
    environment:
      - PUID=1000
      - PGID=1000
      - TZ=UTC
      - MYSQL_ROOT_PASSWORD=nextcloud
      - MYSQL_DATABASE=nextcloud_db
      - MYSQL_USER=nextcloud
      - MYSQL_PASSWORD=nextcloud
  nextcloud:
    image: linuxserver/nextcloud
    depends_on:
      - nextcloud_db
      - collabora
    hostname: nextcloud
    domainname: nextcloud.lan
    networks:
      - network
    ports:
      - "8080:80"
    volumes:
      - nextcloud_config:/config
      - nextcloud_data:/data
    environment:
      - PUID=1000
      - PGID=1000
      - TZ=UTC
      - NEXTCLOUD_UPLOAD_LIMIT=16G
      - NEXTCLOUD_MAX_TIME=3600
      - NEXTCLOUD_MEMORY_LIMIT=3G
      - SKIP_DOMAIN_VALIDATION=true
      - NEXTCLOUD_TRUSTED_DOMAINS=nextcloud.lan
Key Questions:
    How should I modify the docker-compose.yml to:
        Enable HTTPS for both services?
        Properly configure the reverse proxy for the local domains?
        Set up valid SSL certificates for *.lan domains?
    For Collabora:
        What extra_params or environment variables are needed for HTTPS?
        How to configure Nextcloud's config.php for the Collabora HTTPS endpoint?
I'd prefer a solution using Caddy if possible, as it's simpler for automatic HTTPS. Any working configuration examples would be greatly appreciated!
Thanks in advance for your help!
Viktor Malygin
WordPress Developer
Edited by Werner
Remove advertisment
  • Werner changed the title to ARM64 Armbian Collabora & Nextcloud -> nginx/caddy proxy for Local Domains on NanoPi R4S
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
