Skip to content
View in the app
Armbian Community Forums
How do I display the nice SSH login info again?
Featured Replies
Hi there, Orange Pi 5 user here, when I ssh into my Armbian installation remotely, it shows a nice welcome screen, with a bunch of facts like Uptime, Load, Temperature and so on
I tried typing 'motd' but it says no command found
I have 2 requests
1 - how do I display this manually, again, from a terminal?
2- is there a way to have this show when I open a terminal locally?  it's useful to me
thanks!
Solved by laibsch
  • Solution
The answer to your question is "sudo run-parts /etc/update-motd.d/", @snow
To have that information displayed every time you login, you might want to check ~/.profile or ~/.bash* files if you use bash as your shell.  I am not sure what problem you might run into since as you can see above the run-parts command needs root.  Do some testing, with and without root.
  • Author
Thank you @laibsch I unfortunately don't understand @Werner's response, but yours is very helpful, thank you very much!  I will look at trying to add that to my .bashrc or .zshrc I suppose! cheers
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
