Skip to content
View in the app
Armbian Community Forums
Problem GPIO PH5
Featured Replies
I get an error when i try to use the PH5 pin as digital output.
PH5 is the number 229 according to the following equation:  (8-1)*32+5 = 229
echo 229 > /sys/class/gpio/export
-bash: echo: write error: Device or resource busy
If i use other pins like PH13, PH19, PH20 or PH21, all work correctly. For example, for PH13 as digital output:
echo 237 > /sys/class/gpio/export
echo "out" > /sys/class/gpio/gpio237/direction
echo "1" > /sys/class/gpio/gpio237/value
echo "0" > /sys/class/gpio/gpio237/value
echo 237 > /sys/class/gpio/unexport
I get the same error in the Cubieboard2 and the Lime A20 board.
Can someone help me ?
Thanks in advance
  • Author
Thanks martinayotte for your answer. Yes, It seems this pin is being used. I will use another pin.
Thanks anyway
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
