Skip to content
View in the app
Armbian Community Forums
Armbian build framework for BananaPi M1+
Featured Replies
Dear maintainers,
can you answer a simple question: which board should be selected in build menu for BananaPi M1+ ?
I can  see 2 options for A20 Soc : "bananapi" and "bananapipro" ? Which one is the preferred option ?
Thanks
After this stable release (hopefully not later than in 1 week) there will be a separate build configuration for this device. Currently I'm not sure which of the existing ones is better because manual script.bin or fdtfile adjustments will be needed in either case.
  • Author
Thanks, waiting for it
  • Author
Hi, zador.blood.stained,
thank you, we can see bananapim1plus among boards now and it is possible to compile an image for it.
But there is a minor issue: for some reason the board does not appear in user interface.
8 minutes ago, Igor said:
You need to run a script with additional parameter EXPERT="yes" since it was added as .csc (community supported configuration).
I'm thinking about showing the switch supported/other view button regardless of EXPERT=yes since the warning will be shown anyway.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
