Skip to content
View in the app
Armbian Community Forums
NanoPi Duo RPi.GPIO
Featured Replies
I've built https://github.com/auto3000/RPi.GPIO_NP for the Duo running Armbian Ubuntu test image:
cd /sys/class/gpio
for i in gpiochip* ; do  echo `cat $i/label`: `cat $i/base` ; done
1c20800.pinctrl: 0
1f02c00.pinctrl: 352
Has anyone actually got RPi.GPIO working on Duo? I'm trying to get luma.oled cranking and have SPI working fine, but need GPIO working as well.
On 13.12.2017 at 8:13 PM, raschid said:
Try https://github.com/karabek/nanopi_duo_gpio_pyH3. I have not tried SPI, but I2C works rather nicely.
The mapping of this fork is really a mess... There are GPIOs defined which are not accessible on the Duo. PA15, PA16, PL11 and PG11 which are accessible via pin header aren't defined. Numbering for using connector instead of port is useless, cause also wrong...
If you need them go to pyGPIO ... :P (or go to pyGPIOs GitHub, search for the nanopiduo mapping, replace the one in this pyA20 fork and stay with it.. :P )
looks quite easy... opi is more or less the same.. not? As long as this:
Only the basic GPIO functions are replicated, using sysfs: this allows the GPIO pins to be accessed from user space.
matches to your needs.
I think, you only have to adjust this one: https://github.com/rm-hull/OPi.GPIO/blob/master/OPi/pin_mappings.py
reading the schematics and calculating sysfs pin numbers from here:
http://linux-sunxi.org/GPIO#Accessing_the_GPIO_pins_through_sysfs_with_mainline_kernel
  • Author
Yes, this is why I went down this route. I'll see if I can figure out the mappings. If I understand correctly then for example:
(position of letter in alphabet - 1) * 32 + pin number
CSUART3_TX/SPI1_CS/GPIOA13 would be:
(1-1) * 32 + 13 = 13?
should be correct
From pyGPIOs mapping.h:
			J1		  	 J2
(UART0_RX)		|1| microUSB |1|	 5V
(UART0_TX)		|·|	 		 |·|	5V
GND			|·|	 		 |·|	3.3V
GPIO3 (TWI_SCL)		|·|			 |·|	GND
GPIO2 (TWI_SDA)		|·|			 |·| 	GPIO4 (IR_RX)
GPIO23 (SPI1_CS)	|·|			 |·|	GPIO18 (IOG11)
GPIO22 (SPI1_CLK)	|·|			 |·|	DM3 D-
GPIO27 (SPI1_MISO)	|·|			 |·|	DM3 D+
GPIO17 (SPI1_MOSI)	|·|			 |·|	DM2 D-
GPIO15(UART1_RX)	|·|			 |·|	DM2 D+
GPIO14 (UART1_TX)	|·|			 |·|	RDN
(CVBS)			|·|			 |·|	RDP
(LINEOUT_L)		|·|			 |·|	TXN
(LINEOUT_R)		|·|			 |·|	TXP
(MICP)			|·|			 |·|	LED-LINK
(MICN)			|·|	microSD		 |·|	LED-SPD
*/  {"J1",
            {   "GPIO3",  SUNXI_GPA(11),  4   },
            {   "GPIO2",  SUNXI_GPA(12),  5   },
            {   "GPIO23",  SUNXI_GPA(13),  6   },
            {   "GPIO22",  SUNXI_GPA(14),  7  },
            {   "GPIO27",  SUNXI_GPA(16),  8  },
            {   "GPIO17",  SUNXI_GPA(15),  9  },
	    {   "GPIO15",  SUNXI_GPG(6),  11  },
            {   "GPIO14",  SUNXI_GPG(7),  10  },
                {   0,  0,  0}
	{"J2",
            {   "GPIO18",  SUNXI_GPL(11),  5   },
            {   "GPIO4",  SUNXI_GPG(11),  6   },
                {   0,  0,  0}
with XX being the number of the desired pin. To obtain the correct number you have to calculate it from the pin name (like PH18)[1]:
E.g for PH18 this would be ( 8 - 1) * 32 + 18 = 224 + 18 = 242 (since 'h' is the 8th letter).
1
'GPIO3' --> PA11 --> (1-1)*32 + 11 = 11
'GPIO4'  --> PG11 --> (7-1)32 + 11 = 203   ({   "GPIO4",  SUNXI_GPG(11),  6   },)
  • Author
Cool, thanks, I was able to read the button (GPIOL3) using:
echo 355 > /sys/class/gpio/export
echo in > /sys/class/gpio/gpio355/direction
cat /sys/class/gpio/gpio355/value
echo 355 > /sys/class/gpio/unexport
Now I'm going to try hacking OPi.GPIO :)
just for fun... I forked it and wrote the mapping for a nanopi duo (with minishield). Only the GPIOs no buttons no leds, no board to test... :D
https://github.com/chwe17/OPi.GPIO
If it works I might write a wrapper for the mappings from the pyGPIO and adjust the library a little bit to make it 'multiple boards' usable.
Can you test it?
in case you don't have the minishield: BCM naming should work and there is the 'naming scheme':
			J1		  	 J2
GND			|·|	 		 |·|	3.3V
(CVBS)			|·|			 |·|	RDP
in case you use the minishield (there you go... :P ):
			{   "POWER_LED",  SUNXI_GPL(10),  1   },
			{   "STATUS_LED",  SUNXI_GPA(10),  2  },
POWER_LED is PL10
STATUS_LED is PA10
12 minutes ago, sgjava said:
rm-hull:master and chwe17:master are identical.
ooops.. was only on my local git... :P
Now it should be there...
  • Author
How would you map the button and led then? I doesn't really have a pin number. I'm just going to hack some in the missing slots and see what happens. I'm trying to get something simple working before I wire up the SPI display I'm testing. I already have spi-dev working fine.
14 minutes ago, sgjava said:
How would you map the button and led then? I doesn't really have a pin number. I'm just going to hack some in the missing slots and see what happens. I'm trying to get something simple working before I wire up the SPI display I'm testing. I already have spi-dev working fine. Send me a PM and maybe I'll send you a Duo and/or mini shield. I'm going to get some v1.1s. I have v1.0 now.
I'll have to dig up the LEDs, but if they're used by the system then you won't be able to access them through the sysfs GPIO interface; you'll have you use the kernel LED driver. The button on the NanoPi Duo is GPIO 355
  • Author
Look above and you'll see I've figured out the button. The status LED blinks with https://github.com/karabek/nanopi_duo_gpio_pyH3/blob/master/examples/blink_POWER_STATUS_PL10.py, so I thought it was possible through A10. Also, if you look at /sys/class/gpio you see gpiochip352 which is the power LED. I'm not saying you are wrong, but maybe I'll need to dig into the source I just mentioned. In any event I'm going to try a simple OPi.GPIO hack real quick.
  • Author
OK, this is the same result that trying to access A10 from /sys/class/gpio which OPi.GPIO uses:
UserWarning: Channel 99 is already in use, continuing anyway. Use GPIO.setwarnings(False) to disable warnings.
I mapped 99 to 10. Let me look at the working source. The main thing I need is gpio_DC="CSID1", gpio_RST="CSID0" for luma.oled (this is from my CHIP config) and I believe that will work fine. I just wanted to test without wiring and configuring (being lazy here).
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
