Skip to content
View in the app
Armbian Community Forums
PWM Fan Configuration on Orange Pi 5 Max Running Armbian Debian Minimal
Featured Replies
This article describes how I successfully configured a PWM fan on an Orange Pi 5 Max running Armbian Debian Trixie Minimal vendor 6.1.115, using the opifancontrol utility.
Special thanks to Jamie Sinclair for creating and sharing the opifancontrol project with the community.
I have an Orange Pi 5 Max installed in a metal case and running several Docker containers, including Frigate, Immich, Samba, and others. The case originally came with a internal 30x30x10 mm fan, which was not able to provide sufficient cooling. Under load, CPU temperatures were reaching nearly 70°C.
To improve cooling, I installed an external 40x40x10 mm PWM fan that was originally used on an Odroid HC4. The fan was mounted using screws, which required drilling holes in the case cover. I also added several ventilation holes, in the case cover above the CPU area to improve airflow. After these modifications, the CPU temperature now stays around 48°C.
1. Install wiringOP
Follow the instructions from the wiringOP project:
 Download wiringOP
 $ apt-get update
 $ apt-get install -y git
 $ git clone https://github.com/orangepi-xunlong/wiringOP.git
 Build wiringOP
 $ cd wiringOP
 $ ./build clean
 $ ./build
 Verify the installation:
 $ gpio readall
This command should display the Orange Pi 5 Max GPIO pin map.
2. Configure GPIO Pin 7 as a PWM Output
 In Armbian, configure GPIO Pin 7 (PWM3_IR_M3) as a PWM output.
 $ sudo armbian-config
 Navigate to:
 System
 └─ Kernel
      └─ Overlays
 Select:
  rk3588-pwm3-m3
  Press the space bar to enable it, save the configuration, and reboot the system.
3. Install opifancontrol: https://github.com/jamsinclair/opifancontrol
 $ su
 $ cd /usr/local/bin/
 $ wget https://github.com/jamsinclair/opifancontrol/blob/main/opifancontrol.sh
 $ chmod +x /usr/local/bin/opifancontrol.sh
 $ curl -sSL https://raw.githubusercontent.com/jamsinclair/opifancontrol/main/install.sh | bash
Enable the service to start automatically at boot:
 $ systemctl enable opifancontrol.service
Start the service:
 $ systemctl start opifancontrol.service
Check the service status:
 $ systemctl status opifancontrol.service
4. PWM Fan Wiring
 I used a 5V, 4-wire, 4,000 RPM fan from an Odroid HC4.
 Connection details:
 Fan Wire   Function                     GPIO Pin
 Red            +5V Power                    Pin 4
 Black          GND                              Pin 6
 Blue            PWM Speed Control  Pin 7
 Yellow        TACH (RPM Sensor)    Not Connected
5. Adjust the Fan Control Configuration
Edit the configuration file:
 $ sudo nano /etc/opifancontrol.conf
 My settings are:
 TEMP_LOW=45
 FAN_LOW=60
 TEMP_MED=60
 FAN_MED=75
 TEMP_HIGH=70
 FAN_HIGH=100
 RAMP_UP_DELAY_SECONDS=30
 RAMP_DOWN_DELAY_SECONDS=60
After saving the configuration file, restart the service:
 $ sudo systemctl stop opifancontrol.service
 $ sudo systemctl start opifancontrol.service
With these settings and the hardware modifications described above, my Orange Pi 5 Max now operates significantly cooler, maintaining temperatures around 48°C while running multiple Docker services
Edited by malima17
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
