Skip to content
View in the app
Armbian Community Forums
[Armbian newsletter] - One board, two architectures: Armbian on the Milk-V Duo S
Featured Replies
The Milk-V Duo S is a very cheap and small board. It runs a Sophgo SG2000 with
an Arm Cortex-A53 and a RISC-V C906, 512 MB of RAM, and a physical slide switch decides which
one boots. Armbian now supports both architectures. PR #10326 landed the port (175 files) as two thin board targets – milkv-duos-arm and milkv-duos-riscv – over a single shared family include, so the bootloader pins can't drift apart. PR #10510 moved the edge branch to kernel 7.1.
Standing on the shoulders of others
There are at least 2 projects the port owes a lot to: queenkjuul/milkv-duo-ubuntu (Ubuntu on a mainline kernel 7.0, RISC-V) and Fishwaldo/sophgo-sg200x-debian (Debian sid, vendor kernel 5.10). Armbian takes the mainline route, adds arm64, and builds the entire boot chain from source: no prebuilt fip.bin.
What the patches add
Kernel (57 patches per branch, one series for both architectures – the arm64
device tree includes the RISC-V ones): thermal sensor, watchdog, PWM, eFuse, DMA, MDIO mux, I2S, mailbox, the C906L coprocessor, correct eMMC and
microSD pin muxing, USB gadget mode, ramoops, and overlays for the 26-pin header (I²C, SPI, UART, PWM) and USB device mode.
U-Boot (vendor 2021.10): distroboot: the standard armbianEnv.txt + boot.scr mechanism works and overlays are chosen at boot rather than at build (like in other implementations), plus a fix for the SD slot being powered down when empty.
1050 MHz as a default RISC-V speed. Provided by a build option
SOPHGO_CPU_OVERDRIVE.
Both bootloaders ship in every image, so one image boots from microSD or eMMC – but flashing to the eMMC still requires special treatment using sophgo-emmc-install.
./compile.sh build BOARD=milkv-duos-arm BRANCH=edge
Usage example
The board runs under 1 W, so it can make a nice always-on serial console.
milkv-duos-uart turns a Duo S into a recorder for Rockchip boards (or any others!): enable the UART2 overlay, connect three pins, and it keeps a 32 MiB RAM ring buffer you can follow, dump as history, or attachand use like a normal console. This way a guest's boot log can survive even it it dies.
What are your ideas for this board?
View the full article
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
