August 30Aug 30 Some 4K VP9 videos — odd/Academy-ratio resolutions like 2970×2160 — hardware-decoded into a solid green frame on RK3588. Root-caused to a surface-stride alignment bug in the VA-API driver and fixed. Now it's a one-line apt install, no building from source. [ — same Pi, same video, green → clean 4K ] 📎 Full illustrated guide attached (unzip → open the HTML) · also online: https://defcom5-rockchip.github.io/rockchip-vaapi/ Quick start — BSP kernel only (/dev/mpp_service must exist): cd /tmp wget https://github.com/defcom5-rockchip/rockchip-vaapi/releases/download/v1.0.11-defcom5.vp9align1/rockchip-vaapi-driver_1.0.11+defcom5.vp9align1_arm64.deb sudo apt install ./rockchip-vaapi-driver_1.0.11+defcom5.vp9align1_arm64.deb Then wrap Firefox with LIBVA_DRIVER_NAME=rockchip + MOZ_DISABLE_RDD_SANDBOX=1, and enable media.ffmpeg.vaapi.enabled / media.hardware-video-decoding.enabled in about:config. Full steps — wrapper script, verify, YouTube tip — in the attached guide. Source, credit & reproducer → github.com/defcom5-rockchip/rockchip-vaapi Base driver: woodyst (Eduardo García-Mádico Portabella) · PR #2 fixes: truongsinh · VP9 64-align fix: defcom5-rockchip Firefox-4K-HW-Decode-RK3588.zip Edited August 31Aug 31 by defcom5-rockchip formatting
