Skip to content
View in the app
Armbian Community Forums
Sound Card Lost after upgrading packages
Featured Replies
After I run apt-get  update and upgrade, I lose the sound card:
aplay -l
aplay: device_list:268: no soundcards found...
If I check my upgrade history, I can see the following:
cat /var/log/apt/history.log
Start-Date: 2018-03-16  22:33:12
Commandline: apt-get upgrade
Upgrade: libgssapi-krb5-2:armhf (1.12.1+dfsg-19+deb8u2, 1.12.1+dfsg-19+deb8u4), tzdata:armhf (2017b-0+deb8u1, 2018c-0+deb8u1), ncurses-term:armhf (5.9+20140913-1, 5.9+20140913-1+deb8u2), libkrb5-3:armhf (1.12.1+dfsg-19+deb8u2, 1.12.1+dfsg-19+deb8u4), libk5crypto3:armhf (1.12.1+dfsg-19+deb8u2, 1.12.1+dfsg-19+deb8u4), linux-image-next-sunxi:armhf (5.34, 5.41), armbian-firmware:armhf (5.34, 5.38), libcurl3:armhf (7.38.0-4+deb8u9, 7.38.0-4+deb8u10), openssh-sftp-server:armhf (6.7p1-5+deb8u3, 6.7p1-5+deb8u4), sudo:armhf (1.8.10p3-1+deb8u4, 1.8.10p3-1+deb8u5), linux-u-boot-lime-next:armhf (5.34, 5.38), openssh-server:armhf (6.7p1-5+deb8u3, 6.7p1-5+deb8u4), libkrb5support0:armhf (1.12.1+dfsg-19+deb8u2, 1.12.1+dfsg-19+deb8u4), hostapd:armhf (2.6-4~armbian5.34.171017+1, 2.6-4~armbian5.38+1), curl:armhf (7.38.0-4+deb8u9, 7.38.0-4+deb8u10), base-files:armhf (8+deb8u9, 8+deb8u10), libdb5.3:armhf (5.3.28-9, 5.3.28-9+deb8u1), ncurses-bin:armhf (5.9+20140913-1+b1, 5.9+20140913-1+deb8u2), linux-dtb-next-sunxi:armhf (5.34, 5.41), openssh-client:armhf (6.7p1-5+deb8u3, 6.7p1-5+deb8u4), libcurl3-gnutls:armhf (7.38.0-4+deb8u9, 7.38.0-4+deb8u10), armbian-tools-jessie:armhf (5.34, 5.38), sunxi-tools:armhf (1.4.2-1~armbian5.34.171017+1, 1.4.2-2~armbian5.38+1), libicu52:armhf (52.1-8+deb8u5, 52.1-8+deb8u6), linux-jessie-root-next-lime:armhf (5.34, 5.38), libtinfo5:armhf (5.9+20140913-1+b1, 5.9+20140913-1+deb8u2), libncursesw5:armhf (5.9+20140913-1+b1, 5.9+20140913-1+deb8u2), libncurses5:armhf (5.9+20140913-1+b1, 5.9+20140913-1+deb8u2), ncurses-base:armhf (5.9+20140913-1, 5.9+20140913-1+deb8u2)
End-Date: 2018-03-16  22:36:11
In the following pictures you can see the modules of the system, before and after the upgrade process
Why have I lost the sun4i_codec and snd_soc_core ?
what can I do to enable the sound card again ?
Thanks a lot in advance,
Regards
Solved by Igor
  • Author
Thank you guidol, I was running armbianmonitor -u, when Igor answered.
Thank you very much Igor, it solved the problem with the sound card :)
Regards
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
