Skip to content
View in the app
Armbian Community Forums
install to emmc on OPi Zero Plus2
Featured Replies
Hi there,
tomorrow I should obtain my OPi Zero Plus2. I see it does not have USB port (just GPIO for USB, so I could solder USB port for it with GPIO, no problem).
Then, I will need to install my own raspbian.img on eMMC (I am using read only system). Till now I installed it on many SD cards to another Opi Zero's and used it so (because of lack eMMC). But how to install it on Opi Zero Plus2? Do I need to install it on SD card first and then go with nand-sata-install?
Honestly, I would like to install it (the best) with USB or some other way, because I will need to install dozen of pieces and it is pretty time consuming to install if from SD card (and secondly I don't know if read-only images will install ok).
Usually my armban.img file is between 1GB. Is there any way how to upload/install it directly to emmc from standard PC?
What I really need to do is to simplify whole install process at minimum steps, because I will need to install it for more pieces probably.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
