Skip to content
View in the app
Armbian Community Forums
How to unable the UART or serial connection in Armbian OS with Banana Pi Zero ?
Featured Replies
Hi All
I am using Banana Pi Zero.
I have installed the Armbian OS in the SD card.
Log In working successfully.
I want to enable the UART in the Banana Pi Zero with Armbian OS.
I want to get the internet connection using GSM module with UART.
If you have any appropriate link for this plz message me.
Command Output:
1.
root@mintboxlite:~# uname -r
3.4.113-sun8i (Kernel Version)
2.
root@mintboxlite:~# cat /etc/armbian-release
# PLEASE DO NOT EDIT THIS FILE
BOARD=bananapim2zero
BOARD_NAME="Banana Pi M2 Zero"
BOARDFAMILY=sun8i
VERSION=5.41
LINUXFAMILY=sun8i
BRANCH=default
ARCH=arm
IMAGE_TYPE=user-built
BOARD_TYPE=conf
INITRD_ARCH=arm
KERNEL_IMAGE_TYPE=zImage
3.
root@mintboxlite:~# dmesg | grep tty
[    0.000000] Kernel command line: root=UUID=fa26cc3d-091a-4510-ba3f-f12f36bff240 rootwait rootfstype =ext4 console=tty1 console=ttyS0,115200 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=                           10 consoleblank=0 loglevel=1 ubootpart=ce9cea4f-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u, 0x2537:0x1068:u   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable                  =memory swapaccount=1
[    0.000000] console [tty1] enabled
[    0.547802] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[    0.547987] console [ttyS0] enabled
[    0.548404] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[    0.548697] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[    0.548994] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI
[    4.111940] systemd[1]: Expecting device dev-ttyS0.device...
[    5.110580] systemd[1]: Starting system-serial\x2dgetty.slice.
[    5.130252] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    5.130411] systemd[1]: Starting system-getty.slice.
[    5.150169] systemd[1]: Created slice system-getty.slice.
[    7.530201] systemd[1]: Found device /dev/ttyS0.
Can anyone help me.
I have not found any proper documentation for UART and Sim Module Configuration.
Thanks in advance.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
