Skip to content
View in the app
Armbian Community Forums
Amlogic buildroot help
Featured Replies
If you have ever compiled buildroot from Amlogic, please help me. I am trying to learn develop app on amlogic based device.
First I was getting compile error on 64bit Ubuntu 16.04.
Something like this. Even though there was a file, 'bash' couldn't find  or run.
/bin/bash: /root/buildroot/x86/xxxx-gcc: No such file or directory
Thinking it's something to do with 64 bit OS, I switched to 32 bit Ubuntu 16.04.
However after about 2 hours I'm getting following error.
/bin/bash: /root/buildroot_openlinux/output/meson8b_m201/host/usr/gcc-arm-none-eabi-6-2017-q2-update/bin/arm-none-eabi-gcc: No such file or directory
dirname: missing operand
Try 'dirname --help' for more information.
/bin/bash: /root/buildroot_openlinux/output/meson8b_m201/host/usr/gcc-arm-none-eabi-6-2017-q2-update/bin/arm-none-eabi-ld: No such file or directory
fatal: Not a git repository (or any of the parent directories): .git
To compare two paths outside a working tree:
usage: git diff [--no-index] <path> <path>
make[2]: *** No rule to make target '/root/buildroot_openlinux/output/meson8b_m201/build/uboot-next/build/firmware.bin', needed by '/root/buildroot_openlinux/output/meson8b_m201/build/uboot-next/build/api/libapi.o'.  Stop.
make[2]: *** Waiting for unfinished jobs....
arm-none-eabi-gcc -DDO_DEPS_ONLY \
        -g  -Os   -D__KERNEL__ -I/root/buildroot_openlinux/output/meson8b_m201/build/uboot-next/build/include2 -I/root/buildroot_openlinux/output/meson8b_m201/build/uboot-next/build/include -I/root/buildroot_openlinux/output/meson8b_m201/build/uboot-next/include -fno-builtin -ffreestanding -nostdinc -isystem  -pipe  -DCONFIG_ARM -D__ARM__           -Wall -Wstrict-prototypes    \
        -o /root/buildroot_openlinux/output/meson8b_m201/build/uboot-next/build/lib/asm-offsets.s /root/buildroot_openlinux/output/meson8b_m201/build/uboot-next/lib/asm-offsets.c -c -S
Makefile:805: recipe for target '/root/buildroot_openlinux/output/meson8b_m201/build/uboot-next/build/lib/asm-offsets.s' failed
make[2]: *** [/root/buildroot_openlinux/output/meson8b_m201/build/uboot-next/build/lib/asm-offsets.s] Error 127
package/pkg-generic.mk:216: recipe for target '/root/buildroot_openlinux/output/meson8b_m201/build/uboot-next/.stamp_built' failed
make[1]: *** [/root/buildroot_openlinux/output/meson8b_m201/build/uboot-next/.stamp_built] Error 2
/root/buildroot_openlinux/output/meson8b_m201/Makefile:16: recipe for target '_all' failed
make: *** [_all] Error 2
Again those files exists. File command shows following.
arm-none-eabi-gcc: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, for GNU/Linux 2.6.24, BuildID[sha1]=0c937a9bf52dcb3a4e5ced5efc41213730d23b54, stripped
Am I  doing anything wrong? Any input will be appreciated.
Thanks in advance.
Edited by dsh
Fixed spelling
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
