Skip to content
View in the app
Armbian Community Forums
Default W1 pin on Nano PI NEO
Featured Replies
I enabled modules, and connected DS18B20 but still haven't 28-XXX... folder in /sys/bus/w1/devices.
In README.sun8i-h3-overlays written that default port is PD14 but i can't find it on my board pinout.
  • Author
cat /sys/kernel/debug/gpio
gpiochip0: GPIOs 0-223, parent: platform/1c20800.pinctrl, 1c20800.pinctrl:
 gpio-10  (                    |nanopi:blue:status  ) out lo
 gpio-110 (                    |w1                  ) in  lo
 gpio-166 (                    |cd                  ) in  lo
gpiochip1: GPIOs 352-383, parent: platform/1f02c00.pinctrl, 1f02c00.pinctrl:
 gpio-362 (                    |nanopi:green:pwr    ) out hi
So now w1 uses gpio-110 but i still can't find it on pinout
  • Author
11 hours ago, martinayotte said:
PD14 equals GPIO110 ...
But, effectively, according to schematic of NanoPi-NEO, since header has only 24 pins, the PD14 is not there unlike many other boards.
You can use PG11 (GPIO203) or PA6 (GPIO6) instead, but you need to decompile overlay, edit to change the pin, and recompile it.
Thank you, solved.
Is there a difference to the NanoPi NEO Air?
I tried to setup W1 with my NanoPi NEO Air (Rev 1.0) but i failed. I changed pins to "PG11" in /boot/dtb/overlay/sun8i-h3-w1-gpio.dtbo (and in sun7i*w1 and sun4i*w1 as well), but W1 remains on gpio-110:
 gpio-10  (                    |nanopi:blue:status  ) out hi
To be sure, i double checked the new dtbo files by decompiling them again.
Kernel: Linux nano01 4.14.65-sunxi #1 SMP Mon Aug 20 08:45:20 CEST 2018 armv7l GNU/Linux
Do you have some hints for me?
Best regards, Thomas
I think that's not the case:
dtc -I dtb -O dts sun8i-h3-w1-gpio.dtbo.orig > orig.dts
dtc -I dtb -O dts sun8i-h3-w1-gpio.dtbo.new > new.dts
diff orig.dts new.dts
12c12
< 				pins = "PD14";
> 				pins = "PG11";
The real file name in /boot/dtb/overlay/ is sun8i-h3-w1-gpio.dtbo. :-)
Thanks very much for helping, martinayotte!
cat /proc/device-tree/soc/pinctrl@01c20800/w1_pins/pins
PG11
So this seems to be correct.
cat /boot/armbianEnv.txt
overlay_prefix=sun8i-h3
overlays=i2c0 i2c1 i2c2 usbhost1 usbhost2 w1-gpio
I added w1-gpio by using armbian-config.
I tried armbian-add-overlay as well (mentioned in https://docs.armbian.com/User-Guide_Allwinner_overlays/ ):
armbian-add-overlay w1-gpio.dts
Error: dtc does not support compiling overlays
Please try to install matching kernel headers
Thanks in advance!
Thomas
You guys are awesome. I love you but I also hate you. :P That  is  a joke btw.
Remember, threads/emails are not ideal communication. When you finalize a thread, maybe wrap it all up in a single coherent, command by command tutorial?
Just spent the last hour trying to hodge podge the meaning of this thread + this
All I needed to know is that param_w1_pin=PG11 shoulda been on a seperate line while a simple dump of the full amrbianEnv.txt woulda sufficed...
verbosity=1
logo=disabled
console=serial
disp_mode=1920x1080p60
overlays=armbian-add-overlay usbhost1 usbhost2 w1-gpio
param_w1_pin=PG11
rootdev=UUID=41c3101b-b077-456b-b9cd-a7717422b4b3
rootfstype=ext4
Not to mention how to actually de/recompile dbto's and dts's. I would love to post back here those simple commands that were just glossed over in this thread but I can't guarantee I'll be able to do that. Anyone with a life outside themselves would understand how valuable 1 hour of uninterrupted time to decompiling text based gibberish is, all the while knowing it could legit, be automated.
If there's any doubt to the tone of this message. I prove my point and thank you guys.
Which is easier to say? Every post previous, or run this?
Attached is a bash script that will install and make various dtbo/dts edits automagically in order to install and interface with ds18b20 Thermometer connected to a NPiNeo running Armbian 5.69.
I've also attached an image for how the module needs to be physically connected (using 10k resistor between 1 wire and PWR). If you do not have a physical 10k resistor you may use the internal pullup to do so (do not use on long connections?) This is done by adding param_w1_pin_int_pullup 1 on a newline after param_w1_pin=PG11 in the /boot/armbianEnv.txt file.
The picture is for a raspi connection. Simply connect blue wire to PG11 on NanoPi Neo, Red to 3.3v PWR. Black wire to GND. All of which are actually located on the exact same pins if you flip the picture 90 degrees clockwise and cross reference it to FriendlyArms standard schematic. Also attached.
WARNING: I created the attached script from a default installation of Armbian. It will erase current /boot/armbianEnv.txt file.  Use sed or edit printf command to customize.
- physical bash script attached
- gist copy of script here: https://gist.github.com/BiTinerary/0ab5f3c7bf118456fc02bb0b876dc172
ds18b20ThermoNPiNeoInstall.sh
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
