Skip to content
View in the app
Armbian Community Forums
Armbian for Amlogic S9xxx kernel 5.x
Featured Replies
Yes!
My K2 is ready to test images: I have several SD card so no problem to rewrite them from scratch...
Waiting for your images...
Hello @balbes150,
I have tried your latest 5.76 with Mali support. H264 video streams are decoded by HW, however, H265 streams are decoded by SW.
I have used following command without any parameter.
mpv [Video-URL]. In case of H265, do I need to explicitly state HW decoder?
Also I have tried building one myself using your script but I can't find where select Mali driver options.
Thanks in advance.
  • Author
1 hour ago, Xavier31 said:
Yes!
1. Copy of the standard u-boot from the working SD card.
dd if=/dev/mmcblkXXX of=u-boot_k2.img bs=1M count=4
2. Burn the image Armbian for TV Boxing on the SD card.
3. Replace u-boot on the recorded SD card
dd if=u-boot_k2.img of=/dev/mmcblk0 conv=fsync bs=1 count=442
dd if=u-boot_k2.img of=/dev/mmcblk0 conv=fsync bs=512 skip=1 seek=1
Configure the correct DTB for K2. If you have u-boot-2018\19 , then in the file "/extlinux/extlinux.conf".
If u-boot is different, show its version.
  • Author
Also there is no audio.
This is a test case, I'm not sure h265 is supported. Look at the list of decoders and try them.
Will do that.
Aside from that,
Are we eventually be able to flash directly to emmc by Amlogic burning tool?
  • Author
A new set of images 5.77_20190407 , used by the kernel 5.1.0-rc1.
Pay attention, this is a generic image for the entire line of S9xxx (including for S912 and S905x2).
Enabled by default DTB for Khadas VIM1 (S905X). To run on other models, you need to configure DTB.
I planned to use Armbian_5.75_Nanopik2-s905_Ubuntu_bionic_next_4.19.20_desktop.img to prepare a working SD card and then to grab u-boot from.
But I noticed this image contains only one partition.
Armbian_5.77_Aml-s905_Ubuntu_bionic_default_5.1.0-rc1_desktop_20190407.img image contains two partitions.
Is your procedure always applicable in such situation?
  • Author
Yes, follow the description. The recovery option is specially made to save the current partition table.
BM8 s912 2Gb meson-gxm-q200.dtb
root@aml-bm8:~# uname -a
Linux aml-bm8 5.1.0-rc1-aml-s905 #5.77 SMP PREEMPT Sun Apr 7 12:55:48 MSK 2019 aarch64 aarch64 aarch64 GNU/Linux
update: T95Z Plus - s912 octacore 3gb ram :thumbup:
I performed following steps:
  1. root@desktop:~# cat Armbian_5.75_Nanopik2-s905_Ubuntu_bionic_next_4.19.20_desktop.img > /dev/sdf
  2. root@desktop:~# dd if=/dev/sdf of=u-boot_k2.img bs=1M count=4
  3. root@desktop:~# cat Armbian_5.77_Aml-s905_Ubuntu_bionic_default_5.1.0-rc1_desktop_20190407.img > /dev/sdf
  4. root@desktop:~# dd if=u-boot_k2.img of=/dev/sdf conv=fsync bs=1 count=442
  5. root@desktop:~# dd if=u-boot_k2.img of=/dev/sdf conv=fsync bs=512 skip=1 seek=1
  6. root@desktop:~# vi extlinux/extlinux.conf
  7. add line:
    FDT /dtb/meson-gxbb-nanopi-k2.dtb
SD card boots perfectly.
Below, output of uname -a
Linux aml 5.1.0-rc1-aml-s905 #5.77 SMP PREEMPT Sun Apr 7 12:55:48 MSK 2019 aarch64 aarch64 aarch64 GNU/Linux
I noticed this image doesn't contain mali drivers so I don't expect a smooth Kodi GUI...
I will play with it anyway and achieve some tests.
If you think about some tests you would like I perform, feel free to ask...
test images 5.77_20190407 with Beelink GT1 mini , mouse keyboard vidoe, all is good
except : HDMI no sound   no wifi,   any suggest?
  • Author
Please note, this is the first test version, it does not work yet sound from HDMI, WiFi and video acceleration HW. Works wired network, USB sound card and USB WiFi. Video in SW mode surprisingly works in up to 1080p inclusive.
https://forum.freaktab.com/forum/tv-player-support/amlogic-based-tv-players/606133-linux-images-for-s802-s805-s812-s905-s905x-s912-sd-usb-emmc?p=768370#post768370
New image 20190408
only changes
add support BT and eMMC for x96 max (s905x2).
  • Author
Checked work with eMMC of the last variant of an image 20190408 on x96max. eMMC can see,  the ddbr utility creates a full copy. I also checked the installation of the latest version of LibreELEC in eMMC, the system was installed in eMMC without problems and works from eMMC. :)
  • Author
Now checked on Odroid C2 an image 5.76 with MALI and a media script, by a technique with replacement of u-boot, as for K2.  :)
Everything works fine. After installing the script, the standard browser began to play video 1080 full screen without brakes. MPV is just as easy to handle any full-screen video. Bonus has an in-house sound via HDMI. There is one caveat when configuring - it is necessary to specify the correct DTB option in the file for Odroid C2  "/extlinux/extlinux conf".
For those who don't know. The browser has a special additional link for a quick test of full-screen video. :)
I modified the ethernet dtb for x96max 2GB version, it could boot but there is no driver for ethernet device from dmesg. Could you release the new image for the x96max 2GB version? Thanks
ethernet@ff3f0000 {
				compatible = "amlogic, g12a-eth-dwmac", "snps,dwmac";
				reg = <0x0 0xff3f0000 0x0 0x10000 0x0 0xff634540 0x0 0x8 0x0 0xff64c000 0x0 0xa0>;
				reg-names = "eth_base", "eth_cfg", "eth_pll";
				interrupts = <0x0 0x8 0x1>;
				interrupt-names = "macirq";
				status = "okay";
				clocks = <0x2 0x38>;
				clock-names = "ethclk81";
				pll_val = <0x9c0040a 0x927e0000 0xac5f49e5>;
				analog_val = <0x20200000 0xc000 0x23>;
				pinctrl-names = "external_eth_pins";
				pinctrl-0 = <0x11>;
				mc_val = <0x1621>;
				cali_val = <0x30000>;
				internal_phy = <0x0>;
		external_eth_pins {
			linux,phandle = <0x11>;
			phandle = <0x11>;
			mux {
				groups = "eth_mdio", "eth_mdc", "eth_rgmii_rx_clk", "eth_rx_dv", "eth_rxd0", "eth_rxd1", "eth_rxd2_rgmii", "eth_rxd3_rgmii", "eth_rgmii_tx_clk", "eth_txen", "eth_txd0", "eth_txd1", "eth_txd2_rgmii", "eth_txd3_rgmii";
				function = "eth";
				drive-strength = <0x3>;
  • Author
I will try to add it in the next versions.
New image 20190408
only changes
I will test the new image on emmc, if it works, i will reply.
thanks for your hard work.
Hi there, i have a question regarding the stability of my tv box. I actually use a km8p as a pihole box and every week it crashed and i have to hard reboot it to make it works again. Can someone give me a hint to see where logs can help knows where could be the problem?
I was on 5.1 kernel when i got the prob so i reinstall the box from scratch with previous build in 4.20.5 and both got the problem.
Last kern.log is just :
Apr 11 04:01:29 localhost kernel: [   92.903423] random: 7 urandom warning(s) missed due to ratelimiting
Thanks.
Thanks.
Are you using the WiFi or ethernet to connect to the net? Also try a different power brick if you have one, you could have received a bad one.
andrew@km8p1:~$ uptime
22:12:51 up 23 days
andrew@km8p2:~$ uptime
22:13:38 up 47 days
andrew@km8p3:~/Development/Armbian-NG$ uptime
22:14:01 up 47 days
10 hours ago, balbes150 said:
Uploaded to the website alpha versions of images (Armbian and LibreELEC) with kernel 5.1.0-rc1 for Odroid N2.  :rolleyes:
You have uploaded Armbian s912 5.78.
What are the benefits / improvements over Armbian 5.77?
It appears the Kernel has gone from 5.0 to 5.1?
Does that mean better Video driver performance?
P.S. 5.77 s912 runs great on my Mecool s912 TV box. I use it as my main TV / projector player now utilizing VLC.
Thanks for the great work.
22:12:51 up 23 days
22:13:38 up 47 days
22:14:01 up 47 days
I don't use WiFi nor BT at all. Only ethernet. Will try with a different power supply. Thanks.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
