Skip to content
View in the app
Armbian Community Forums
banana pi M2 H2+ zero Camera modul doesn't work
Featured Replies
How can I setup my banana pi M2 H2+ ARMBIAN 5.41 user-built Ubuntu 16.04.5 LTS 3.4.113-sun8i camera module
I set this command "sudo modprobe sunxi_csi1" and returned: "modprobe: FATAL: Module sunxi_csi1 not found in directory /lib/modules/3.4.113-sun8i"
I Don't see /dev/video0
Can I  confirm and setup my camera module?
are you sure modul name is "sudo modprobe sunxi_csi1" and not "sudo modprobe sunxi_csi"?
can you post your build kernel configuration?
/dev/video gets created when sunxi_csi modul gets loaded
do you still use fex file for configuration? can you post it?
which camera are you using?
i would recommend using latest next armbian with latest stable kernel and proper device tree config instead of deprecated fex, at least i got there the ov5640 running.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
