Skip to content
View in the app
Armbian Community Forums
i2c can't find any attached module on H3 board with mainline kernel (NPi Air)
Featured Replies
I have few of i2c devices that was successfully tested working with RPi Zero W (Tiny RTC, BME280), but no one is visible to NanoPi Neo Air board with Armbian. I can't get it to work on latest few versions of Armbian.
As soon as I add i2c0 to overlays there appears two of i2c devices (both silent):
$ ls -la /dev/i2c*
crw-rw---- 1 root i2c 89, 0 Jan 28 14:58 /dev/i2c-0
crw-rw---- 1 root i2c 89, 1 Jan 28 14:58 /dev/i2c-1
I need to admit that scan itself took quite significant amount of time.
$ sudo time i2cdetect -y 0
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
0.00user 0.04system 3:59.62elapsed 0%CPU (0avgtext+0avgdata 1036maxresident)k
0inputs+0outputs (0major+64minor)pagefaults 0swaps
Since it could be a problem with pull-up resistors, I've tried to add 4K7 resistors to SDA and to SCL lines, but situation remains the same.
What am I doing wrong? What step is missed? Will appreciate any help. Thank you.
  • Author
Thank you for quick response, @martinayotte
> Could be that you mistakenly crossed SDA and SCL ?
Checked and re-checked for a lots of times, tried different jumpers and different breadboards.
Unfortunately I have no oscilloscope to check if i2c bus is working, but are there any ways to test the bus? E.g.: what does it means if i2cdetect scan takes so much time? Could it signalize something?
"i2cdetect -y 0" should be almost instantenous, left than half second for the whole 127 addresses !
If it takes about 1 seconds per address, this means you pullups are defective, or they are placed on the wrong pins.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
