Skip to content
View in the app
Armbian Community Forums
/usr/lib/nand-sata-install/nand-sata-install.sh
Featured Replies
i try nand-sata-install.sh .
namely
before nand-sata-install.sh
   usb hard disk ----orange pi PI -----micro sd
   (sda)
fdisk -l /dev/sda
Device     Boot    Start       End   Sectors                      Size        Id Type
/dev/sda1       12584960 488397163 475812204 226.9G 83 Linux
/dev/sda2           2048  12584959  12582912        6G         82 Linux swap / Solaris
after nand-sata-install.sh     plus     rewriting  swap line of /etc/fstab
/etc/fstab
 tmpfs           /tmp         tmpfs   nodev,nosuid,size=256M          0  0
/dev/sda1    /               ext4    defaults,noatime,nodiratime,commit=600,errors=remount-ro        0       0
/dev/sda2                   none swap sw 0 0
/dev/mmcblk0p1        /media/mmc   ext4    defaults        0       0
/media/mmc/boot      /boot   none    bind        0       0
 df is
Filesystem     1K-blocks    Used Available Use% Mounted on
/dev/root      234171444 4225628 218050512   2% /
devtmpfs          381396       0    381396   0% /dev
tmpfs             512624       0    512624   0% /dev/shm
tmpfs             512624    6980    505644   2% /run
tmpfs               5120       4      5116   1% /run/lock
tmpfs             512624       0    512624   0% /sys/fs/cgroup
tmpfs             262144       8    262136   1% /tmp
/dev/mmcblk0p1  14281204 4199032   9356720  31% /boot
tmpfs             102528       0    102528   0% /run/user/1000
namely root is over 200GB ( in HDD)
i think hard disk is more sutable for hevy duty so nand-sata-install.sh is good tool for us .
{ ls /boot/ } is
System.map-3.4.110-sun8i  bin  boot.bmp  boot.cmd  boot.scr  config-3.4.110-sun8i  script.bin  vmlinuz-3.4.110-sun8i  zImage
and
when gparted , /media/mmc apear .
and  {ls /media/mmc}  is
bin   dev  home  lost+found  media  opt   root  sbin     srv  tmp  var
boot  etc  lib   ma1         mnt    proc  run   selinux  sys  usr
can i erase /media/mmc folda except boot ?
( rm -rf /media/mmc/bin  and so on)
if i get  redundant sd card , i try experiment .
regards
  • Author
i have done home work .
the present state is that /boot is in 32GB sd .
i intend to change 32GB sd for 4GB sd .
with kali linux , i insert 4GB sd to kali linux PC .
dd if=/Armbian_5.05_Orangepih3_Debian_jessie_3.4.110_desktop.raw  of=/dev/sdb bs=16M
and over internet , by sftp  i get /boot of  32GB sd ,
and cp -pR  {/boot/* of 32GB sd }  /mb1
and
cd /mb1
rm -rf  usr var .....and so on
so
the content of 4GB sd card is
ls -l /boot/
total 6964
-rw-r--r-- 1 root root 2107649  3月  9 04:03 System.map-3.4.110-sun8i
drwxr-xr-x 2 root root    4096  3月 15 13:20 bin
-rw-r--r-- 1 root root    6944  3月  9 04:23 boot.bmp
-rw-r--r-- 1 root root    2019  4月  9 23:35 boot.cmd
-rw-r--r-- 1 root root    2091  4月  9 23:35 boot.scr
-rw-r--r-- 1 root root   93944  3月  9 04:03 config-3.4.110-sun8i
lrwxrwxrwx 1 root root      24  3月 15 13:20 script.bin -> /boot/bin/orangepipc.bin
-rw-r--r-- 1 root root   35916  4月 20 18:19 script.bin.bak
-rwxr-xr-x 1 root root 4866320  3月  9 04:03 vmlinuz-3.4.110-sun8i
lrwxrwxrwx 1 root root      21  3月  9 04:23 zImage -> vmlinuz-3.4.110-sun8i
and i can boot armbian
now
250GB USB hard disk(this is /)-------[orange pi PC]---micro sd 4GB(this is  /boot)
i spare 32 GB sd card   and    as /   hard disk  is more tough than sd card , so i think .
df
/dev/root      234171444 4376704 217899436   2% /
tmpfs             512624    6976    505648   2% /run
/dev/mmcblk0p1   2275348   92352   2067424   5% /boot
fdisk -l /dev/mmcblk0
Disk /dev/mmcblk0: 3.7 GiB, 3951034368 bytes, 7716864 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x000276fe
/dev/mmcblk0p1       2048 4625127 4623080  2.2G 83 Linux
and 250GB hard disk cloning is easy .
250GB  usb hdd-------
                                    orange pi PC-----4GB micro sd card
clone-rsync-HDD2HDD.bat
df
fdisk -l /dev/sda
fdisk -l /dev/sdb
read X
echo $x
cd /mb1
mkdir -p bin etc home lib opt root sbin srv usr var selinux boot
for x in /bin /etc /home /lib /opt /root  /sbin /srv /usr /var /selinux /boot
do
rsync -avHx  --delete $x/  /mb1$x/
done
cd /mb1
mkdir -p  dev proc sys media mnt run tmp
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
