Skip to content
View in the app
Armbian Community Forums
armbian Amlogic S905x kernal 3.14 image can't save to emmc/nand
Featured Replies
I tried some steps.
1. The image is  Armbian_5.37_S9xxx_Ubuntu_xenial_3.14.29_server_20180209.img.xz
2, The arm box is Amlogic S905X 2+16 emmc.
3. Printf the save.log when run "ddbr" and "./install.sh".
4. It no boot when run reboot, see reboot.log.
5. I don't how to save the image to emmc,no boot from TFcard.
save.log
Done copy ROOTFS
Writing new kernel image...
65536+0 records in
65536+0 records out
33554432 bytes (34 MB, 32 MiB) copied, 0.828127 s, 40.5 MB/s
/dev/boot: no Android Magic Value
/dev/boot: not a valid Android Boot Image.
done.
Write env bootargs
Complete copy OS to eMMC parted DATA
root@amlogic:~#
reboot.log
        aml_dt soc: gxl platform: p212 variant: 2g
        dtb 0 soc: gxl   plat: p212   vari: 1g
        dtb 1 soc: gxl   plat: p212   vari: 2g
      Find match dtb: 1
There is no valid bmp file at the given address
amlkey_init() enter!
amlkey_init() 71: already init!
[EFUSE_MSG]keynum is 8
[BL31]: tee size: 0
[KM]Error:f[key_manage_query_size]L507:key[usid] not programed yet
[KM]Error:f[key_manage_query_size]L507:key[deviceid] not programed yet
detect sadckey ....
saradc - saradc sub-system
Usage:
saradc saradc open <channel>    - open a SARADC channel
saradc close    - close the SARADC
saradc getval   - get the value in current channel
saradc test     - test the SARADC by channel-7
saradc get_in_range <min> <max> - return 0 if current value in the range of current channel
gpio: pin GPIOAO_2 (gpio 102) value is 1
Hit Enter or space or Ctrl+C key to stop autoboot -- :  0
(Re)start USB...
USB0:   USB3.0 XHCI init start
Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
** Bad device usb 0 **
** Bad device usb 1 **
** Bad device usb 2 **
** Bad device usb 3 **
card out
[sd_inand_staff_init][246], debug
emmc/sd response timeout, cmd8, status=0x1ff2800
emmc/sd response timeout, cmd55, status=0x1ff2800
emmc/sd response timeout, cmd1, status=0x1ff2800
Booting...
Unknown command 'unifykey' - try 'help'
Err imgread(L252):Fmt unsupported!genFmt 0x0 != 0x3
InUsbBurn
noSof
[MSG]mmcinfo failed!
(Re)start USB...
USB XHCI 1.00
gxl_p212_v1#
  • Author
Hi,Balbes150, I'm glad to receive your reply.
A-   My box is S905X 2GB-4bit-DDR 16GB-emmc ssv6051-wifi.
I need to setup canon printer and save the image to emmc, but I was in trouble and asked for help.
1, I  upgrade the image file Armbian_5.75_Aml-s905_Ubuntu_bionic_dev_4.19.21_desktop_20190216.img, it can save to emmc and boot from emmc.
    But it can't install and setup canon MP288 printer driver.
2, I upgrade the image file Armbian_5.37_S9xxx_Ubuntu_xenial_3.14.29_mate_20180203.img, it can install and setup canon MP288 printer driver
    But it can't save to emmc and boot from emmc.
B-  I have downloaded the armbian/build source code and successfully run install.sh, I have 3th issues:
1,  How to configure ssv6051 wifi.
2,  How to compile and package the image.
3,  How to Burn Image in Batch。
What do you mean can't install ? Write in detail what you do and what messages you receive from the system.
https://docs.armbian.com/
  • Author
root@amlogic:~# apt-get install cnijfilter-mp280series
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 cnijfilter-mp280series:amd64 : Depends: libc6:amd64 (>= 2.14) but it is not installable
                                Depends: libpng12-0:amd64 (>= 1.2.13-4) but it is not installable
                                Depends: libpopt0:amd64 (>= 1.14) but it is not installable
                                Depends: libtiff5:amd64 (>= 4.0.3) but it is not installable
                                Depends: cnijfilter-common:amd64 (>= 4.10) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
root@amlogic:~#
  • Werner locked this topic
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
