- eth0 down after fresh install of 25.5.1
Hi, I wanted to give my Odroid M1 new life by installing a fresh Armbian 25.5.1. Previously it was running on an old Odroid Ubuntu Image. After starting from SD I have no ethernet connection. The eth0 interface is DOWN. I tried using a USB3 2.5G ethernet adapter, but the new network interface also shows DOWN. I have tried Debian and Ubuntu Minimal images with the same results. What could be the cause and how do I get a working ethernet connection? Thanks Malz
Rock 5 ITX+ with two M.2 instead of M.2/SATA
Hi, thanks for your reply. In the meantime I did some (a lot) more testing and set up a armbian build environment to try things out. At first I created a patch for the current dtb and applied it to the build. I tried to figure out what to change in the current dtb, but had no luck. As soon as I go for powersave to activate ASPM I loose some of the PCIe devices. I also did some testing with "latest" Radxa Debian 12 image, which doesn't come with a special variant for the newer ITX+ board. This image comes with a 6.1 kernel and there is no problem when going to powersave for ASPM activating. That leads me to the fact that there is no special dtb needed for the ITX+ variant of the board. My guess is that the current dtb from mainline isn't perfect. It works but with activated ASPM some devices (m.2 and ethernet) will have problems. lspci -vv output shows " !!! Unknown header type 7f" for those devices. I did a decompile of the current dtb in use of the (working) radxa image and the current armbian to examine the differences to find some cause, but they are very different and my knowledge in device trees seems far to poor. It would be great to fix the ASPM issues as it reduced the power consumption of the radxa build by ~2W which means about 25% compared with deactivated ASPM consumption of ~8W.
Hi, this week my Rock 5 ITX+ board arrived and I started installing Armbian with vendor kernel (now on 6.1.99-vendor-rk35xx). This board has slightly different hardware than the original ITX. It has two M.2 M-key (2-lanes) instead of one M.2 M-key and four SATA ports. I think because of the different hardware configuration the DTB has to be changed as no SATA controller is present on the board. With the ITX DTB I am experiencing problems with not regonizing NVME disks when activating ASPM in armbianEnv.txt. I have no experience in editing DTBs or applying patches, so I need help to figure out what to do to make things work. armbianmonitor log: https://paste.next.armbian.com/asoxunogeg Thanks Thomas
Malz
