kirant400
  1. Hi, I am not able to make Radxa Camera 8M to work with Armbian_24.5.3_Radxa-zero3_bookworm_vendor_6.1.43_minimal.img and Armbian_24.5.1_Radxa-zero3_noble_vendor_6.1.43.img gst-launch-1.0 v4l2src device=/dev/video0 io-mode=4 ! videoconvert ! video/x-raw,format=NV12,width=1920,height=1080 ! jpegenc ! multifilesink location=/home/a2t/test.jpg Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error. Additional debug info: ../libs/gst/base/gstbasesrc.c(3132): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: streaming stopped, reason not-negotiated (-4) Execution ended after 0:00:00.001604801 Setting pipeline to NULL ... Freeing pipeline ... root@radxa-zero3:~# v4l2-ctl -i /dev/video0 --list-formats VIDIOC_S_INPUT: failed: Inappropriate ioctl for device ioctl: VIDIOC_ENUM_FMT Type: Video Capture Multiplanar [0]: 'UYVY' (UYVY 4:2:2) [1]: '422P' (Planar YUV 4:2:2) [2]: 'NV16' (Y/UV 4:2:2) [3]: 'NV61' (Y/VU 4:2:2) [4]: 'YM16' (Planar YUV 4:2:2 (N-C)) [5]: 'NV21' (Y/VU 4:2:0) [6]: 'NV12' (Y/UV 4:2:0) [7]: 'NM21' (Y/VU 4:2:0 (N-C)) [8]: 'NM12' (Y/UV 4:2:0 (N-C)) [9]: 'YU12' (Planar YUV 4:2:0) [10]: 'YM24' (Planar YUV 4:4:4 (N-C)) root@radxa-zero3:~# v4l2-ctl --device=/dev/video0 --all Driver Info: Driver name : rkisp_v5 Card type : rkisp_mainpath Bus info : platform:rkisp-vir0 Driver version : 2.4.0 Capabilities : 0x84201000 Video Capture Multiplanar Streaming Extended Pix Format Device Capabilities Device Caps : 0x04201000 Video Capture Multiplanar Streaming Extended Pix Format Media Driver Info: Driver name : rkisp-vir0 Model : rkisp0 Serial : Bus info : platform:rkisp-vir0 Media version : 6.1.43 Hardware revision: 0x00000000 (0) Driver version : 6.1.43 Interface Info: ID : 0x0300000e Type : V4L Video Entity Info: ID : 0x0000000d (13) Name : rkisp_mainpath Function : V4L2 I/O Pad 0x01000010 : 0: Sink Link 0x02000011: from remote pad 0x1000004 of entity 'rkisp-isp-subdev' (Unknown V4L2 Sub-Device): Data, Enabled Priority: 2 Format Video Capture Multiplanar: Width/Height : 0/0 Pixel Format : '' Field : Any Number of planes : 0 Flags : Colorspace : Default Transfer Function : Default YCbCr/HSV Encoding: Default Quantization : Default Selection Video Capture: crop, Left 0, Top 0, Width 0, Height 0, Flags: Selection Video Capture: crop_bounds, Left 0, Top 0, Width 800, Height 600, Flags: Selection Video Output: crop, Left 0, Top 0, Width 0, Height 0, Flags: Selection Video Output: crop_bounds, Left 0, Top 0, Width 800, Height 600, Flags: What should be done to get the image
