serial via USB.
the two orange pi are powered separately, the microusb (otg) port is connected to the other's usb type A port with the modified cable and it works perfectly. I cannot tell you why, but I have only experimented.
Orangepizero does not restart any more
@going reinstalled the new kernel (trunk) and thedtb you suggested via dpkg -i everything seems to work fine (docker, etc), but if from command line I use reboot at next session I can't log in via ssh ; only if I manually reboot I can log in with sshdmesg.txtsyslog.txti should still have an armbian image from a few years ago i will install that and disable updates is the 'only way i have to reuse orangepizero.🥲
- Orangepizero does not restart any more
@robertoj, on the first ssh connection it asked me to delete the previous key and I did ,then it asked me for the password which I re-entered and it let me in. As far as docker is concerned it has duned very well for a few years with portainer, minidlna,a tor relay , and deluge;managing the reserved storage it always worked then something broke , maybe due to an upgrade , and problems arose. Now I installed this old version of armbian as suggested by igor and it seems to be working fine since 24 hours.
Yesterday evening I installed Armbian_community_24.8.0-trunk.443_Orangepizero_noble_current_6.6.36.img.xz I checked the sha , installed on sd verbatim 32gb unpacked new. Installed docker, portainer and container minidlna . First startup without a hitch worked until this morning, then the strange error, some ports remain open ;now I rebooted repaired with fsck , it starts responding to ping and after a few minutes is no longer reachable. I would like to try booting via SD and put the operating system on an external HDD, if it is possible.
good morning everyone, I installed Armbian 23.02.2 on orangepizero about a year ago without ever having a problem . Today it suddenly stopped booting and I can't get it to start again and that's what I'm interested in, also possibly to recover internal docker configurations. The orangepizero is powered by a 3A power supply under UPS and properly cooled, if I use the latest release on a new SD it works perfectly, so I think it is not a hardware problem. The SD with Armbian 23.02.2 is not corrupted and I can read every part of it. Does anyone know any tricks to get it running again?
Introduction to U Boot? /Lack of fundamental understanding
@mongoose I didn't understand the problem, but if you need help here is a tutorial on the orange pi zero. https://hackaday.io/project/181169-orange-pi-zero-native-network-boot/log/196475-step-2-enable-spi-flash-and-and-write-u-boot
