badhon_raj
  1. Thanks for the suggestion regarding btrfs. I'll keep that in mind. I did try writing the image file in multiple memory card, it shows the same error. At this point I just want to make the image/memory card bootable. is that possible? Using the older backup will be useless, It will be better to just reinstall and setup everything again. I was trying to avoid that if possible. I'm not sure how I can fix the corrupted one so that it boots at least, preferably with all installed programs, so that I don't have to redo everything. If some file is corrupt, making some app not to work, I can live with that.
  2. I have a Rock64 I'm using for about 3-4 years. last month November, '24, due to a power failure issue, the Memory card got corrupted and won't boot anymore. I backed up the memory card using win32disk imager to rock64_corrupted.img now if I insert the memory card in a debian 12 machine, then I can see all files. root@debian:~# lsblk sdb 8:16 1 29.8G 0 disk └─sdb1 8:17 1 29.5G 0 part /media/user/ddc95179-99af-4380-b45b-fa41999ac3d0 root@debian:~# fdisk -l /dev/sdb Disk /dev/sdb: 29.81 GiB, 32010928128 bytes, 62521344 sectors Disk model: Mass-Storage Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0xce7a88b0 Device Boot Start End Sectors Size Id Type /dev/sdb1 32768 61896127 61863360 29.5G 83 Linux root@debian:~# cat /media/user/ddc95179-99af-4380-b45b-fa41999ac3d0/etc/os-release PRETTY_NAME="Armbian 24.2.1 bookworm" NAME="Debian GNU/Linux" VERSION_ID="12" VERSION="12 (bookworm)" VERSION_CODENAME=bookworm ID=debian HOME_URL="https://www.armbian.com" SUPPORT_URL="https://forum.armbian.com" BUG_REPORT_URL="https://www.armbian.com/bugs" ARMBIAN_PRETTY_NAME="Armbian 24.2.1 bookworm" root@debian:~# umount /media/user/ddc95179-99af-4380-b45b-fa41999ac3d0 root@debian:~# fsck.ext4 /dev/sdb1 e2fsck 1.47.0 (5-Feb-2023) /dev/sdb1: clean, 448797/1914432 files, 5384081/7732920 blocks Is it possible to fix this? Please let me know if I should provide any more info. Any help is greatly appreciated. I have a backup img file from February, '24 which works fine when written into the memory card. But that one is very old.
