Pinecube: ERROR: FDT image overlaps OS image
Decided to see how far the LLM have come along and give this another crack. Gemini 3 Flash seems to have got me a few steps forward. It had me add zswap and build a swap file while adjusting some of the U-Boot variables. /boot/armbianEnv.txt additions/changes fdt_addr_r=0x42000000 ramdisk_addr_r=0x42800000 fdt_high=0xffffffff initrd_high=0xffffffff extraargs=zswap.enabled=0 swiotlb=1024 I had to expand the filesystem to use more of the SD card then added a 512M swapfile sudo fallocate -l 512M /mnt/pinecube/swapfile sudo chmod 600 /mnt/pinecube/swapfile sudo mkswap /mnt/pinecube/swapfile It took a solid 5 or so minutes but I got booted. It's very slow but at least I got this far! Just leaving this here for anyone else that may stumble along.
- Pinecube: ERROR: FDT image overlaps OS image
It seems trying to update/upgrade got it into a partially updated state. It’s giving a /run/systemd is out of space error currently and says it cannot use/build with libc6 or something. Away from the PC and Pinecube at the moment. I will reflash my other SD card, set the memory values, and then copy all the outputs with verbosity 8 and early console enabled.
Changing release back to Armbian_community_24.11.0-trunk.273 (just happened to have it from last time I tested a while back) seems to have posted into the kernel. I'll try an update && upgrade but I'm sure it will break again like before. Here's the armbianmonitor -u if it helps in any way: https://paste.armbian.com/zutopexulu Here's the u-boot from that version if it helps. I did modify the armbianenv values with: verbosity=8 earlycon=on fdt_addr_r=0x41000000 kernel_addr_r=0x41080000 ramdisk_addr_r=0x42080000 U-Boot SPL 2024.01-armbian-2024.01-S866c-Pb2fe-H0429-Vc98b-Bda0a-R448a (Oct 10 2024 - 02:38:10 +0000) DRAM: 128 MiB Trying to boot from MMC1 ns16550_serial serial@1c28800: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 U-Boot 2024.01-armbian-2024.01-S866c-Pb2fe-H0429-Vc98b-Bda0a-R448a (Oct 10 2024 - 02:38:10 +0000) Allwinner Technology CPU: Allwinner V3s (SUN8I 1681) Model: PineCube IP Camera DRAM: 128 MiB Core: 47 devices, 20 uclasses, devicetree: separate WDT: Not starting watchdog@1c20ca0 MMC: mmc@1c0f000: 0, mmc@1c10000: 1 Loading Environment from FAT... Unable to use mmc 0:1... In: serial@1c28800 Out: serial@1c28800 Err: serial@1c28800 Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 4107 bytes read in 2 ms (2 MiB/s) ## Executing script at 41900000 U-boot loaded from SD Boot script loaded from mmc 288 bytes read in 2 ms (140.6 KiB/s) 10752455 bytes read in 446 ms (23 MiB/s) 8994176 bytes read in 374 ms (22.9 MiB/s) Found mainline kernel configuration 18875 bytes read in 5 ms (3.6 MiB/s) Working FDT set to 41000000 Failed to load '/boot/dtb/overlay/sun8i-v3s-fixup.scr' Kernel image @ 0x41080000 [ 0x000000 - 0x893d80 ] ## Loading init Ramdisk from Legacy Image at 42080000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 10752391 Bytes = 10.3 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 41000000 Booting using the fdt blob at 0x41000000 Working FDT set to 41000000 Loading Ramdisk to 423be000, end 42dff187 ... OK Loading Device Tree to 42351000, end 423bdfff ... OK Working FDT set to 42351000 Starting kernel ...
Good to hear that something was found at least! Should the last build already have it incorporated because I still needed to modify the fdt/kernel/ramdisk variables in the armbianenv in order to get the process started? But it looks like turning it to verbosity=8 and earlycon=on didn't provide any additional details sadly. U-Boot SPL 2024.01-armbian-2024.01-S866c-P7738-Ha5c2-V1f00-Bb703-R448a (Mar 16 2025 - 04:03:33 +0000) DRAM: 128 MiB Trying to boot from MMC1 ns16550_serial serial@1c28800: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 U-Boot 2024.01-armbian-2024.01-S866c-P7738-Ha5c2-V1f00-Bb703-R448a (Mar 16 2025 - 04:03:33 +0000) Allwinner Technology CPU: Allwinner V3s (SUN8I 1681) Model: PineCube IP Camera DRAM: 128 MiB Core: 47 devices, 20 uclasses, devicetree: separate WDT: Not starting watchdog@1c20ca0 MMC: mmc@1c0f000: 0, mmc@1c10000: 1 Loading Environment from FAT... Unable to use mmc 0:1... In: serial@1c28800 Out: serial@1c28800 Err: serial@1c28800 Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 5475 bytes read in 3 ms (1.7 MiB/s) ## Executing script at 41900000 U-boot loaded from SD 241 bytes read in 2 ms (117.2 KiB/s) Load fdt: /boot/dtb/sun8i-s3-pinecube.dtb 12284163 bytes read in 509 ms (23 MiB/s) 11014744 bytes read in 458 ms (22.9 MiB/s) Found mainline kernel configuration 19691 bytes read in 6 ms (3.1 MiB/s) Working FDT set to 41000000 Kernel image @ 0x41080000 [ 0x000000 - 0xa81258 ] ## Loading init Ramdisk from Legacy Image at 42080000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 12284099 Bytes = 11.7 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 41000000 Booting using the fdt blob at 0x41000000 Working FDT set to 41000000 Loading Ramdisk to 42248000, end 42dff0c3 ... OK Loading Device Tree to 421da000, end 42247fff ... OK Working FDT set to 421da000 Starting kernel ...
So I decided to modify the armbianEnv.txt with the values you provided and it has moved to "Starting kernel..." It is taking quite a while to boot. The older version seemed to take quite a while as well but this seems to be hanging possibly. I tried changing the armbianEnv.txt verbosity to 7 but it is still stuck on Starting kernel... U-Boot 2024.01-armbian-2024.01-S866c-P7738-Ha5c2-V1f00-Bb703-R448a (Mar 16 2025 - 04:03:33 +0000) Allwinner Technology CPU: Allwinner V3s (SUN8I 1681) Model: PineCube IP Camera DRAM: 128 MiB Core: 47 devices, 20 uclasses, devicetree: separate WDT: Not starting watchdog@1c20ca0 MMC: mmc@1c0f000: 0, mmc@1c10000: 1 Loading Environment from FAT... Unable to use mmc 0:1... In: serial@1c28800 Out: serial@1c28800 Err: serial@1c28800 Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 5475 bytes read in 2 ms (2.6 MiB/s) ## Executing script at 41900000 U-boot loaded from SD 227 bytes read in 1 ms (221.7 KiB/s) Load fdt: /boot/dtb/sun8i-s3-pinecube.dtb 12286995 bytes read in 509 ms (23 MiB/s) 11013984 bytes read in 456 ms (23 MiB/s) Found mainline kernel configuration 19691 bytes read in 4 ms (4.7 MiB/s) Working FDT set to 41000000 Kernel image @ 0x41080000 [ 0x000000 - 0xa80f60 ] ## Loading init Ramdisk from Legacy Image at 42080000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 12286931 Bytes = 11.7 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 41000000 Booting using the fdt blob at 0x41000000 Working FDT set to 41000000 Loading Ramdisk to 42248000, end 42dffbd3 ... OK Loading Device Tree to 421da000, end 42247fff ... OK Working FDT set to 421da000 Starting kernel ...
Yes. I noticed in past attempts when using saveenv it says it cannot write or something. I have not modified any of the files as I said earlier. This is all from a fresh install so it is whatever is generated that is currently located on the PineCube page. Also when I took an older image and updated the FDT image overlap error began as well. Error for saveenv I've seen Saving Environment to FAT... Unable to use mmc 0:1... Failed (1) armbianEnv.txt verbosity=1 bootlogo=false console=both disp_mode=1920x1080p60 fdt_addr_r=0x41900000 overlay_prefix=sun8i-v3s rootdev=UUID=7cb05da7-0b85-4547-83a2-601bab88d8dc rootfstype=ext4 boot.cmd # DO NOT EDIT THIS FILE # # Please edit /boot/armbianEnv.txt to set supported parameters # setenv load_addr "0x45000000" setenv overlay_error "false" # default values setenv verbosity "1" setenv console "both" setenv disp_mem_reserves "off" setenv disp_mode "1920x1080p60" setenv rootfstype "ext4" setenv docker_optimizations "on" setenv bootlogo "false" setenv devnum "0" setenv rootdev "/dev/mmcblk${devnum}p1" setenv earlycon "off" # Remember the default u-boot fdtfile setenv deffdt_file ${fdtfile} # Remember the default u-boot fdtdir setenv deffdt_dir "${prefix}dtb" if test "$fdtdir" = ""; then setenv fdtdir "${deffdt_dir}";fi setenv vendor "allwinner" # Print boot source itest.b *0x28 == 0x00 && echo "U-boot loaded from SD" itest.b *0x28 == 0x01 && echo "U-boot loaded from NAND" itest.b *0x28 == 0x02 && echo "U-boot loaded from eMMC or secondary SD" itest.b *0x28 == 0x03 && echo "U-boot loaded from SPI" # get PARTUUID of first partition on SD/eMMC it was loaded from # mmc 0 is always mapped to device u-boot (2016.09+) was loaded from if test "${devtype}" = "mmc"; then part uuid mmc ${devnum}:1 partuuid; setenv devnum ${mmc_bootdev} setenv rootdev "/dev/mmcblk${mmc_bootdev}p1" fi if test -e ${devtype} ${devnum} ${prefix}armbianEnv.txt; then load ${devtype} ${devnum} ${load_addr} ${prefix}armbianEnv.txt env import -t ${load_addr} ${filesize} fi # Delete the vendor's name from the fdtfile variable and record the result # after the file with the environment variables has been read if setexpr subfdt sub ${vendor}/ "" ${fdtfile};then setenv fdtfile ${subfdt} fi # In this shell, we can only check the existence of the file. # Make a check of reasonable ways to find the dtb file. # Set the true value of the paths. if test -e ${devtype} ${devnum} "${fdtdir}/${fdtfile}"; then echo "Load fdt: ${fdtdir}/${fdtfile}" else echo "The file ${fdtfile} was not found in the path ${fdtdir}" if test -e ${devtype} ${devnum} "${deffdt_dir}/${vendor}/${fdtfile}"; then setenv fdtdir "${deffdt_dir}/${vendor}" echo "Load fdt: ${fdtdir}/${fdtfile}" else if test -e ${devtype} ${devnum} "${deffdt_dir}/${vendor}/${deffdt_file}"; then setenv fdtdir "${deffdt_dir}/${vendor}" setenv fdtfile "${deffdt_file}" echo "Load fdt: ${fdtdir}/${fdtfile}" else if test -e ${devtype} ${devnum} "${deffdt_dir}/${deffdt_file}"; then setenv fdtdir "${deffdt_dir}" setenv fdtfile "${deffdt_file}" echo "Load fdt: ${fdtdir}/${fdtfile}" fi fi fi fi if test "${console}" = "display"; then setenv consoleargs "console=tty1"; fi if test "${console}" = "serial"; then setenv consoleargs "console=ttyS0,115200"; fi if test "${console}" = "both"; then setenv consoleargs "console=ttyS0,115200 console=tty1"; fi if test "${earlycon}" = "on"; then setenv consoleargs "earlycon ${consoleargs}"; fi if test "${bootlogo}" = "true"; then setenv consoleargs "splash plymouth.ignore-serial-consoles ${consoleargs}" else setenv consoleargs "splash=verbose ${consoleargs}" fi setenv bootargs "root=${rootdev} rootwait rootfstype=${rootfstype} ${consoleargs} hdmi.audio=EDID:0 disp.screen0_output_mode=${disp_mode} consoleblank=0 loglevel=${verbosity} ubootpart=${partuuid} ubootsource=${devtype} usb-storage.quirks=${usbstoragequirks} ${extraargs} ${extraboardargs}" if test "${disp_mem_reserves}" = "off"; then setenv bootargs "${bootargs} sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16" fi if test "${docker_optimizations}" = "on"; then setenv bootargs "${bootargs} cgroup_enable=memory"; fi load ${devtype} ${devnum} ${ramdisk_addr_r} ${prefix}uInitrd load ${devtype} ${devnum} ${kernel_addr_r} ${prefix}zImage if test -e ${devtype} ${devnum} "${prefix}.next"; then echo "Found mainline kernel configuration" load ${devtype} ${devnum} ${fdt_addr_r} ${fdtdir}/${fdtfile} fdt addr ${fdt_addr_r} fdt resize 65536 for overlay_file in ${overlays}; do if load ${devtype} ${devnum} ${load_addr} ${fdtdir}/overlay/${overlay_prefix}-${overlay_file}.dtbo; then echo "Applying kernel provided DT overlay ${overlay_prefix}-${overlay_file}.dtbo" fdt apply ${load_addr} || setenv overlay_error "true" fi done for overlay_file in ${user_overlays}; do if load ${devtype} ${devnum} ${load_addr} ${prefix}overlay-user/${overlay_file}.dtbo; then echo "Applying user provided DT overlay ${overlay_file}.dtbo" fdt apply ${load_addr} || setenv overlay_error "true" fi done if test "${overlay_error}" = "true"; then echo "Error applying DT overlays, restoring original DT" load ${devtype} ${devnum} ${fdt_addr_r} ${fdtdir}/${fdtfile} else if test -e ${devtype} ${devnum} ${fdtdir}/overlay/${overlay_prefix}-fixup.scr; then load ${devtype} ${devnum} ${load_addr} ${fdtdir}/overlay/${overlay_prefix}-fixup.scr echo "Applying kernel provided DT fixup script (${overlay_prefix}-fixup.scr)" source ${load_addr} fi if test -e ${devtype} ${devnum} ${prefix}fixup.scr; then load ${devtype} ${devnum} ${load_addr} ${prefix}fixup.scr echo "Applying user provided fixup script (fixup.scr)" source ${load_addr} fi fi bootz ${kernel_addr_r} ${ramdisk_addr_r} ${fdt_addr_r} else echo "Found legacy kernel configuration" load ${devtype} ${devnum} ${fdt_addr_r} ${prefix}script.bin bootz ${kernel_addr_r} ${ramdisk_addr_r} fi # Recompile with: # mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr
Looks like it is still overlapping. => run bootcmd switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 5475 bytes read in 2 ms (2.6 MiB/s) ## Executing script at 41900000 U-boot loaded from SD 176 bytes read in 2 ms (85.9 KiB/s) Load fdt: /boot/dtb/sun8i-s3-pinecube.dtb 12286995 bytes read in 509 ms (23 MiB/s) 11013984 bytes read in 456 ms (23 MiB/s) Found mainline kernel configuration 19691 bytes read in 5 ms (3.8 MiB/s) Working FDT set to 41900000 Kernel image @ 0x41080000 [ 0x000000 - 0xa80f60 ] ## Loading init Ramdisk from Legacy Image at 42080000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 12286931 Bytes = 11.7 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 41900000 Booting using the fdt blob at 0x41900000 ERROR: FDT image overlaps OS image (OS=0x41080000..0x41b00f60) SCRIPT FAILED: continuing... BootOrder not defined EFI boot manager: Cannot load any image
@laibsch since I cannot boot that doesn't seem to be a command in u-boot I can run. Reformatted the card with latest Bookworm Armbian_community_25.5.0-trunk.444_Pinecube_bookworm_current_6.12.23_minimal.img.gz @djurnyBoot and Outputs requested at the end. Let me know if you need anything else. Thanks! U-Boot 2024.01-armbian-2024.01-S866c-P7738-Ha5c2-V1f00-Bb703-R448a (Mar 16 2025 - 04:03:33 +0000) Allwinner Technology CPU: Allwinner V3s (SUN8I 1681) Model: PineCube IP Camera DRAM: 128 MiB Core: 47 devices, 20 uclasses, devicetree: separate WDT: Not starting watchdog@1c20ca0 MMC: mmc@1c0f000: 0, mmc@1c10000: 1 Loading Environment from FAT... Unable to use mmc 0:1... In: serial@1c28800 Out: serial@1c28800 Err: serial@1c28800 Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 5475 bytes read in 2 ms (2.6 MiB/s) ## Executing script at 41900000 U-boot loaded from SD 176 bytes read in 2 ms (85.9 KiB/s) Load fdt: /boot/dtb/sun8i-s3-pinecube.dtb 12286995 bytes read in 509 ms (23 MiB/s) 11013984 bytes read in 457 ms (23 MiB/s) Found mainline kernel configuration 19691 bytes read in 4 ms (4.7 MiB/s) Working FDT set to 41900000 Kernel image @ 0x41000000 [ 0x000000 - 0xa80f60 ] ## Loading init Ramdisk from Legacy Image at 41c00000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 12286931 Bytes = 11.7 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 41900000 Booting using the fdt blob at 0x41900000 ERROR: FDT image overlaps OS image (OS=0x41000000..0x41a80f60) SCRIPT FAILED: continuing... Card did not respond to voltage select! : -110 No EFI system partition No EFI system partition Failed to persist EFI variables BootOrder not defined EFI boot manager: Cannot load any image => echo $fdt_addr_r 0x41900000 => echo $kernel_addr_r 0x41000000 => echo $kernel_addr_r 0x41000000 => echo $kernel_addr_r 0x41000000 => echo $fdt_addr_r 0x41900000 => echo $kernel_addr_r 0x41000000 => echo $ramdisk_addr_r 0x41C00000 => setexpr abc 1 + 1 => echo "abc=x${abc}x" abc=x2x => fdt header magic: 0xd00dfeed totalsize: 0x6b000 (438272) off_dt_struct: 0x38 off_dt_strings: 0x457c off_mem_rsvmap: 0x28 version: 17 last_comp_version: 16 boot_cpuid_phys: 0x0 size_dt_strings: 0x76f size_dt_struct: 0x4544 number mem_rsv: 0x0 => fdt header get def totalsize => echo "def=x${def}x" def=x6b000x
Sorry to bring this back up but I'm having exact same issue on latest releases. I'm able to boot an older 21.05.1 release for the PineCube but the 25.5.0-trunk.87 and 25.5.0-trunk.444 have the same issue. Upgrading the 21.05.1 via apt update && apt upgrade broke it once again with the same overlap issue. ## Loading init Ramdisk from Legacy Image at 41b00000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 11237905 Bytes = 10.7 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 41800000 Booting using the fdt blob at 0x41800000 ERROR: FDT image overlaps OS image (OS=0x41000000..0x41a72768)
Zaf9670
