For 2/4 GB versions. Image with kernel 7.2 and uboot 26.07 Although using armbian-config the installation is copied to the NVMe drive, it should boot from the SD card (for now). Wi-Fi/BT appears to be working. SPI (mtd0) in Linux. E906 is enabled so you can test the "e906-examples" repository (I haven't tested the "hello world" example that prints via serial yet). Don't forget to connect the HDMI cable and turn on the monitor!
Hi! Sorry for the delay in replying. I just read the thread. Thanks to a message on Discord about the working 1GB version. I previously asked Igor if we should create a specific configuration for that 1GB board due to the problems with using different types of RAM. Currently, the stability of image 6.18 can be resolved with a uboot patch that you can find in the future port/bump to 7.2. https://github.com/armbian/build/pull/10587 https://github.com/armbian/build/pull/10587/changes#diff-7d199e3b644c9de298a8504c5ed9a99330f89331309413c909578a89a4ffdb19R19 In the PR, uboot is updated from 26.01 to 26.07, including the patches. Does it have functional dynamic memory detection? If not, adding cubie-a5e-1gb should only involve a few files.
- OPI 4A - Allwinner T527
Hi, I haven't posted for a while since I don't have an OrangePi 4A, just a Cubie A5E. I compiled Armbian for OrangePi 4a, kernel 6.16-rc4. No video yet, just a serial console. Can anyone test the image? https://github.com/juanesf/build/commits/Opi4A/ https://paste.armbian.com/ranagabiku https://drive.google.com/drive/folders/1dx0TApPAEjFDz24Rm22J4jgtIbJrYYHC?usp=sharing
@JamesCL Changes: git status On branch main Your branch is up to date with 'origin/main'. Changes not staged for commit: (use "git add <file>..." to update what will be committed) (use "git restore <file>..." to discard changes in working directory) modified: config/boards/radxa-cubie-a5e.conf modified: config/sources/families/sun55iw3.conf Untracked files: (use "git add <file>..." to include in what will be committed) config/boards/orangepi4a.conf patch/kernel/archive/sunxi-dev-6.12/Add-sun55iw3-OrangePi-4A.patch patch/u-boot/sunxi-dev-u-boot-a523/ you should skip the cubie board changes: config/boards/radxa-cubie-a5e.conf config/sources/families/sun55iw3.conf # # SPDX-License-Identifier: GPL-2.0 # # Copyright (c) 2013-2023 Igor Pecovnik, igor@armbian.com # # This file is a part of the Armbian Build Framework # https://github.com/armbian/build/ # enable_extension "sunxi-tools" declare -g ARCH=arm64 declare -g ATFSOURCE='https://github.com/jernejsk/arm-trusted-firmware' declare -g ATF_TARGET_MAP="PLAT=sun55i_a523 DEBUG=1 bl31;;build/sun55i_a523/debug/bl31.bin" declare -g ATFBRANCH="branch:a523" declare -g BOOTSCRIPT='boot-sun50i-next.cmd:boot.cmd' declare -g BOOTDELAY=1 declare -g BOOTSOURCE='https://github.com/jernejsk/u-boot/' declare -g BOOTPATCHDIR="sunxi-dev-${BOOTPATCHDIR:-"u-boot-a523"}" declare -g BOOTBRANCH="${BOOTBRANCH:-"branch:a523"}" declare -g BOOTENV_FILE='sunxi.txt' declare -g UBOOT_TARGET_MAP="${UBOOT_TARGET_MAP:-BINMAN_ALLOW_MISSING=1;;u-boot-sunxi-with-spl.bin}" declare -g OVERLAY_DIR="/boot/dtb/allwinner/overlay" declare -g LINUXFAMILY="sun55iw3" case "${BRANCH}" in dev) declare -g KERNELSOURCE='https://github.com/apritzel/linux' declare -g KERNELBRANCH='branch:a523-v2-WIP' declare -g KERNEL_MAJOR_MINOR="6.12" # Major and minor versions of this kernel. KERNELPATCHDIR="archive/sunxi-dev-${KERNEL_MAJOR_MINOR}" ;; esac family_tweaks() { # execute specific tweaks function if present [[ $(type -t family_tweaks_s) == function ]] && family_tweaks_s cp $SRC/packages/blobs/splash/armbian-u-boot-24.bmp $SDCARD/boot/boot.bmp } write_uboot_platform() { dd if=/dev/zero of=$2 bs=512 count=1023 seek=1 status=noxfer > /dev/null 2>&1 dd if=$1/u-boot-sunxi-with-spl.bin of=$2 bs=512 seek=256 status=noxfer > /dev/null 2>&1 } setup_write_uboot_platform() { local tmp part dev if grep -q "ubootpart" /proc/cmdline; then # mainline with new boot script tmp=$(cat /proc/cmdline) tmp="${tmp##*ubootpart=}" tmp="${tmp%% *}" [[ -n $tmp ]] && part=$(findfs PARTUUID=$tmp 2> /dev/null) [[ -n $part ]] && dev=$(lsblk -n -o PKNAME $part 2> /dev/null) [[ -n $dev ]] && DEVICE="/dev/$dev" else # legacy or old boot script tmp=$(cat /proc/cmdline) tmp="${tmp##*root=}" tmp="${tmp%% *}" [[ -n $tmp ]] && part=$(findfs $tmp 2> /dev/null) [[ -n $part ]] && dev=$(lsblk -n -o PKNAME $part 2> /dev/null) # do not try to write u-boot to USB devices [[ -n $dev && $dev == mmcblk* ]] && DEVICE="/dev/$dev" fi } config/boards/orangepi4a.conf # Allwinner Cortex-A55 octa core SoC BOARD_NAME="Orange Pi 4A" BOARDFAMILY="sun55iw3" BOARD_MAINTAINER="" BOOTCONFIG="orangepi-4a_defconfig" OVERLAY_PREFIX="sun55i-t527" #BOOT_LOGO="desktop" KERNEL_TARGET="dev" patch/kernel/archive/sunxi-dev-6.12/Add-sun55iw3-OrangePi-4A.patch From 0000000000000000000000000000000000000000 Mon Sep 17 00:00:00 2001 From: John Doe <john.doe@somewhere.on.planet> Date: Mon, 24 Feb 2025 21:37:29 -0300 Subject: Add sun55i-t527-orangepi-4a dts file Signed-off-by: John Doe <john.doe@somewhere.on.planet> --- arch/arm64/boot/dts/allwinner/Makefile | 2 + arch/arm64/boot/dts/allwinner/sun55i-t527-orangepi-4a.dts | 375 ++++++++++ 2 files changed, 377 insertions(+) diff --git a/arch/arm64/boot/dts/allwinner/Makefile b/arch/arm64/boot/dts/allwinner/Makefile index 9d5e14695af0..b409e491bf73 100644 --- a/arch/arm64/boot/dts/allwinner/Makefile +++ b/arch/arm64/boot/dts/allwinner/Makefile @@ -53,5 +53,7 @@ dtb-$(CONFIG_ARCH_SUNXI) += sun50i-h700-anbernic-rg35xx-h.dtb dtb-$(CONFIG_ARCH_SUNXI) += sun50i-h700-anbernic-rg35xx-plus.dtb dtb-$(CONFIG_ARCH_SUNXI) += sun50i-h700-anbernic-rg35xx-sp.dtb dtb-$(CONFIG_ARCH_SUNXI) += sun55i-a527-radxa-a5e.dtb dtb-$(CONFIG_ARCH_SUNXI) += sun55i-h728-x96qpro+.dtb dtb-$(CONFIG_ARCH_SUNXI) += sun55i-t527-avaota-a1.dtb +dtb-$(CONFIG_ARCH_SUNXI) += sun55i-t527-orangepi-4a.dtb + diff --git a/arch/arm64/boot/dts/allwinner/sun55i-t527-orangepi-4a.dts b/arch/arm64/boot/dts/allwinner/sun55i-t527-orangepi-4a.dts new file mode 100644 index 000000000000..06046e2555af --- /dev/null +++ b/arch/arm64/boot/dts/allwinner/sun55i-t527-orangepi-4a.dts @@ -0,0 +1,375 @@ +// SPDX-License-Identifier: (GPL-2.0-only OR MIT) +// Copyright (C) 2024 Arm Ltd. + +/dts-v1/; + +#include "sun55i-a523.dtsi" + +#include <dt-bindings/gpio/gpio.h> + +/ { + model = "OrangePi 4A"; + compatible = "xunlong,orangepi-4a", "allwinner,sun55i-t527"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + /* For now, until we have mainline components living in SRAM */ + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + /* 128 KiB reserved for Trusted Firmware-A (BL31). */ + secmon@48000000 { + reg = <0x0 0x48000000 0x0 0x20000>; + no-map; + }; + + /* 256 KiB reserved for the SCP. */ + secmon@48100000 { + reg = <0x0 0x48100000 0x0 0x40000>; + no-map; + }; + }; + + leds: gpio-leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + status = "okay"; + + status_led@0 { + gpios = <&pio 3 20 GPIO_ACTIVE_HIGH>; /* PD20 */ + label = "status_led"; + linux,default-trigger = "heartbeat"; + linux,default-trigger-delay-ms = <0>; + }; + }; + + reg_vcc5v: vcc5v { + /* board wide 5V supply from the 12V->5V regulator */ + compatible = "regulator-fixed"; + regulator-name = "vcc-5v"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + }; + + reg_exxt_vbus: exxt-vbus { + compatible = "regulator-fixed"; + regulator-name = "exxxxt-vbus"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-enable-ramp-delay = <1000>; + gpio = <&r_pio 0 8 GPIO_ACTIVE_HIGH>; + regulator-always-on; + regulator-boot-on; + enable-active-high; + }; + + reg_usb0_vbus: usb0-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb0-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-enable-ramp-delay = <1000>; + gpio = <&r_pio 0 4 GPIO_ACTIVE_HIGH>; + regulator-always-on; + regulator-boot-on; + enable-active-high; + }; + + reg_usb1_vbus: usb1-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb1-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-enable-ramp-delay = <1000>; + gpio = <&r_pio 0 12 GPIO_ACTIVE_HIGH>; + regulator-always-on; + regulator-boot-on; + enable-active-high; + }; +}; + +&mmc0 { + vmmc-supply = <®_cldo3>; + vqmmc-supply = <®_cldo1>; + cd-gpios = <&pio 5 6 (GPIO_ACTIVE_LOW | GPIO_PULL_DOWN)>; /* PF6 */ + bus-width = <4>; + max-frequency = <20000000>; + status = "okay"; +}; + +&pio { + vcc-pb-supply = <®_cldo3>; + vcc-pc-supply = <®_cldo1>; + vcc-pd-supply = <®_dcdc4>; + vcc-pe-supply = <®_dcdc4>; + vcc-pf-supply = <®_cldo3>; + vcc-pg-supply = <®_bldo1>; + vcc-ph-supply = <®_cldo3>; + vcc-pi-supply = <®_dcdc4>; + vcc-pj-supply = <®_dcdc4>; + vcc-pk-supply = <®_bldo3>; +}; + +&r_i2c0 { + status = "okay"; + + axp717: pmic@35 { + compatible = "x-powers,axp717"; + reg = <0x35>; + interrupt-controller; + #interrupt-cells = <1>; + interrupt-parent = <&nmi_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + + vin1-supply = <®_vcc5v>; + vin2-supply = <®_vcc5v>; + vin3-supply = <®_vcc5v>; + vin4-supply = <®_vcc5v>; + aldoin-supply = <®_vcc5v>; + bldoin-supply = <®_vcc5v>; + cldoin-supply = <®_vcc5v>; + + regulators { + /* Supplies the "little" cluster (1.4 GHz cores) */ + reg_dcdc1: dcdc1 { + regulator-always-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1160000>; + regulator-name = "vdd-cpu0-3"; + }; + + reg_dcdc2: dcdc2 { + regulator-always-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1160000>; + regulator-name = "vdd-gpu-sys"; + }; + + reg_dcdc3: dcdc3 { + regulator-always-on; + regulator-min-microvolt = <1160000>; + regulator-max-microvolt = <1160000>; + regulator-name = "vdd-dram"; + }; + + reg_dcdc4: dcdc4 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vdd-io"; + }; + + reg_aldo1: aldo1 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "axp2202-aldo1"; + }; + + reg_aldo2: aldo2 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "axp2202-aldo2"; + }; + + reg_aldo3: aldo3 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-pl-pm"; + }; + + reg_aldo4: aldo4 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-pll-dxco-avcc"; + }; + + reg_bldo1: bldo1 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-pg-wifi-lvds"; + }; + + reg_bldo2: bldo2 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-dram-1v8"; + }; + + reg_bldo3: bldo3 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-cvp-pk-vid1v8"; + }; + + reg_bldo4: bldo4 { + regulator-always-on; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-name = "axp2202-bldo4"; + }; + + reg_cldo1: cldo1 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-pc"; + }; + + reg_cldo2: cldo2 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-efuse"; + }; + + reg_cldo3: cldo3 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-mmc-eth-codec"; + }; + + reg_cldo4: cldo4 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "axp2202-cldo4"; + }; + + reg_cpusldo: cpusldo { + /* supplies the management core */ + regulator-always-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + regulator-name = "vdd-cpus"; + }; + }; + }; + + axp323: pmic@36 { + compatible = "x-powers,axp323"; + reg = <0x36>; + #interrupt-cells = <1>; + interrupt-controller; + interrupt-parent = <&nmi_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + status = "okay"; + + vin1-supply = <®_vcc5v>; + vin2-supply = <®_vcc5v>; + vin3-supply = <®_vcc5v>; + + regulators { + /* Supplies the "big" cluster (1.8 GHz cores) */ + reg_dcdc1_323: dcdc1 { + regulator-always-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1160000>; + regulator-name = "vdd-cpu4-7"; + }; + + reg_dcdc2_323: dcdc2 { + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-name = "axp323-dcdc2"; + }; + + reg_dcdc3_323: dcdc3 { + regulator-always-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-name = "vdd-npu"; + }; + + reg_aldo1_323: aldo1 { + regulator-name = "axp323-aldo1"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + }; + + reg_dldo1_323: dldo1 { + regulator-name = "axp323-dldo1"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + }; + }; +}; + +&r_pio { +/* + * Specifying the supply would create a circular dependency. + * + * vcc-pl-supply = <®_aldo3>; + */ + vcc-pm-supply = <®_aldo3>; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pb_pins>; + status = "okay"; +}; + +&ehci0 { + drvvbus-supply = <®_usb0_vbus>; + status = "okay"; +}; + +&ohci0 { + drvvbus-supply = <®_usb0_vbus>; + status = "okay"; +}; + +&ehci1 { + drvvbus-supply = <®_usb1_vbus>; + status = "okay"; +}; + +&ohci1 { + drvvbus-supply = <®_usb1_vbus>; + status = "okay"; +}; + +&usbphy { + status = "okay"; +}; + +&gmac1 { + phy-mode = "rgmii"; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&gmac1_pins_default>; + pinctrl-1 = <&gmac1_pins_sleep>; + aw,soc-phy25m; + tx-delay = <1>; + rx-delay = <3>; + dwmac3v3-supply = <®_cldo3>; + phy3v3-supply = <®_cldo3>; + status = "okay"; +}; + +&gmac1_phy0 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + reset-gpios = <&pio 8 15 GPIO_ACTIVE_LOW>; + reset-assert-us = <15000>; + reset-deassert-us = <100000>; +}; -- Created with Armbian build tools https://github.com/armbian/build patch/u-boot/sunxi-dev-u-boot-a523/Add-u-boot-OrangePi4A-defconfig.patch From 0000000000000000000000000000000000000000 Mon Sep 17 00:00:00 2001 From: John Doe <john.doe@somewhere.on.planet> Date: Mon, 24 Feb 2025 22:04:53 -0300 Subject: Add u-boot orangepi-4a_defconfig Signed-off-by: John Doe <john.doe@somewhere.on.planet> --- arch/arm/dts/sun55i-t527-orangepi-4a.dts | 375 ++++++++++ configs/orangepi-4a_defconfig | 26 + 2 files changed, 401 insertions(+) diff --git a/arch/arm/dts/sun55i-t527-orangepi-4a.dts b/arch/arm/dts/sun55i-t527-orangepi-4a.dts new file mode 100644 index 0000000000..06046e2555 --- /dev/null +++ b/arch/arm/dts/sun55i-t527-orangepi-4a.dts @@ -0,0 +1,375 @@ +// SPDX-License-Identifier: (GPL-2.0-only OR MIT) +// Copyright (C) 2024 Arm Ltd. + +/dts-v1/; + +#include "sun55i-a523.dtsi" + +#include <dt-bindings/gpio/gpio.h> + +/ { + model = "OrangePi 4A"; + compatible = "xunlong,orangepi-4a", "allwinner,sun55i-t527"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + /* For now, until we have mainline components living in SRAM */ + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + /* 128 KiB reserved for Trusted Firmware-A (BL31). */ + secmon@48000000 { + reg = <0x0 0x48000000 0x0 0x20000>; + no-map; + }; + + /* 256 KiB reserved for the SCP. */ + secmon@48100000 { + reg = <0x0 0x48100000 0x0 0x40000>; + no-map; + }; + }; + + leds: gpio-leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + status = "okay"; + + status_led@0 { + gpios = <&pio 3 20 GPIO_ACTIVE_HIGH>; /* PD20 */ + label = "status_led"; + linux,default-trigger = "heartbeat"; + linux,default-trigger-delay-ms = <0>; + }; + }; + + reg_vcc5v: vcc5v { + /* board wide 5V supply from the 12V->5V regulator */ + compatible = "regulator-fixed"; + regulator-name = "vcc-5v"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + }; + + reg_exxt_vbus: exxt-vbus { + compatible = "regulator-fixed"; + regulator-name = "exxxxt-vbus"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-enable-ramp-delay = <1000>; + gpio = <&r_pio 0 8 GPIO_ACTIVE_HIGH>; + regulator-always-on; + regulator-boot-on; + enable-active-high; + }; + + reg_usb0_vbus: usb0-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb0-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-enable-ramp-delay = <1000>; + gpio = <&r_pio 0 4 GPIO_ACTIVE_HIGH>; + regulator-always-on; + regulator-boot-on; + enable-active-high; + }; + + reg_usb1_vbus: usb1-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb1-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-enable-ramp-delay = <1000>; + gpio = <&r_pio 0 12 GPIO_ACTIVE_HIGH>; + regulator-always-on; + regulator-boot-on; + enable-active-high; + }; +}; + +&mmc0 { + vmmc-supply = <®_cldo3>; + vqmmc-supply = <®_cldo1>; + cd-gpios = <&pio 5 6 (GPIO_ACTIVE_LOW | GPIO_PULL_DOWN)>; /* PF6 */ + bus-width = <4>; + max-frequency = <20000000>; + status = "okay"; +}; + +&pio { + vcc-pb-supply = <®_cldo3>; + vcc-pc-supply = <®_cldo1>; + vcc-pd-supply = <®_dcdc4>; + vcc-pe-supply = <®_dcdc4>; + vcc-pf-supply = <®_cldo3>; + vcc-pg-supply = <®_bldo1>; + vcc-ph-supply = <®_cldo3>; + vcc-pi-supply = <®_dcdc4>; + vcc-pj-supply = <®_dcdc4>; + vcc-pk-supply = <®_bldo3>; +}; + +&r_i2c0 { + status = "okay"; + + axp717: pmic@35 { + compatible = "x-powers,axp717"; + reg = <0x35>; + interrupt-controller; + #interrupt-cells = <1>; + interrupt-parent = <&nmi_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + + vin1-supply = <®_vcc5v>; + vin2-supply = <®_vcc5v>; + vin3-supply = <®_vcc5v>; + vin4-supply = <®_vcc5v>; + aldoin-supply = <®_vcc5v>; + bldoin-supply = <®_vcc5v>; + cldoin-supply = <®_vcc5v>; + + regulators { + /* Supplies the "little" cluster (1.4 GHz cores) */ + reg_dcdc1: dcdc1 { + regulator-always-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1160000>; + regulator-name = "vdd-cpu0-3"; + }; + + reg_dcdc2: dcdc2 { + regulator-always-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1160000>; + regulator-name = "vdd-gpu-sys"; + }; + + reg_dcdc3: dcdc3 { + regulator-always-on; + regulator-min-microvolt = <1160000>; + regulator-max-microvolt = <1160000>; + regulator-name = "vdd-dram"; + }; + + reg_dcdc4: dcdc4 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vdd-io"; + }; + + reg_aldo1: aldo1 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "axp2202-aldo1"; + }; + + reg_aldo2: aldo2 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "axp2202-aldo2"; + }; + + reg_aldo3: aldo3 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-pl-pm"; + }; + + reg_aldo4: aldo4 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-pll-dxco-avcc"; + }; + + reg_bldo1: bldo1 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-pg-wifi-lvds"; + }; + + reg_bldo2: bldo2 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-dram-1v8"; + }; + + reg_bldo3: bldo3 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-cvp-pk-vid1v8"; + }; + + reg_bldo4: bldo4 { + regulator-always-on; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-name = "axp2202-bldo4"; + }; + + reg_cldo1: cldo1 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-pc"; + }; + + reg_cldo2: cldo2 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-efuse"; + }; + + reg_cldo3: cldo3 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-mmc-eth-codec"; + }; + + reg_cldo4: cldo4 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "axp2202-cldo4"; + }; + + reg_cpusldo: cpusldo { + /* supplies the management core */ + regulator-always-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + regulator-name = "vdd-cpus"; + }; + }; + }; + + axp323: pmic@36 { + compatible = "x-powers,axp323"; + reg = <0x36>; + #interrupt-cells = <1>; + interrupt-controller; + interrupt-parent = <&nmi_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + status = "okay"; + + vin1-supply = <®_vcc5v>; + vin2-supply = <®_vcc5v>; + vin3-supply = <®_vcc5v>; + + regulators { + /* Supplies the "big" cluster (1.8 GHz cores) */ + reg_dcdc1_323: dcdc1 { + regulator-always-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1160000>; + regulator-name = "vdd-cpu4-7"; + }; + + reg_dcdc2_323: dcdc2 { + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-name = "axp323-dcdc2"; + }; + + reg_dcdc3_323: dcdc3 { + regulator-always-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-name = "vdd-npu"; + }; + + reg_aldo1_323: aldo1 { + regulator-name = "axp323-aldo1"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + }; + + reg_dldo1_323: dldo1 { + regulator-name = "axp323-dldo1"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + }; + }; +}; + +&r_pio { +/* + * Specifying the supply would create a circular dependency. + * + * vcc-pl-supply = <®_aldo3>; + */ + vcc-pm-supply = <®_aldo3>; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pb_pins>; + status = "okay"; +}; + +&ehci0 { + drvvbus-supply = <®_usb0_vbus>; + status = "okay"; +}; + +&ohci0 { + drvvbus-supply = <®_usb0_vbus>; + status = "okay"; +}; + +&ehci1 { + drvvbus-supply = <®_usb1_vbus>; + status = "okay"; +}; + +&ohci1 { + drvvbus-supply = <®_usb1_vbus>; + status = "okay"; +}; + +&usbphy { + status = "okay"; +}; + +&gmac1 { + phy-mode = "rgmii"; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&gmac1_pins_default>; + pinctrl-1 = <&gmac1_pins_sleep>; + aw,soc-phy25m; + tx-delay = <1>; + rx-delay = <3>; + dwmac3v3-supply = <®_cldo3>; + phy3v3-supply = <®_cldo3>; + status = "okay"; +}; + +&gmac1_phy0 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + reset-gpios = <&pio 8 15 GPIO_ACTIVE_LOW>; + reset-assert-us = <15000>; + reset-deassert-us = <100000>; +}; diff --git a/configs/orangepi-4a_defconfig b/configs/orangepi-4a_defconfig new file mode 100644 index 0000000000..5a9422535c --- /dev/null +++ b/configs/orangepi-4a_defconfig @@ -0,0 +1,26 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_SUNXI_ARMV8_32BIT_BUILD=y +CONFIG_DEFAULT_DEVICE_TREE="sun55i-a527-orangepi-4a" +CONFIG_SPL=y +CONFIG_DRAM_SUNXI_DX_ODT=0x07070707 +CONFIG_DRAM_SUNXI_DX_DRI=0x0d0d0d0d +CONFIG_DRAM_SUNXI_CA_DRI=0x0e0e +CONFIG_DRAM_SUNXI_ODT_EN=0x84848484 +CONFIG_DRAM_SUNXI_TPR0=0x80808080 +CONFIG_DRAM_SUNXI_TPR1=0x06060606 +CONFIG_DRAM_SUNXI_TPR6=0x38000000 +CONFIG_DRAM_SUNXI_TPR10=0x802f3333 +CONFIG_DRAM_SUNXI_TPR11=0xc6c4c2c0 +CONFIG_DRAM_SUNXI_TPR12=0x3a373233 +CONFIG_MACH_SUN55I_A523=y +CONFIG_R_I2C_ENABLE=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_I2C=y +CONFIG_SPL_SYS_I2C_LEGACY=y +CONFIG_SYS_I2C_MVTWSI=y +CONFIG_SYS_I2C_SLAVE=0x7f +CONFIG_SYS_I2C_SPEED=400000 +CONFIG_AXP717_POWER=y +CONFIG_AXP_DCDC2_VOLT=920 +CONFIG_AXP_DCDC3_VOLT=1100 -- Created with Armbian build tools https://github.com/armbian/build patch/u-boot/sunxi-dev-u-boot-a523/Fix-uboot-sun55iw3-orangepi4a.patch From 0000000000000000000000000000000000000000 Mon Sep 17 00:00:00 2001 From: John Doe <john.doe@somewhere.on.planet> Date: Mon, 24 Feb 2025 23:29:02 -0300 Subject: Fix u-boot sun55iw3-orangepi-4a Signed-off-by: John Doe <john.doe@somewhere.on.planet> --- arch/arm/dts/sun55i-t527-orangepi-4a.dts | 21 ---------- configs/orangepi-4a_defconfig | 2 +- 2 files changed, 1 insertion(+), 22 deletions(-) diff --git a/arch/arm/dts/sun55i-t527-orangepi-4a.dts b/arch/arm/dts/sun55i-t527-orangepi-4a.dts index 06046e2555..d6e291c3b1 100644 --- a/arch/arm/dts/sun55i-t527-orangepi-4a.dts +++ b/arch/arm/dts/sun55i-t527-orangepi-4a.dts @@ -350,26 +350,5 @@ }; &usbphy { status = "okay"; }; - -&gmac1 { - phy-mode = "rgmii"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&gmac1_pins_default>; - pinctrl-1 = <&gmac1_pins_sleep>; - aw,soc-phy25m; - tx-delay = <1>; - rx-delay = <3>; - dwmac3v3-supply = <®_cldo3>; - phy3v3-supply = <®_cldo3>; - status = "okay"; -}; - -&gmac1_phy0 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <1>; - reset-gpios = <&pio 8 15 GPIO_ACTIVE_LOW>; - reset-assert-us = <15000>; - reset-deassert-us = <100000>; -}; diff --git a/configs/orangepi-4a_defconfig b/configs/orangepi-4a_defconfig index 5a9422535c..10901edfc7 100644 --- a/configs/orangepi-4a_defconfig +++ b/configs/orangepi-4a_defconfig @@ -1,9 +1,9 @@ CONFIG_ARM=y CONFIG_ARCH_SUNXI=y CONFIG_SUNXI_ARMV8_32BIT_BUILD=y -CONFIG_DEFAULT_DEVICE_TREE="sun55i-a527-orangepi-4a" +CONFIG_DEFAULT_DEVICE_TREE="sun55i-t527-orangepi-4a" CONFIG_SPL=y CONFIG_DRAM_SUNXI_DX_ODT=0x07070707 CONFIG_DRAM_SUNXI_DX_DRI=0x0d0d0d0d CONFIG_DRAM_SUNXI_CA_DRI=0x0e0e CONFIG_DRAM_SUNXI_ODT_EN=0x84848484 -- Created with Armbian build tools https://github.com/armbian/build Those were the changes I made, I don't have the board to be able to test and try to repair the compilation, if someone has the board and can make the missing changes maybe this will help. You need to clone the following repository to apply the above changes: https://github.com/juanesf/build.git
This board is very new and not mature in any way. If you use the radxa bsp kernel (debian) you have video, audio, wifi, etc... but with a modified version of the kernel with drivers and binaries closed in some cases. Mainline support is being worked on but it will take some time for the developers to add the necessary drivers and some may not arrive and even free and proprietary drivers may be mixed to make some specific features of each board work. warpme is merging Andre's work (mainline kernel) with drivers that are in the radxa cubie a5e bsp to enable network ports for example. in the sunxi kernel repo revisions of the "Display Engine 3.3" are being sent which adds video support for the new generation of allwinner (h616) soc among them. The GPU drivers for the Cubie A5e board are present in the mainline kernel, so once the graphics engine is enabled, it should be easy to enable GPU video acceleration.
@Nick A Image based on the "apritzel" kernel for a527, I have compiled the image and it works on my board. The you just to chage "dev" to "edge" and add the clean patches for the board (I will take the time to learn and send). this is very edge and has no video, ethernet, wifi, etc... @Igor is it applicable to send to the armbian/build repository? Add Radxa Cubie A5E (sun55i-a527) Armbian Radxa Cubie A5E Debian BookWorm (Image)
nano /home/juanesf91/build/config/bootscripts/extlinux label ARMBIAN kernel /vmlinuz-6.12.12-edge-sunxi fdt /dtbs/allwinner/sun55i-a527-radxa-a5e.dtb append earlycon=uart8250,mmio32,0x02500000 clk_ignore_unused console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p2 rw rootwait nano config/boards/radxa-cubie-a5e.csc BOOT_FDT_FILE="dtb/allwinner/sun55i-a527-radxa-a5e.dtb" BOOTFS_TYPE="fat" BOOTSCRIPT="extlinux" IMAGE_PARTITION_TABLE="msdos" BOOTSTART="1" BOOTSIZE="512" ROOTSTART="513" UBOOT_EXTLINUX=yes" UBOOT_EXTLINUX_ROOT=root=UUID=%%ROOT_PARTUUID%%" UBOOT_EXTLINUX_FDT="sun55i-a527-radxa-a5e.dtb" fdisk -l output/images/Armbian-unofficial_25.02.0-trunk_Radxa-cubie-a5e_bookworm_edge_6.12.12_minimal.img Disk output/images/Armbian-unofficial_25.02.0-trunk_Radxa-cubie-a5e_bookworm_edge_6.12.12_minimal.img: 1.81 GiB, 1946157056 bytes, 3801088 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0xd91fa24c Device Boot Start End Sectors Size Id Type output/images/Armbian-unofficial_25.02.0-trunk_Radxa-cubie-a5e_bookworm_edge_6.12.12_minimal.img1 8192 1056767 1048576 512M ea Linux extended boot output/images/Armbian-unofficial_25.02.0-trunk_Radxa-cubie-a5e_bookworm_edge_6.12.12_minimal.img2 1056768 3801087 2744320 1.3G 83 Linux
JuanEsf
