Tiedemate
  1. Hm, that seems not to have worked, I still get: v24.11.1 for Odroid XU4 running Armbian Linux 6.6.60-current-odroidxu4.
  2. Hi Igor, thanks for your reply! There is a boot.ini, and it states: # DO NOT EDIT THIS FILE # # Please edit /boot/armbianEnv.txt to set supported parameters # So now I just created /boot/armbianEnv.txt and added board_name=hc1 to it. I hope it's that easy? Thanks again! Björn
  3. Hi! I just flashed Armbian 24.11.1 Bookworm Minimal / IOT onto my Odroid HC1 SD-Card. The download page states: "For HC1 and HC2 we provide specially optimized config which has to be applied manually. This results in shorter boot time and lower consumption. Edit /boot/armbianEnv.txt and add: board_name=xu4 # or xu3, xu3, hc1" However there is no /boot/armbianEnv.txt. Should I just run the system as is or do I have to modify something to have it run optimally? Should I just create the file and add line? Thx! Björn
