Armbian with preinstalled Home Assistant supervised
Usually I give "rm /etc/os-release" and "ln -s /usr/lib/os-release /etc/os-release".
I also solved it with the previous command, now I'm using Armbian with preinstalled Home Assistant and I'm fine. Great job, thanks.
I followed your instructions on a clean install but the result is not changed, aa-status output is the same and Home Assistant continues to ask for Apparmor.
So on Debian doesn't work? Apparmor is required on Home Assistant, I tried also Armbian with preinstalled Home Assistant and saw that even in this version Apparmor does not work.
25.2.2 for Raspberry Pi 4 Model B running Armbian Linux 6.12.17-current-bcm2711
Without Apparmor Home Assistant is not fully functional so you need to install the module properly. I followed the instructions on this thread but Apparmor still does not work, this is the output: root@localhost:~# aa-status apparmor module is loaded. apparmor filesystem is not mounted. Does anyone know a solution to get Apparmor working on Armbian?
- Set static ip on Bookworm Minimal 24.8.0-trunk.399
TonyB
