Ethernet throughput issues on armbian (at high latency)
I'm not sure it's related to your issue, but on some pi's I've seen Ethernet bandwidth issues accumulating over uptime. It was related to only to a part of specific hardware models, so suspect might be related to either hardware or kernel/driver version/implementation. After some tests I've found that the issue affects only per TCP connection downlink bandwidth - UDP does not have limits, as well as uplink TCP, multiple downlink TCP connections bandwidth stacks linearly. The worst bw case I've seen is ~2Mbps per TCP conn. Reboot fixes the issue for a random time (briefly from a few hours to a few months). Sometimes(?) the issue disappears on its own. So far I've not found a fault-proof fix except a reboot, but changing tcp congestion algo is worth to try: # sysctl net.ipv4.tcp_available_congestion_control net.ipv4.tcp_available_congestion_control = reno bic cubic westwood highspeed hybla htcp vegas nv veno scalable lp yeah illinois bbr # sysctl net.ipv4.tcp_congestion_control net.ipv4.tcp_congestion_control = cubic # sysctl net.ipv4.tcp_congestion_control=bbr net.ipv4.tcp_congestion_control = bbr For tests you may use iperf3 varying -C/-P/-R/..., e.g.: # iperf3 -4 -f m -P 1 -i 0 -t 5 -c IPERF3_SRV_IP --bind LAN_IP -R -b 100M -u # Single connection DL UDP up to 100Mbps for 5 sec # iperf3 -4 -f m -P 1 -i 0 -c IPERF3_SRV_IP --bind LAN_IP -R -C bbr # Single TCP conn DL using BBR as a congestion algo ... # iperf3 -4 -f m -P 50 -i 0 -c IPERF3_SRV_IP --bind LAN_IP -R # 50 TCP conns DL
sunxi64: Decrease amount of (video?) reserved memory
The same case was already discussed here, but with no result: Finally found that adding `swiotlb=1` to kernel args releases 64 MB of memory: /boot/armbianEnv.txt:extraargs=... nokaslr cma=0 swiotlb=0 but not disables it completely: [ 0.000000] software IO TLB: SWIOTLB bounce buffer size roundup to 1MB Now: MemTotal: 487684 kB Alternative option `iommu=off` does not work. So it's not for graphics. This option looks reasonable for less than 4 GB RAM devices(?) If someone knows potential drawbacks, please disclose.
Is it a way to reduce the amount of reserved memory on sunxi64 devices? Trying to remove all useless for my case features (video/audio/wireless) to free up memory/resources for other tasks. The amount of total (413M) vs real (512M) memory is quite low: # grep -e Mem -e Cma /proc/meminfo MemTotal: 422416 kB MemFree: 49620 kB MemAvailable: 314396 kB CmaTotal: 0 kB CmaFree: 0 kB # dmesg | grep Memory: [ 0.000000] Memory: 407924K/524288K available (14144K kernel code, 1456K rwdata, 8700K rodata, 3072K init, 521K bss, 116364K reserved, 0K cma-reserved) # grep extraargs /boot/armbianEnv.txt extraargs=cma=0 sunxi_no_mali_mem_reserve sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 # uname -a Linux pi160 6.6.65-current-sunxi64 #1 SMP Wed Dec 11 19:13:43 +04 2024 aarch64 GNU/Linux The tricks which works for `sunxi` (e.g. `orangepizero`) does not work for `sunxi64` boards: https://linux-sunxi.org/Kernel_arguments Attempt to specify that extraargs in /boot/armbianEnv.txt have no effect (also their defaults are absent in /boot/boot.cmd, while present in orangepizero's version), except for `cma=0` with is not directly related to total available memory. Custom kernel with `CONFIG_CMA=n` also changes nothing.
vmspike
