sepp
  1. I tested Armbian 24.5.1 Noble Gnome + trunk MESA/VPU Kernel: 6.6.31, Size: 1.3GB, Release date: May 25, 2024 on my PBP (sd card). What does not work: - Sound - HDMI Monitor on PB dock Thank you
  2. Hi Referring to https://forum.armbian.com/topic/32667-usb-c-port-doesnt-work-on-pinebook-pro-after-the-latest-update-on-kernel-662/ USB -C is not working. I also tried 6.7.4-edge with no success. Looking for a solution G??gle found this: https://www.linuxquestions.org/questions/slackware-arm-108/pinebook-pro-usb-c-port-not-working-after-kernel-upgrade-4175732886/#google_vignette referring to Megi`s 6.7 kernel. The link was outdated, but the base worked and had versions 6.8 and 6.9. Tried both with a lot of success: USB-C working and the HDMI monitor output as well as Gigabit Ethernet work like a charm again. 😄 The only small issue remaining: Sound is not working (no analog or digital.) armbianmonitor: https://paste.armbian.com/mamocolodo (I had a small issue following Megi`s Readme: The board.dtb should replace rk3399-pinebook-pro.dtb in one of the existing dtb trees. I used dtb-6.7.4-edge-rockchip64.) any ideas about the sound issue are greatly appreciated. Sepp
