Armbian Install on Banana Pi M5
I've just looked and the build I use is: https://fi.mirror.armbian.de/archive/bananapim5/archive/Armbian_24.2.1_Bananapim5_jammy_current_6.6.16_xfce_desktop.img.xz Some of the builds around that time had issues with the regulatory database not being signed correctly (might not be a problem for you), this one was OK.
I think there are some problems with the latest download, I had a quick look (very quick) at Armbian_24.5.1_Bananapim5_noble_current_6.6.31_xfce_desktop and Chromium was installed but didn't work, and there were some issues with USB. I didn't investigate any further. The earlier version worked well except for some errors in dmesg - I'd try that to see if it works better for you.
Setting up an Access point
Hello, I've started a project where I'd like to setup a Bananapi M5 with two wifi adapters to use in hotel room for example. So one wifi adapter will connect to the hotel wifi, and the other will be in access point mode with dhcp for my devices to connect to. I think the proper terminology is AP-STA. So I have purchased one Comfast CF-953AX which uses the mt7921au chipset (0e8d:7961) to test in access point mode as it supports this: Supported interface modes: * managed * AP * AP/VLAN * monitor * P2P-client * P2P-GO The issue I have come across is the hostapd fails to start: nl80211: Failed to start radar detection: -22 (Invalid argument) I think I've tracked it down to the wifi region not being set: sudo iw reg get global country 00: DFS-UNSET (2402 - 2472 @ 40), (6, 20), (N/A) (2457 - 2482 @ 20), (6, 20), (N/A), AUTO-BW, PASSIVE-SCAN (2474 - 2494 @ 20), (6, 20), (N/A), NO-OFDM, PASSIVE-SCAN (5170 - 5250 @ 80), (6, 20), (N/A), AUTO-BW, PASSIVE-SCAN (5250 - 5330 @ 80), (6, 20), (0 ms), DFS, AUTO-BW, PASSIVE-SCAN (5490 - 5730 @ 160), (6, 20), (0 ms), DFS, PASSIVE-SCAN (5735 - 5835 @ 80), (6, 20), (N/A), PASSIVE-SCAN (57240 - 63720 @ 2160), (N/A, 0), (N/A) sudo iw reg reload command failed: No data available (-61) ..and you cannot set it, I think this post may explain it better than me: https://forum.odroid.com/viewtopic.php?t=44942 Is there a way to set the wifi region? Thanks
Badger
