2play
  1. As it seems no reply will be posted. Update: if I select N to the proposed location, i get the option to set, locale, timezone, country and all to be as supposed to be
  2. Dear @Werner yes I did. Something overrides it? i set to 0 the timeout(s), hidden instead menu etc For example below works ok and stated when I run the update-grub GRUB_DISABLE_OS_PROBER=true Grub shows with armbian background, no menu options and boots to first entry of the default too (original options)
  3. I have tried all known possible combos to hide the grub menu on boot but no luck I tested on the /etc/default/grub and /etc/default/grub.d/98-armbian.cfg Is there another config file Im missing that ignores above, especially later? Tried also with custom override config at boot. Any advise is welcome
  4. Hello @Igor I have installed Armbian 24.2.4 Jammy Kde-neon Kernel: 6.6.21, Size: 1.9GB, Release date: Mar 12, 2024 on a mini pc J4125 Celeron based. What I noticed that is during initial boot, when finds the timezone and asks to accept or select a diff one, i tried 2 times. I selected accept and then took minuted to complete and enter the desktop First time I killed it and second clean i waited.:-) I checked in armbian-config the locales and noticed that ALL options were checked. Which makes sense why I waited so long If this a know bug or needs to be fixed? Just wanted to bring to your attention. Rest work smooth and fast! Tx for your work
