Armbian 23.8 Bookworm eth0 missing
I've installed Armbian minimal version based on Debian Bookworm (image Armbian_community_24.8.0-trunk.495_Bananapi_bookworm_current_6.6.36_minimal.img.xz) on my Banana Pi M1. Installation went well but I can't set up static ip address in armbian config. Anytime I run armbian-config and try to set static address it hangs for a while and exits with no error code. So, I set up static ip address mapping on my router. After installation I runned apt update and apt upgrade. I've noticed that there is no eth0 interface but end0. Dmesg says that interface was renamed. root@bananapi:/usr/local/bin# dmesg | grep end0 [ 3.327770] sun7i-dwmac 1c50000.ethernet end0: renamed from eth0 [ 10.106591] sun7i-dwmac 1c50000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 10.126691] sun7i-dwmac 1c50000.ethernet end0: PHY [stmmac-0:01] driver [RTL8211E Gigabit Ethernet] (irq=POLL) [ 10.126766] sun7i-dwmac 1c50000.ethernet end0: No Safety Features support found [ 10.126781] sun7i-dwmac 1c50000.ethernet end0: RX IPC Checksum Offload disabled [ 10.126799] sun7i-dwmac 1c50000.ethernet end0: No MAC Management Counters available [ 10.126813] sun7i-dwmac 1c50000.ethernet end0: PTP not supported by HW [ 10.127714] sun7i-dwmac 1c50000.ethernet end0: configuring for phy/rgmii-id link mode [ 14.547226] sun7i-dwmac 1c50000.ethernet end0: Link is Up - 1Gbps/Full - flow control rx/tx I'm not sure if interface name causes problem with setting up static address in armbian-config. Now I'm trying to rename end0 interface to eth0.
Orange Pi Prime booting problem
I think Windows Drives Management has difficulty with understanding Linux partitions. Hopefully SD Formatter detects SD cards without assigned drive letter. It formats cards to FAT16 and then Drives Management sees that drive and allows assigning drive letter. After that I was able to test one of my Kingston cards. h2test2 output: Warning: Only 14795 of 14796 MByte tested. Test finished without errors. You can now delete the test files *.h2w or verify them again. Writing speed: 9.82 MByte/s Reading speed: 77.9 MByte/s H2testw v1.4 Not very fast but with no problems. So I used that card and burned Armbian with balena Etcher. Earlier I wad using Rufus. After all, booting stops in the same place.
I was downloading minimal/server images. This is an output from serial console: U-Boot SPL 2024.01-armbian (Feb 09 2024 - 18:57:17 +0000) DRAM: 2048 MiB Trying to boot from MMC1 and pretty the same from older armbian version from another memory card: U-Boot SPL 2023.07.02-armbian (Aug 31 2023 - 08:27:30 +0000) DRAM: 2048 MiB Trying to boot from MMC1 I have a problem with h2testw on my Windows 11 laptop. Laptop has buildin micro sd card reader that works but windows often shows memory card disk on the disks list but I cant assign drive letter. Additionaly I can't refresh the view. h2testw expects me to select drive. I also tried to use other power supply (5V 2,5A - minimal for Orange Pi Prime) but with no success.
Hi, I've bought Orange Pi Prime from the second hand. I've also bought 5V 3A power supply. It it was booting with Debian and Armbian. I was using Kingston SDHC cards. Suddenly my board stopped booting from mmc card. I also tried to boot it from Sandisk A1 class card but with no success. Do ypu think it is hardware malfunction or something else?
bolo
