kreestyahn
  1. The error disappears and the SPI1 pins' mode set back to ALT4 when only "spi1-cs0-spidev" overlay is enabled. But if only "spi-sd" or both is enabled it set them back to "OFF" and the error appears.
  2. now it looks like this:I replaced the target = <&spi1>; to target-path = </soc/spi@5011000>; because i got errors (Reference to non-existent node or label "spi1"). /dts-v1/; / { compatible = "allwinner,sun50i-h616"; fragment@0 { target-path = "/aliases"; __overlay__ { spi0 = "/soc/spi@5010000"; spi1 = "/soc/spi@5011000"; }; }; fragment@1 { target-path = "/soc/spi@5011000"; __overlay__ { spi1_pins: spi1-pins { pins = "PH6\0PH7\0PH8"; function = "spi1"; }; spi1_cs0_pin: spi1-cs0-pin { pins = "PH5"; function = "spi1"; }; }; }; fragment@2 { target-path = "/soc/spi@5011000"; __overlay__ { #address-cells = <0x01>; #size-cells = <0x00>; pinctrl-names = "default\0default"; pinctrl-0 = <&spi1_pins>, <&spi1_cs0_pin>; status = "okay"; mmc@0 { reg = <0x00>; compatible = "mmc-spi-slot"; voltage-ranges = <0xce4 0xce4>; spi-max-frequency = <0x2faf080>; status = "okay"; }; }; }; }; Now I could compile it without any error, but in /dev there is still only one mmcblk. root@orangepizero2w:allwinner/overlay # dmesg | grep -i 'spi' [ 1.415511] spi-nor spi0.0: ZB25VQ128A (16384 Kbytes) [ 24.548702] platform 5011000.spi: deferred probe pending
  3. Like this? /dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h616"; fragment@0 { target-path = "/aliases"; __overlay__ { spi0 = "/soc/spi@5010000"; spi1 = "/soc/spi@5011000"; }; }; fragment@1 { target = <&spi1>; __overlay__ { spi1_pins: spi1-pins { pins = "PH6", "PH7", "PH8"; function = "spi1"; }; spi1_cs0_pin: spi1-cs0-pin { pins = "PH5"; function = "spi1"; }; }; }; fragment@2 { target = <&spi1>; __overlay__ { #address-cells = <1>; #size-cells = <0>; pinctrl-0 = <&spi1_pins>; pinctrl-names = "default", "default"; status = "okay"; mmc@0 { reg = <0>; compatible = "mmc-spi-slot"; voltage-ranges = <3300 3300>; spi-max-frequency = <50000000>; status = "okay"; }; }; }; };
  4. I have created an sun50i-h616-spi-sd.dts: /dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h616"; fragment@0 { target = <&spi1>; __overlay__ { #address-cells = <1>; #size-cells = <0>; status = "okay"; mmc@0 { reg = <0>; compatible = "mmc-spi-slot"; voltage-ranges = <3300 3300>; spi-max-frequency = <50000000>; status = "okay"; }; }; }; }; compiled it and added into /boot/dtb/allwinner/overlay orangepiEnv.txt: verbosity=1 bootlogo=false console=both disp_mode=1920x1080p60 overlay_prefix=sun50i-h616 rootdev=UUID=6cd6cb54-48bc-4b6a-a615-2abfb7d74fe0 rootfstype=ext4 overlays=pi-i2c1 spi-sd usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u only the main SD is detected: root@orangepizero2w:/ # ls /dev/mmc* /dev/mmcblk1 /dev/mmcblk1p1 root@orangepizero2w:/ # dmesg | grep -i spi dmesg | grep -i mmc [ 1.415702] spi-nor spi0.0: ZB25VQ128A (16384 Kbytes) [ 1.451348] mmc_spi spi1.0: SD/MMC host mmc0, no WP, no poweroff, cd polling [ 1.451348] mmc_spi spi1.0: SD/MMC host mmc0, no WP, no poweroff, cd polling [ 1.482498] sunxi-mmc 4021000.mmc: allocated mmc-pwrseq [ 1.482663] sunxi-mmc 4020000.mmc: Got CD GPIO [ 1.508525] sunxi-mmc 4020000.mmc: initialized, max. request size: 16384 KB, uses new timings mode [ 1.546705] mmc1: host does not support reading read-only switch, assuming write-enable [ 1.548649] mmc1: new high speed SDHC card at address 0001 [ 1.549859] mmcblk1: mmc1:0001 EITSD 7.50 GiB [ 1.552553] mmcblk1: p1 [ 1.712888] sunxi-mmc 4021000.mmc: initialized, max. request size: 16384 KB, uses new timings mode [ 1.731008] mmc2: new high speed SDIO card at address 8800 [ 3.149516] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Quota mode: none. [ 6.629778] EXT4-fs (mmcblk1p1): re-mounted. Quota mode: none. I can't show you the physical connections because the orange pi is built into a custom board that I don't have access to right now, but the microSD module it connected to the SPI1-MOSI, -MISO, -CLK, -CS0 pins.
  5. Hello, I have connected a microSD module to the SPI1 CS0 pins Is there a way to mount an SPI device? I tried, but I got this error: mount: /mnt/sdcard: /dev/spidev1.0 is not a block device. What is the best way to easily manage files on this secondary SD card?
  6. Thanks, So I have an SD Card module connected to SPI1 (CS0) pins. root@orangepizero2w:~# dmesg | grep -i 'spi' [ 1.336073] sun50i-h616-pinctrl 300b000.pinctrl: pin-64 (5010000.spi) status -517 [ 1.336093] sun6i-spi 5010000.spi: Error applying setting, reverse things back [ 1.336368] sun50i-h616-pinctrl 300b000.pinctrl: pin-230 (5011000.spi) status -517 [ 1.336385] sun6i-spi 5011000.spi: Error applying setting, reverse things back [ 1.349503] spi-nor spi0.0: supply vdd not found, using dummy regulator [ 1.364641] spi-nor spi0.0: spi-nor-generic (16384 Kbytes) [ 234.215538] /dev/spidev1.0: Can't lookup blockdev spidev-test: root@orangepizero2w:/home/kvl/spidev-test# ./spidev_test -D /dev/spidev1.0 -v spi mode: 0x0 bits per word: 8 max speed: 500000 Hz (500 KHz) TX | FF FF FF FF FF FF 40 00 00 00 00 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 0D | ......@....▒..................▒. RX | FF FF FF FF FF FF FC 17 FF FF FF FF FF FF FF FF FF FF F0 5F FF FF FF FF FF FF FF FF FF FF FF FF | ......▒...........▒_............ armbian-config> System/Hardware: armbian-config> device tree:
  7. Yeah, I just realized that after the reinstall everything worked fine. Maybe I just messed up something before. Thank you for your help! Now I have another issue with SPI. Can I write here or should I open a new topic?
  8. Well.. there was a little problem so i reinstalled the whole OS. Currently I only modified armbianEnv.txt. I added this line: overlays:i2c0 I also installed armbian-config and found i2c0-pi in System/Hardware so I enabled it. The device tree is currently unmodified so it has default configuration. Should I remove the PI7-8 from rgmii-pins and then change the i2c0-pins to "PI8\0PI7"? It has also a i2c0-pi-pins. Which one should I modify? i2c0-pi-pins { pins = "PI5\0PI6"; function = "i2c0"; phandle = <0x56>; }; i2c0-pins { pins = "PI6\0PI7"; function = "i2c0"; phandle = <0x1e>; };
  9. Hi, How to enable i2c on PI8(SDA) and PI7(SCL)? I'm newbie in linux and not really understand what am I actually doing so I tried to make it with chatgpt but still not working. root@orangepizero2w:/# sudo i2cdetect -y 0 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- UU -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- It can't see any device, but there should be one on the 0x21. Could somebody help me out with this? dmesg | grep i2c [ 0.739582] i2c_dev: i2c /dev entries driver [ 0.739878] mv64xxx_i2c 7081400.i2c: can't get pinctrl, bus recovery not supp orted [ 0.740303] i2c 0-0036: Fixed dependency cycle(s) with /soc/pinctrl@300b000 [ 1.340117] sun50i-h616-pinctrl 300b000.pinctrl: unsupported function i2c0 on pin PI8 [ 1.340132] sun50i-h616-pinctrl 300b000.pinctrl: unsupported function i2c0 on pin PI7 [ 1.340141] mv64xxx_i2c 5002000.i2c: there is not valid maps for state defaul t [ 1.340264] sun50i-h616-pinctrl 300b000.pinctrl: unsupported function i2c0 on pin PI8 [ 1.340279] sun50i-h616-pinctrl 300b000.pinctrl: unsupported function i2c0 on pin PI7 [ 1.340287] mv64xxx_i2c 5002000.i2c: there is not valid maps for state defaul t [ 1.341370] axp20x-i2c 0-0036: AXP20x variant AXP313a found [ 1.342890] axp20x-i2c 0-0036: AXP20X driver loaded [ 269.046993] i2c i2c-2: mv64xxx: I2C bus locked, block: 1, time_left: 0 [ 271.094978] i2c i2c-2: mv64xxx: I2C bus locked, block: 1, time_left: 0 Tried to edit device tree via armbian-config (now it is probably kinda messy): armbianEnv.txt: verbosity=1 bootlogo=false console=both disp_mode=1920x1080p60 overlay_prefix=sun50i-h618 overlays=i2c0 i2c1 i2c2 i2c3 uart5 param_uart1_rtscts=1 param_uart2_rtscts=2 param_uart2_rtscts=3 param_uart2_rtscts=4 param_uart2_rtscts=5 rootdev=UUID=88b03ed8-436d-4226-bf01-975ceef8cc1b rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
