[Guide] How to get the official Orange pi 5 wifi m.2 module working in Armbian and Orange pi OS
This guide is specifically for the official orange pi 5 PCIe WiFi 6.0 Module that can be found here although it has been in and out of stock https://a.co/d/bhjoolW It uses the ap6275p chip. The guide will be split into 2 sections depending on what OS you want to use Orange Pi OS 1. install the wifi module into the m.2 slot and boot sd card with either the latest orange pi os ubuntu or debian http://www.orangepi.org/html/hardWare/computerAndMicrocontrollers/service-and-support/Orange-pi-5.html 2. edit the boot file to enable wifi by adding overlays=wifi-ap6275p to the end. Note if you already have overlays=<anything> line such as ssd-sata, delete it so it only says overlays=wifi-ap6275p sudo nano /boot/orangepiEnv.txt overlays=wifi-ap6275p Save and reboot 3. now you can search for you wifi and connect nmtui-connect Armbian OS Preface, for Armbian OS this is currently only working with the nightly build which can be found here https://github.com/armbian/build/releases/ I repeat, this will not work with the stable build of Armbian here https://www.armbian.com/orangepi-5/ as it is missing drivers but you can upgrade your stable build to nightly build 1. You first need to obtain the .dtbo file from the latest orangepi5.img, I would download the smallest img which is debian_bullseye_server http://www.orangepi.org/html/hardWare/computerAndMicrocontrollers/service-and-support/Orange-pi-5.html 2. use 7zip to first extract the Orangepi5*.img then open that .img file in 7zip further which will show 2 files named 0.bootfs.img and 1.rootfs.img 3. Go into the folder /0.bootfs.img/dtb/rockchip/overlay/ and at the end grab the file rk3588-wifi-ap6275p.dtbo 4. rename the file to rockchip-rk3588-wifi-ap6275p.dtbo and copy it to the /boot/dtb/rockchip/overlay/ directory on your orange pi sudo cp /path/to/rk3588-wifi-ap6275p.dtbo /boot/dtb/rockchip/overlay/rockchip-rk3588-wifi-ap6275p.dtbo 5. edit the boot file to enable wifi by adding overlays=wifi-ap6275p to the end. Note if you already have overlays=<anything> line such as ssd-sata, delete it so it only says overlays=wifi-ap6275p sudo nano /boot/armbianEnv.txt overlays=wifi-ap6275p Save and reboot 6. now you can search for you wifi and connect nmtui-connect
[Guide] How to boot Orange pi 5 from SATA m.2 SSD (for Orange pi OS and Armbian)
I originally posted this on reddit after seeing a lot of posts trying to use a SATA M.2 SSD and saying it wouldn't boot with replies telling them to go buy a NVME M.2 SSD which isn't necessary when the board does support SATA M.2 with flashing the correct bootloader. This guide has 3 different sections, 1 being booting with Orange pi OS and 2 being with Armbian OS Orange Pi OS Instructions Download Orange Pi OS Ubuntu or Debian from their website http://www.orangepi.org/html/hardWare/computerAndMicrocontrollers/service-and-support/Orange-pi-5.html unzip the 7z file to get the .img file and flash it to your sd card with your preferred flasher i.e balenaetcher. Once flashed put it into orange pi 5 and boot from sd card first once booted, the rest will be done in a terminal. go ahead and do your usual update sudo apt update sudo apt upgrade -y 3. then make sure to wipe your SPI of any previous bootloader (give it time to complete, you'll know it's done when you get your cursor back in terminal) sudo dd if=/dev/zero of=/dev/mtdblock0 bs=1M count=1 4. Write sata bootloader to SPI sudo dd if=/usr/share/orangepi5/rkspi_loader_sata.img of=/dev/mtdblock0 && sudo sync 5. Edit boot file on sd card to recognize sata by adding overlays line to the bottom, save then reboot sudo nano /boot/orangepiEnv.txt overlays=ssd-sata sudo reboot 6. On reboot you will still boot into SD card but now you should see "sda" (your sata SSD) show up on your list of devices when typing: lsblk 7. Put the same Orange Pi OS image you used in step 1 in any directory on your orange pi making sure it is unzipped and is in .img format. I just used the web browser in orange pi os to redownload from the website which for me put it in directory /home/orangepi/Downloads 8. Flash your downloaded .img to your sata ssd with this command (substitute with your directory to .img) sudo dd bs=1M if=/path/your/orangepi.img of=/dev/sda status=progress && sudo sync 9. Mount your ssd so you can edit the ssd’s boot file to support sata and reboot sudo mount /dev/sda1 /mnt/ sudo nano /mnt/boot/orangepiEnv.txt overlays=ssd-sata sudo umount /mnt/ && sudo sync sudo poweroff 10. Remove SDcard, turn on orange pi and it should boot orange pi OS from your M.2 sata ssd now Armbian OS Instructions Relatively same instructions with different file names write armbian .img file to your sd card with balenaetcher, I chose to use the more up to date imags from their github here https://github.com/armbian/build/releases/ make sure to unzip boot armbian from sd card, wipe spi sudo dd if=/dev/zero of=/dev/mtdblock0 bs=1M count=1 3 Download sata spi bootloader from orange github, place it on your sd card (mine is in downloads directory) and write to spi https://github.com/orangepi-xunlong/orangepi-build/blob/next/external/packages/bsp/rk3588/usr/share/orangepi5/rkspi_loader_sata.img sudo dd if=/home/pi/Downloads/rkspi_loader_sata.img of=/dev/mtdblock0 status=progress && sudo sync 4. Edit boot file to recognize sata then reboot sudo nano /boot/armbianEnv.txt overlays=opi5-sata sudo reboot 5. Once rebooted you can check sda shows up with command: lsblk 6. download the same armbian.img you used for step 1 to your orange pi making sure it's unzipped in .img format, then flash it to your ssd sudo dd bs=1M if=/path/your/armbian.img of=/dev/sda status=progress && sudo sync 7. Mount /boot/ of ssd so you can edit the ssd’s boot file to support sata and reboot sudo mount /dev/sda1 /mnt/ sudo nano /mnt/boot/armbianEnv.txt overlays=opi5-sata sudo umount /mnt/ && sudo sync sudo poweroff 8. Remove SDcard and start SBC, resize filesystem to use all available space sudo systemctl enable armbian-resize-filesystem
jng98908
