oliveryang
  1. I downloaded the lastest Armbian image for my Nanopi Neo (Armbian 23.02.2 Jammy with Linxu 5.15.93-sunxi). I then connected my WiFi dongle (D-Link DWA-131) and tried to create AP using armbian-config utility. Unfortunately, the hostapd fail to start even though the status shows "active". root@armbian:/etc# systemctl status hostapd ● hostapd.service - LSB: Advanced IEEE 802.11 management daemon Loaded: loaded (/etc/init.d/hostapd; generated) Active: active (exited) since Thu 2023-03-02 12:32:58 CST; 5s ago Docs: man:systemd-sysv-generator(8) Process: 3656 ExecStart=/etc/init.d/hostapd start (code=exited, status=0/SUCCESS) CPU: 61ms Mar 02 12:32:58 armbian systemd[1]: Starting LSB: Advanced IEEE 802.11 management daemon... Mar 02 12:32:58 armbian hostapd[3656]: * Starting advanced IEEE 802.11 management hostapd Mar 02 12:32:58 armbian hostapd[3659]: ioctl[SIOCSIWMODE]: Invalid argument Mar 02 12:32:58 armbian hostapd[3656]: ...fail! Mar 02 12:32:58 armbian systemd[1]: Started LSB: Advanced IEEE 802.11 management daemon. In the configuration file, I tried to replace the driver part from rtl871xdrv, which is the original setting by hostapd, to nl80211 with no luck. root@armbian:/etc# cat hostapd.conf # # armbian hostapd configuration example # # realtek mode # ssid=ARMBIAN interface=wlan0 hw_mode=g channel=5 #bridge=br0 driver=rtl871xdrv #driver=nl80211 I spent hours just to find out that the driver (8192eu) comes with the Armbian doesn't support ap mode. I'm pretty sure the wifi adapter itself does support ap mode as it's been using in my other boards. I have two different USB wifi adapters both with Realtek chips (8192eu and 8188u). They all have the same problem. Any suggestion on this issue? root@armbian:/etc# iwconfig wlan0 mode master Error for wireless request "Set Mode" (8B06) : SET failed on device wlan0 ; Invalid argument. root@armbian:/etc# nmcli con up Hotspot ifname wlan0 Error: Connection activation failed: Connection 'Hotspot' is not available on device wlan0 because profile is not compatible with device (the device does not support Access Point mode)
