rnsi
  1. I've got Jammy Minimal running on my EspressoBin v7 from Armbian_23.5.1_Espressobin_jammy_current_5.15.113_minimal. All seems to be working except the NICs do not auto-start with the system. Only lo starts. I have to "ip link set lan0 up" and "dhclient" each time it reboots. My /etc/network/interfaces: source /etc/network/interfaces.d/* # Network is managed by Network manager auto lo iface lo inet loopback auto lan0 allow-hotplug lan0 iface lan0 inet dhcp The NetworkManager.service is running. How do I make lan0 auto start? Thanks
  2. Hello- Just got my EspressoBin v7, trying to boot to SD using Armbian 23.02 Bullseye. Followed instructions at https://www.armbian.com/espressobin/. Board is 2GB, so I used flash-image-DDR4-2g_2cs_6-1200_750.bin. U-Boot showed CPU runs at 1200, and I confirmed "C120" on the chip. Interrupt boot process bubt flash-image-DDR4-2g_2cs_6-1200_750.bin spi usb env default -a saveenv Flashed Armbian_23.02.2_Espressobin_bullseye_current_5.15.93_minimal.img to a new SanDisk SD card with belenaEtcher and dd. Board doesn't boot, I get "Wrong image format for "source" command" then it tries to boot other devices. I've tried a second new SD card and both minimal and not minimal filesystems with the same result. Any suggestions or advice is greatly appreciated. My U-Boot output: TIM-1.0 mv_ddr-devel-g251bc63 DDR4 16b 2GB 2CS WTMI-devel-18.12.1-1d97715 WTMI: system early-init SVC REV: 5, CPU VDD voltage: 1.225V Setting clocks: CPU 1200 MHz, DDR 750 MHz CZ.NIC's Armada 3720 Secure Firmware 0b68a33-dirty (May 16 2022 17:51:06) Running on ESPRESSObin NOTICE: Booting Trusted Firmware NOTICE: BL1: v2.6(release):a921da5e NOTICE: BL1: Built : 17:55:48, May 16 2022 NOTICE: BL1: Booting BL2 NOTICE: BL2: v2.6(release):a921da5e NOTICE: BL2: Built : 17:55:48, May 16 2022 NOTICE: BL1: Booting BL31 NOTICE: BL31: v2.6(release):a921da5e NOTICE: BL31: Built : 17:55:48, May 16 2022 U-Boot 2022.04-armbian (May 16 2022 - 17:50:52 +0000) DRAM: 2 GiB Core: 38 devices, 20 uclasses, devicetree: fit WDT: Not starting watchdog@8300 Comphy chip #0: Comphy-0: USB3_HOST0 5 Gbps Comphy-1: PEX0 5 Gbps Comphy-2: SATA0 6 Gbps SATA link 0 timeout. AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode flags: ncq led only pmp fbss pio slum part sxs PCIe: Link down MMC: sdhci@d0000: 0, sdhci@d8000: 1 Loading Environment from SPIFlash... SF: Detected mx25u3235f with page size 256 Bytes, erase size 4 KiB, total 4 MiB OK Model: Globalscale Marvell ESPRESSOBin Board Net: eth0: ethernet@30000 Hit any key to stop autoboot: 0 MMC Device 1 not found no mmc device at slot 1 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr load - load binary file from a filesystem Usage: load <interface> [<dev[:part]> [<addr> [<filename> [bytes [pos]]]]] - Load binary file 'filename' from partition 'part' on device type 'interface' instance 'dev' to address 'addr' in memory. 'bytes' gives the size to load in bytes. If 'bytes' is 0 or omitted, the file is read until the end. 'pos' gives the file byte position to start reading from. If 'pos' is 0 or omitted, the file is read from the start. ## Executing script at 06000000 Wrong image format for "source" command SCRIPT FAILED: continuing... libfdt fdt_check_header(): FDT_ERR_BADMAGIC Scanning disk sdhci@d0000.blk... Found 2 disks No EFI system partition ERROR: invalid device tree starting USB... Bus usb@58000: Register 2000104 NbrPorts 2 Starting the controller USB XHCI 1.00 Bus usb@5e000: USB EHCI 1.00 scanning bus usb@58000 for devices... 1 USB Device(s) found scanning bus usb@5e000 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Device 0: unknown device scanning bus for devices... Device 0: unknown device (NULL udevice *): mvneta_setup_txqs: can't create txq=0 BOOTP broadcast 1 timeout: packet not sent BOOTP broadcast 2 timeout: packet not sent BOOTP broadcast 3 timeout: packet not sent My printenv: => printenv boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr} boot_efi_binary=load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} efi/boot/bootaa64.efi; if fdt addr ${fdt_addr_r}; then bootefi ${kei boot_efi_bootmgr=if fdt addr ${fdt_addr_r}; then bootefi bootmgr ${fdt_addr_r};else bootefi bootmgr;fi boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}${boot_syslinux_conf} boot_net_usb_start=usb start boot_pci_enum=pci enum boot_prefixes=/ /boot/ boot_script_dhcp=boot.scr.uimg boot_scripts=boot.scr.uimg boot.scr boot_syslinux_conf=extlinux/extlinux.conf boot_targets=mmc1 mmc0 usb0 scsi0 pxe dhcp bootcmd=run distro_bootcmd bootcmd_dhcp=devtype=dhcp; run boot_net_usb_start; run boot_pci_enum; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;se; bootcmd_mmc0=devnum=0; run mmc_boot bootcmd_mmc1=devnum=1; run mmc_boot bootcmd_pxe=run boot_net_usb_start; run boot_pci_enum; dhcp; if pxe get; then pxe boot; fi bootcmd_scsi0=devnum=0; run scsi_boot bootcmd_usb0=devnum=0; run usb_boot bootfstype=ext4 criptaddr=0x6d00000 distro_bootcmd=scsi_need_init=; setenv nvme_need_init; for target in ${boot_targets}; do run bootcmd_${target}; done efi_dtb_prefixes=/ /dtb/ /dtb/current/ eth1addr=00:51:82:11:22:01 eth2addr=00:51:82:11:22:02 eth3addr=00:51:82:11:22:03 ethact=ethernet@30000 ethaddr=00:51:82:11:22:00 fdt_addr=0x6f00000 fdt_addr_r=0x6f00000 fdtcontroladdr=7fadcf40 fdtfile=marvell/armada-3720-espressobin-v7.dtb kernel_addr=0x7000000 kernel_addr_r=0x7000000 load_efi_dtb=load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} ${prefix}${efi_fdtfile} mmc_boot=if mmc dev ${devnum}; then devtype=mmc; run scan_dev_for_boot_part; fi nvme_boot=run boot_pci_enum; run nvme_init; if nvme dev ${devnum}; then devtype=nvme; run scan_dev_for_boot_part; fi nvme_init=if ${nvme_need_init}; then setenv nvme_need_init false; nvme scan; fi pxefile_addr_r=0x6e00000 ramdisk_addr_r=0xa000000 sata_boot=if sata dev ${devnum}; then devtype=sata; run scan_dev_for_boot_part; fi scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run sca; scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devpt scan_dev_for_efi=setenv efi_fdtfile ${fdtfile}; for prefix in ${efi_dtb_prefixes}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefixe scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${boot_syslinux_conf}; then echo Found ${prefix}${boot_syslinuxi scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Be scsi_boot=run boot_pci_enum; run scsi_init; if scsi dev ${devnum}; then devtype=scsi; run scan_dev_for_boot_part; fi scsi_init=if ${scsi_need_init}; then scsi_need_init=false; scsi scan; fi stderr=serial@12000 stdin=serial@12000 stdout=serial@12000 usb_boot=usb start; if usb dev ${devnum}; then devtype=usb; run scan_dev_for_boot_part; fi ver=U-Boot 2022.04-armbian (May 16 2022 - 17:50:52 +0000) Environment size: 4408/65532 bytes
