- Need Kernel source for linux-image-current-sunxi64 6.12.20
This 3rd party module needs both kernel headers and kernel source. The Makefile bundled with the code applies patches to an existing kernel module source code and compiles it. I ran the build script on a separate debian vm and created a tarball of the source tree. i will try to transfer it to the opi later today.
I set the version in userpatches/lib.config , then executed this: ./compile.sh BOARD=orangepizero2 BRANCH=current kernel-config KERNEL_BTF=no KERNEL_GIT=full and when the kernel menu came up, just exited to shell. Is this the kernel source directory I can point the compiler script of the module ? /build/cache/sources/linux-kernel-worktree/6.12__sunxi64__arm64$ ls arch COPYING defconfig fs io_uring Kconfig LICENSES mm rust security usr block CREDITS Documentation include ipc kernel MAINTAINERS net samples sound virt certs crypto drivers init Kbuild lib Makefile README scripts tools
Hi, I need linux kernel source to compile a custom module. The one I downloaded from kernel.org did not work, got module format error, indicating the kernel is different. i did not have this problem compiling the same module for Armbian lepotato (amlogic) Where do I get the kernel source for my Orangepi Zero 2? Linux orangepizero2 6.12.20-current-sunxi64 #1 SMP Sat Mar 22 19:54:28 UTC 2025 aarch64 GNU/Linux linux-headers-current-sunxi64/bookworm,now 25.2.3 arm64 [installed] Armbian Linux current headers 6.12.20-current-sunxi64 linux-image-current-sunxi64/bookworm,now 25.2.3 arm64 [installed] Armbian Linux current kernel image 6.12.20-current-sunxi64
- Problem apt upgrade: unmeet dependencies: Depends: base-files (>= 24.5.1) but 11.1+deb11u10 is to be installed.
SOLVED: sshd ignores ListenAddress (due to ssh.socket service)
Investigating the "TriggeredBy: ● ssh.socket" line on this machine, I found a Ubuntu article and disabled ssh.socket service. This appears to be present in armbian debian release only. A Google search for "bookworm ssh.socket" only results with another armbian user reporting it on a community build version of another board.
Using Orange Pi zero 2 Debian bookworm minimal 24.5.1 image , I have disabled Network manager and enabled ifupdown service with static IP configuration. Linux orangepizero2 6.6.31-current-sunxi64 #1 SMP Fri May 17 10:02:40 UTC 2024 aarch64 GNU/Linux Trying to restrict ssh to listen on IP assigned to end0 only, but it is ignoring the ListenAddress 192.168.8.1:22 directive. It listens on all interfaces, which I do not want. sudo service ssh status ● ssh.service - OpenBSD Secure Shell server Loaded: loaded (/lib/systemd/system/ssh.service; disabled; preset: enabled) Active: active (running) since Thu 2024-05-30 16:10:42 UTC; 22s ago TriggeredBy: ● ssh.socket Docs: man:sshd(8) man:sshd_config(5) Process: 1362 ExecStartPre=/usr/sbin/sshd -t (code=exited, status=0/SUCCESS) Main PID: 1363 (sshd) Tasks: 1 (limit: 932) Memory: 1.3M CPU: 231ms CGroup: /system.slice/ssh.service └─1363 "sshd: /usr/sbin/sshd -D [listener] 0 of 10-100 startups" May 30 16:10:41 orangepizero2 systemd[1]: Starting ssh.service - OpenBSD Secure Shell server... May 30 16:10:42 orangepizero2 sshd[1363]: debug3: already daemonized May 30 16:10:42 orangepizero2 sshd[1363]: debug3: oom_adjust_setup May 30 16:10:42 orangepizero2 systemd[1]: Started ssh.service - OpenBSD Secure Shell server. May 30 16:10:42 orangepizero2 sshd[1363]: debug1: Set /proc/self/oom_score_adj from 0 to -1000 May 30 16:10:42 orangepizero2 sshd[1363]: debug2: fd 3 setting O_NONBLOCK May 30 16:10:42 orangepizero2 sshd[1363]: Server listening on :: port 22.
- 64 MB less total memory on 24.2.1
I have flashed the last 23.8 bookworm lite image to my lepotato 1GB model, and it launched with 927 MB total memory. running apt update ; apt upgrade ; reboot it drops to 862M How can I reclaim the remaining memory? This is mostly a headless server i do not need any GPU. just basic hdmi output for troubleshooting purposes. before: Welcome to Armbian 23.8.1 Bookworm with Linux 6.1.50-current-meson64 System load: 8% Up time: 4 min Memory usage: 13% of 927M IP: CPU temp: 48°C Usage of /: 4% of 29G After: Welcome to Armbian 24.2.1 Bookworm with Linux 6.6.16-current-meson64 System load: 19% Up time: 1 min Memory usage: 13% of 862M IP:
ovacikar
