Slycat34
  1. Been having an issue where my idle temps are >60C The fan will spin for maybe a second or two and then turn off for 10-20 seconds Checking /sys/class/hwmon/hwmon2/pwm1 and it is set to 0 even though my MINPWM is set to 90 Even if I manually tee 90 to pwm1 it will eventually reset to 0 even with fancontrol turned off So something resetting without my input... fan1_input does read fan speed & pwm1_enabled is set to 1 lsof & auditd do not have any info as to what is overwriting the file Only way I can get the fan to stay on is to loop the tee command for a few seconds and then it is on that one speed Turning fancontrol back on works for a while and changes speed as expected but eventually pwm1 goes back to 0 I found that when pwm1 is between 90-125 it does runs fine but once higher than 125 it resets Then tried 125 as minimum and the working range becomes 125-160 before reset Then tried 170 as minimum and the working range becomes 175-220 before reset Could the fan be dying and the voltage/load send a signal to the kernel to say "shut down fan"? fancontrol INTERVAL= 10 DEVPATH= hwmon0=devices/virtual/thermal/thermal_zone0 hwmon2=devices/platform/pwm-fan DEVNAME= hwmon0=cpu_thermal hwmon2=pwmfan FCTEMPS=hwmon2/pwm1=hwmon0/temp1_input FCFANS=hwmon2/pwm1=hwmon2/fan1_input MINTEMP=hwmon2/pwm1=54 MAXTEMP=hwmon2/pwm1=65 MINSTART=hwmon2/pwm1=90 MINSTOP=hwmon2/pwm1=110 MINPWM=hwmon2/pwm1=90 MAXPWM=hwmon2/pwm1=240 tee command to force fan spin (only way to avoid resetting to zero), ctrl+c after a few seconds while true; do echo 90 | sudo tee /sys/class/hwmon/hwmon2/pwm1; done
