obiwantoby
  1. Using the latest 6.1.75-vendor-rk35xx ls -l /dev | grep -E "mpp|rga|dri|dma_heap" drwxr-xr-x 2 root root 80 Dec 31 1969 dma_heap drwxr-xr-x 3 root root 140 Nov 7 09:38 dri crw------- 1 root root 241, 0 Nov 7 09:38 mpp_service crw------- 1 root root 10, 122 Nov 7 09:38 rga I am having some issues, very similar to https://forum.radxa.com/t/opencl-fails-with-failed-creating-base-context-during-opening-of-kernel-driver-on-reboots-for-rockchip-rk3558-orange-pi-5-plus/21558. That is when I install the OpenCL extensions, it seems to work fine, but upon reboot the system is non responsive. I am following instructions for that that libmali https://github.com/tsukumijima/libmali-rockchip/releases/download/v1.9-1-2d267b0/libmali-valhall-g610-g13p0-gbm_1.9-1_arm64.deb For the 6.1 LTS kernel on Ubuntu-Rockchip & Armbian and the legacy 5.10 LTS kernel, install v1.9-1-2d267b0. For the 6.1 LTS kernel on other SBC vendor-made distros, install v1.9-1-55611b0. ocker exec -it jellyfin /usr/lib/jellyfin-ffmpeg/ffmpeg -v debug -init_hw_device rkmpp=rk -init_hw_device opencl=ocl@rk ffmpeg version 7.0.2-Jellyfin Copyright (c) 2000-2024 the FFmpeg developers built with gcc 12 (Debian 12.2.0-14) configuration: --prefix=/usr/lib/jellyfin-ffmpeg --target-os=linux --extra-version=Jellyfin --disable-doc --disable-ffplay --disable-ptx-compression --disable-static --disable-libxcb --disable-sdl2 --disable-xlib --enable-lto=auto --enable-gpl --enable-version3 --enable-shared --enable-gmp --enable-gnutls --enable-chromaprint --enable-opencl --enable-libdrm --enable-libxml2 --enable-libass --enable-libfreetype --enable-libfribidi --enable-libfontconfig --enable-libharfbuzz --enable-libbluray --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libopenmpt --enable-libdav1d --enable-libsvtav1 --enable-libwebp --enable-libvpx --enable-libx264 --enable-libx265 --enable-libzvbi --enable-libzimg --enable-libfdk-aac --arch=arm64 --cross-prefix=/usr/bin/aarch64-linux-gnu- --toolchain=hardened --enable-cross-compile --enable-rkmpp --enable-rkrga libavutil 59. 8.100 / 59. 8.100 libavcodec 61. 3.100 / 61. 3.100 libavformat 61. 1.100 / 61. 1.100 libavdevice 61. 1.100 / 61. 1.100 libavfilter 10. 1.100 / 10. 1.100 libswscale 8. 1.100 / 8. 1.100 libswresample 5. 1.100 / 5. 1.100 libpostproc 58. 1.100 / 58. 1.100 Splitting the commandline. Reading option '-v' ... matched as option 'v' (set logging level) with argument 'debug'. Reading option '-init_hw_device' ... matched as option 'init_hw_device' (initialise hardware device) with argument 'rkmpp=rk'. Reading option '-init_hw_device' ... matched as option 'init_hw_device' (initialise hardware device) with argument 'opencl=ocl@rk'. Finished splitting the commandline. Parsing a group of options: global . Applying option v (set logging level) with argument debug. Applying option init_hw_device (initialise hardware device) with argument rkmpp=rk. Applying option init_hw_device (initialise hardware device) with argument opencl=ocl@rk. arm_release_ver: g13p0-01eac0, rk_so_ver: 10 Failed creating base context during opening of kernel driver. Kernel module may not have been loaded [AVHWDeviceContext @ 0xaaab04dcb0d0] 1 OpenCL platforms found. [AVHWDeviceContext @ 0xaaab04dcb0d0] 1 OpenCL devices found on platform "ARM Platform". arm_release_ver: g13p0-01eac0, rk_so_ver: 10 Failed creating base context during opening of kernel driver. Kernel module may not have been loaded [AVHWDeviceContext @ 0xaaab04dcb0d0] 0.0: ARM Platform / Unknown Device Any idea what's up?
  2. I have to say the latest ./compile.sh with 6.8.0-rc1-edge-rockchip-rk3588 seems to be operating great. For some reason the benchmarks have increased dramatically from 5.10-legacy. Ping times are a big lower overall too on average - unsure if the big.LITTLE scheduling improvements are contributing - but in ARM those should have been fairly mature, not like the Adler Lake e core changes. Either way I am welcoming the change. https://pibenchmarks.com/benchmark/78720/ 19,000 --> 32,000 Category Test Result HDParm Disk Read 376.81 MB/sec HDParm Cached Disk Read 386.25 MB/sec DD Disk Write 270 MB/s FIO 4k random read 86050 IOPS (344201 KB/s) FIO 4k random write 46972 IOPS (187889 KB/s) IOZone 4k read 172508 KB/s IOZone 4k write 131029 KB/s IOZone 4k random read 69041 KB/s IOZone 4k random write 159514 KB/s Score: 32652
