Peter Gregory
  1. I'm using image Armbian_23.8.3_Orangepizero2_bookworm_current_6.1.53 I'm building a DTS overlay for a SPI Touchscreen and every pin I try to use is showing this error: [ 1.441808] sun50i-h616-pinctrl 300b000.pinctrl: pin PC11 already requested by 5011000.spi; cannot claim for 300b000.pinctrl:75 [ 1.441817] sun50i-h616-pinctrl 300b000.pinctrl: pin-75 (300b000.pinctrl:75) status -22 [ 1.441829] sun6i-spi 5011000.spi: cannot register SPI master I'm trying to configure my touchscreen dts to use the SPI1.0 & SPI1.1. However, the pins exposed on the headers are all allocated for device use under 300b000.pinctrl. How do you allocate header pins for another use? I need 5 pins + SPI1 for the touchscreen to work. My dts /dts-v1/; /plugin/; / { compatible = "allwinner,sun8i-h3"; fragment@0 { target = <&pio>; __overlay__ { spi1_cs1: spi1_cs1 { pins = "PC11"; function = "gpio_out"; output-high; }; opiz_display_pins: opiz_display_pins { pins = "PC9", "PC6", "PC5"; function = "gpio_out"; }; ads7846_pins: ads7846_pins { pins = "PH6"; function = "irq"; }; }; }; fragment@1 { target = <&spi1>; __overlay__ { #address-cells = <1>; #size-cells = <0>; status = "okay"; pinctrl-1 = <&spi1_cs1>; pinctrl-names = "default", "default"; cs-gpios= <0>, <&pio 2 11 0>; /* PH9 PC11 */ opizdisplay: opiz-display@0 { reg = <0>; /* Chip Select 0 */ compatible = "ilitek,ili9341"; spi-max-frequency = <16000000>; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&opiz_display_pins>; rotate = <90>; bgr = <0>; fps = <10>; buswidth = <8>; dc-gpios = <&pio 2 6 0>; /* PC6 */ reset-gpios = <&pio 2 9 1 >; /* PC9 */ led-gpios=<&pio 2 5 0>; /* PC5 */ debug=<0>; }; ads7846: ads7846@1 { reg = <1>; /* Chip Select 1 */ compatible = "ti,ads7846"; spi-max-frequency = <500000>; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&ads7846_pins>; interrupt-parent = <&pio>; interrupts = <7 6 2>; /* PH6 IRQ_TYPE_EDGE_FALLING */ pendown-gpio = <&pio 7 6 0>; /* PH6 */ /* driver defaults, optional */ ti,x-min = /bits/ 16 <0>; ti,y-min = /bits/ 16 <0>; ti,x-max = /bits/ 16 <0x0FFF>; ti,y-max = /bits/ 16 <0x0FFF>; ti,pressure-min = /bits/ 16 <0>; ti,pressure-max = /bits/ 16 <0xFFFF>; ti,x-plate-ohms = /bits/ 16 <400>; }; }; }; };
  2. I'm trying to get a HDMI LCD touchscreen working. The pinout is compatible with Orange PI PC except the SPI CS pin is on pin 26 (WPI 11) instead of pin 24 (WPI 10). Is there an easy way to move the SPI CS pin to another GPIO pin? Also, I'm not sure how to properly configure the pen down interrupt pin for pin 22 (WPI 6) So far, I've got the following working: Image: Orangepipc_2.0.8_debian_buster_desktop_linux5.4.65.7z Touchscreen: 3.5 Inch HD HDMI USB LCD Touch Screen 3.5" Display Module 480×320 1920x1080 for Raspberry Pi 3rd 4th Generation 4B/3B+/3B/2B orangepiEnv.txt: overlays=spi-add-cs1 spi-spidev param_spidev_spi_bus=0 param_spidev_spi_cs=0 Luckily, the kernel headers are loaded, so Makefile works. mkdir ds7846 cd ds7846 wget https://sourceforge.net/p/openipmi/linux-ipmi/ci/master/tree/drivers/input/touchscreen/ads7846.c?format=raw mv ads7846.c?format=raw ads7846.c nano Makefile: obj-m := ads7846.o KDIR := /lib/modules/$(shell uname -r)/build PWD := $(shell pwd) all: $(MAKE) -C $(KDIR) M=$(PWD) modules clean: $(MAKE) -C $(KDIR) M=$(PWD) clean install: $(MAKE) -C $(KDIR) M=$(PWD) modules_install make make install depmod cd .. git clone https://github.com/notro/fbtft_tools/ cd fbtft_tools/ads7846_device make make install depmod cd .. sudo nano /etc/modules-load.d/99-ads7846.conf ads7846 ads7846_device sudo nano /etc/modprobe.d/ads7846_device.conf options ads7846_device model=7846 verbose=2 cs=0 gpio_pendown=1 keep_vref_on=1 swap_xy=1 pressure_max=255 x_plate_ohms=60 x_min=200 x_max=3900 y_min=200 y_max=3900 after reboot, the SPI device is there and the touch driver attaches to the port. [ 7.124454] ads7846_device: loading out-of-tree module taints kernel. [ 7.125336] ads7846_device: ads7846_device_init() [ 7.125343] ads7846_device: SPI devices registered: [ 7.125354] ads7846_device: spidev spi0.0 1000kHz 8 bits mode=0x00 [ 7.125357] ads7846_device: [ 7.125366] ads7846_device: Settings: [ 7.125369] ads7846_device: model = 7846 [ 7.125372] ads7846_device: gpio_pendown = 1 [ 7.125375] ads7846_device: swap_xy = 1 [ 7.125378] ads7846_device: x_min = 200 [ 7.125380] ads7846_device: x_max = 3900 [ 7.125383] ads7846_device: y_min = 200 [ 7.125386] ads7846_device: y_max = 3900 [ 7.125388] ads7846_device: x_plate_ohms = 60 [ 7.125391] ads7846_device: pressure_min = 0 [ 7.125393] ads7846_device: pressure_max = 255 [ 7.125396] ads7846_device: keep_vref_on = 1 [ 7.125398] ads7846_device: vref_delay_usecs = 0 [ 7.125401] ads7846_device: vref_mv = 0 [ 7.125403] ads7846_device: settle_delay_usecs = 0 [ 7.125406] ads7846_device: penirq_recheck_delay_usecs = 0 [ 7.125409] ads7846_device: y_plate_ohms = 0 [ 7.125411] ads7846_device: debounce_max = 0 [ 7.125414] ads7846_device: debounce_tol = 0 [ 7.125416] ads7846_device: debounce_rep = 0 [ 7.125425] ads7846_device: Deleting spi0.0 [ 7.126442] ads7846 spi0.0: spi0.0 supply vcc not found, using dummy regulator [ 7.144047] ads7846 spi0.0: touchscreen, irq 65 [ 7.144980] input: ADS7846 Touchscreen as /devices/platform/soc/1c68000.spi/spi_master/spi0/spi0.0/input/input1 [ 7.145055] ads7846_device: SPI devices registered: [ 7.145063] ads7846_device: ads7846 spi0.0 2000kHz 8 bits mode=0x00 [ 7.145066] ads7846_device: Of course, no touch events are detected. Anyone else have any luck getting this to work? I'm not familiar with changing the device tee to move GPIO pins, is there a configuration option for the spi_add_cs1?
  3. I got my 320x240 ILI9341 touchscreen to work with the image from the OrangePI site: Armbian_23.5.2_Orangepizero2_bookworm_legacy_4.9.318_minimal The display is one I bought from Amazon Hosyond 2.8 Inches TFT LCD Touch Screen Shield Display Module 320x240 SPI Serial ILI9341 with Touch Pen Compatible with Arduino R3/Mega2560 Development Board This document was very helpful getting the display set up on the OPZero 2: https://tienda.tettsa.gt/wp-content/uploads/2022/08/OrangePi_Zero2_H616_User-manual_v3.7.pdf I still don't have the touch part working. If anyone has success getting 2 selects working with SPI1 on OPZero2 and touch working, let me know. The basic steps to getting the SPI LCD to work are: 1) wire up the display to the OPZero2 2.8 Inch TFT SPI 240x320 => OPZero2 1 - VCC => (1) 3.3v 2 - GND => (6) Gnd 3 - CS => (24) Spi1 CS 4 - RESET => (7) GPIO 6 5 - DC => (11) GPIO 1 6 - SDI (MOSI) => (19) Spi1 MOSI 7 - SCLK => (23) Spi1 CLK 8 - LED => (13) GPIO 0 9 - SDO (MISO) => (21) Spi1 MISO 10 - T_CLK 11 - T_CS 12 - T_DIN 13 - T_DO 14 - T_IRQ 2) Install Armbian_23.5.2_Orangepizero2_bookworm_legacy_4.9.318_minimal - must be legacy kernel to work 4.9 is OK 3) sudo apt install fbi kbd armbian-config 4) sudo armbian-config set up desktop now to make the LCD work and start on boot 5) sudo nano /boot/armbianEnv.txt overlays=spi-spidev param_spidev_spi_bus=1 param_spidev_spi_cs=1 extraargs=fbcon=map:1 6) sudo nano /etc/modules-load.d/fbtft.conf fbtft fbtft_device 7) sudo nano etc/modprobe.d/fbtft.conf options fbtft_device custom name=fb_ili9341 gpios=dc:70,reset:73,led:69 speed=16000000 busnum=1 cs=1 bgr=1 txtbuflen-32768 fps=10 rotate=90 😎 sudo dpkg-reconfigure console-setup select UTF-8 select Guess optimal character set select terminus select 6/12 9) sudo nano /usr/share/X11/xorg.conf.d/99-fbdev.conf Section "Device" Identifier "myfb" Driver "fbdev" Option "fbdev" "/dev/fb1" EndSection Now when it boots it should boot to the SPI LCD Display
