rolsch
  1. I think the onboard fan is not being controlled correctly. root@rock5b01:~# dmesg | grep -i fan [ 6.577344] pwm-fan pwm-fan: Looking up fan-supply from device tree [ 6.577352] pwm-fan pwm-fan: Looking up fan-supply property in node /pwm-fan failed [ 6.581563] thermal_sys: Failed to bind 'soc-thermal' with 'pwm-fan': -22 [ 6.581571] thermal_sys: Failed to bind 'soc-thermal' with 'pwm-fan': -22 [ 6.581574] thermal_sys: Failed to bind 'soc-thermal' with 'pwm-fan': -22 [ 6.581577] thermal_sys: Failed to bind 'soc-thermal' with 'pwm-fan': -22 Running: Armbian v25.11.2 for Rock 5B running Armbian Linux 6.1.115-vendor-rk35xx
  2. Hi, i think the rpm setting-step's of the onboard fan is to low. - how can this be adjusted? SBC: Rock5b
  3. ...or maybe an r8169 driver problem under heavy load dmesg -w | grep -i r8169 [ 5.072779] r8169 0004:41:00.0: enabling device (0000 -> 0003) [ 5.115535] r8169 0004:41:00.0 eth0: RTL8125B, 00:e0:4c:03:00:fc, XID 641, IRQ 166 [ 5.115550] r8169 0004:41:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko] [ 6.328634] RTL8226B_RTL8221B 2.5Gbps PHY r8169-4-4100:00: attached PHY driver (mii_bus:phy_addr=r8169-4-4100:00, irq=MAC) [ 6.518776] r8169 0004:41:00.0 eth0: Link is Down [ 9.721015] r8169 0004:41:00.0 eth0: Link is Up - 2.5Gbps/Full - flow control off [ 9717.405068] r8169 0004:41:00.0 eth0: NETDEV WATCHDOG: CPU: 3: transmit queue 0 timed out 5227 ms [ 9717.405345] r8169 0004:41:00.0 eth0: ASPM disabled on Tx timeout [ 9717.418437] r8169 0004:41:00.0 eth0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100). [ 9941.759110] r8169 0004:41:00.0 eth0: Link is Down [ 9945.329364] r8169 0004:41:00.0 eth0: Link is Up - 2.5Gbps/Full - flow control off I have a frigate container running on this sbc. A second Rock 5b (same os version) with 10 docker images but very low traffic run smoth on the same switch with 2.5Gbps. Could someone check which driver Radxa OS uses?
  4. Hi rock5b user 🙂 My sbc hangs after 8-14 hours on the network. no ping from inside or outside works # ip link - show eth0 up after the commands ip link set eth0 down ip link set eth0 up - the network worgs again, https://paste.armbian.com/tiqabekoje - any hints for this issue?
