Silv3r_18
  1. Here is the resulting log: U-Boot SPL 2025.01-armbian-2025.01-S6d41-P7f87-H8869-V2e4e-Bb703-R448a-dirty (Ma r 07 2025 - 05:18:17 +0000) DRAM:testing 32-bit width, rank = 2 read calibration failed! testing 32-bit width, rank = 1 DRAM:Store cfg DRAM:1st writing pattern DRAM:detecting column address bits detected 11 columns DRAM:restore cfg DRAM:reconfigure for all active rows DRAM:store cfg DRAM:2nd writing pattern DRAM:detecting row address bits detected 16 rows DRAM:restoring cfg DRAM:end of auto detect dram size MBUS port 0 cfg0 0100000d cfg1 00640080 MBUS port 1 cfg0 06000009 cfg1 01000578 MBUS port 2 cfg0 0200000d cfg1 00600100 MBUS port 3 cfg0 01000009 cfg1 00500064 MBUS port 4 cfg0 20000209 cfg1 1388157c MBUS port 5 cfg0 00640209 cfg1 00200040 MBUS port 6 cfg0 00640209 cfg1 00200040 MBUS port 8 cfg0 01000009 cfg1 00400080 MBUS port 11 cfg0 01000009 cfg1 00640080 MBUS port 14 cfg0 04000009 cfg1 00400100 MBUS port 16 cfg0 2000060d cfg1 09600af0 MBUS port 21 cfg0 0800060d cfg1 02000300 MBUS port 22 cfg0 01000009 cfg1 00640080 MBUS port 25 cfg0 0064000f cfg1 00200040 MBUS port 26 cfg0 20000209 cfg1 1388157c MBUS port 37 cfg0 01000009 cfg1 00400080 MBUS port 38 cfg0 00640209 cfg1 00200040 MBUS port 39 cfg0 20000209 cfg1 1388157c MBUS port 40 cfg0 00640209 cfg1 00200040 4096 MiB Trying to boot from MMC1 NOTICE: BL31: v2.10.14(debug):armbian NOTICE: BL31: Built : 05:17:11, Mar 7 2025 NOTICE: BL31: Detected Allwinner H616 SoC (1823) NOTICE: BL31: Found U-Boot DTB at 0x4a0b1888, model: Shenzhen Amediatech Techno logy Co., Ltd X96Q TV Box INFO: ARM GICv2 driver initialized INFO: Configuring SPC Controller INFO: PMIC: Probing AXP305 on RSB WARNING: PMIC: No regulators DT node, skipping setup INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for erratum 855873 was applied INFO: BL31: cortex_a53: CPU workaround for erratum 1530924 was applied INFO: PSCI: Suspend is unavailable INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 INFO: Changed devicetree. ns16550_serial serial@5000000: pinctrl_select_state_full: uclass_get_device_by_p handle_id: err=-19 U-Boot 2025.01-armbian-2025.01-S6d41-P7f87-H8869-V2e4e-Bb703-R448a-dirty (Mar 07 2025 - 05:18:17 +0000) Allwinner Technology CPU: Allwinner H616 (SUN50I) Model: Shenzhen Amediatech Technology Co., Ltd X96Q TV Box DRAM: 4 GiB Core: 56 devices, 18 uclasses, devicetree: separate WDT: Not starting watchdog@30090a0 MMC: mmc@4020000: 0, mmc@4021000: 3, mmc@4022000: 1 Loading Environment from FAT... Unable to use mmc 0:1... In: serial@5000000 Out: serial@5000000 Err: serial@5000000 No USB device found Net: Could not get PHY for ethernet@5030000: addr 16 No ethernet found. starting USB... No USB controllers found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 4641 bytes read in 8 ms (566.4 KiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 196 bytes read in 7 ms (27.3 KiB/s) Load fdt: /boot/dtb/allwinner/sun50i-h313-x96-q.dtb 29607 bytes read in 16 ms (1.8 MiB/s) Working FDT set to 4fa00000 Failed to load '/boot/dtb/allwinner/overlay/sun50i-h616-fixup.scr' 15459855 bytes read in 652 ms (22.6 MiB/s) 42621440 bytes read in 1784 ms (22.8 MiB/s) Moving Image from 0x40080000 to 0x40200000, end=0x42b50000 ## Loading init Ramdisk from Legacy Image at 4ff00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 15459791 Bytes = 14.7 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Working FDT set to 4fa00000 Loading Ramdisk to 49141000, end 49fff5cf ... OK Loading Device Tree to 00000000490d1000, end 0000000049140fff ... OK Working FDT set to 490d1000 Starting kernel ...
  2. It's AXP806 ... And pictures of my board, here: https://ibb.co/608J8Hq4 https://ibb.co/8DQrNF3y
  3. Hello, I allow myself to repost. Is it possible to install ARMBIAN on my box or not? Thanks in advance
  4. Hello everyone, after a lot of fruitless research, I am turning to you for a helping hand. I have a T95 4Gb/32Gb box, on the motherboard it says H616-T95MAX-V4.0-20191217. And the CPU model is sun50iw9. Is it possible to remove ANDROID and install ARMBIAN? Thank you in advance for your answers
