dgw
  1. sudo apt remove brltty I no longer experience the issue. Research suggests a problem with Braille devices using device IDs associated with their USB to serial hardware. It looks like an attempt was made to address the problem with udev rules in the past. Regression bug? Thanks much for the suggestion!
  2. The power supply has been upgraded to an Argon 40 rated at 5.25V and 3.5A, but still connected by the standard micro USB. I had a A3 SD Card and downgraded to A1. Installation is identical to that originally reported. These USB to serial devices are recognized and have persistence in /dev/tty* and /dev/serial: Bus 001 Device 010: ID 1a86:5523 QinHeng Electronics CH341 in serial mode, usb to serial port converter Bus 001 Device 007: ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Port / Mobile Phone Data Cable These devices are recognized and transiently build devices in /dev/tty* which persist for seconds, then disappear: Bus 001 Device 011: ID 1a86:7523 QinHeng Electronics CH340 serial converter Bus 001 Device 014: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC Bus 001 Device 013: ID 10c4:ea60 Silicon Labs CP210x UART Bridge Other than the built in Tinker Board USB devices, I use a Logitech receiver: Bus 001 Device 003: ID 046d:c52b Logitech, Inc. Unifying Receiver The devices above were plugged in and subsequently removed one at at a time with Logitech Unifying Receiver also in place. I'm happy to test removing the Braille device. Do I remove a kernel module, or is there an app that can be used to manage assistive technologies?
  3. I installed Armbian 23.11 Bookworm Kernel 6.1, Size: 482Mb, Release date: Nov 30, 2023. After installation, a CH340 based board was connected to my original Tinkerboard and recognized. Subsequently, I used armbian-config to provide the default desktop (Cinnamon flavor). Thereafter, the CH340 board is incompletely recognized. Specifically, no device is presented as /dev/ttyUSB?. The device appears in the list from lsusb, the kernel module ch341.ko loads, but no device in /dev. The forum search shows a previous instance of a similar issue many years back. I attempted to build the driver from wch.cn, but the kernel sources pulled from armbian-config were for the Linux tinkerboard 6.1.63-current-rockchip kernel and,so, a mismatch for the running kernel. uname -a Linux tinkerboard 6.1.68-current-rockchip #1 SMP PREEMPT Wed Dec 13 17:39:30 UTC 2023 armv7l GNU/Linux lsusb |grep -i ch34 Bus 001 Device 006: ID 1a86:7523 QinHeng Electronics CH340 serial converter lsmod | grep -i ch34 ch341 20480 0 usbserial 28672 1 ch341
