- RK3399 PCIe enumeration
I have a custom PCIe x4 lane card that I'm trying to integrate with a RockPro64 SBC. This custom card has been tested with many users on different platforms including a linux x86 system. When I try this card in a RK3399 system, I get a strange result when I view the assigned address space with the lspci command. It appears the address assigned is the exact value of the BAR address size for each BAR. If I change the BAR size the assigned address changes to that value. Below is a dmesg dump along with a lspci output for my device. Device is [ad00:001e]. Any guidance? dmesg: [ 2.395091] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges: [ 2.395148] rockchip-pcie f8000000.pcie: MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000 [ 2.395175] rockchip-pcie f8000000.pcie: IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000 [ 2.396226] rockchip-pcie f8000000.pcie: supply vpcie1v8 not found, using dummy regulator [ 2.396376] rockchip-pcie f8000000.pcie: supply vpcie0v9 not found, using dummy regulator [ 2.571466] rockchip-pcie f8000000.pcie: wait 1000 ms (from device tree) before bus scan [ 3.582289] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00 [ 3.582303] pci_bus 0000:00: root bus resource [bus 00-1f] [ 3.582316] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff] [ 3.582330] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff]) [ 3.582387] pci 0000:00:00.0: [1d87:0100] type 01 class 0x060400 [ 3.582547] pci 0000:00:00.0: supports D1 [ 3.582557] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [ 3.588072] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 3.588301] pci 0000:01:00.0: [ad00:001e] type 00 class 0x000000 [ 3.588382] pci 0000:01:00.0: reg 0x10: [mem 0xfffffe00-0xffffffff] [ 3.588455] pci 0000:01:00.0: reg 0x18: [mem 0xffe00000-0xffffffff] [ 3.588606] pci 0000:01:00.0: Upstream bridge's Max Payload Size set to 128 (was 256, max 256) [ 3.588632] pci 0000:01:00.0: Max Payload Size set to 128 (was 128, max 128) [ 3.589238] pci_bus 0000:01: busn_res: [bus 01-1f] end is updated to 01 [ 3.589272] pci 0000:00:00.0: BAR 14: assigned [mem 0xfa000000-0xfa2fffff] [ 3.589287] pci 0000:00:00.0: PCI bridge to [bus 01] [ 3.589302] pci 0000:00:00.0: bridge window [mem 0xfa000000-0xfa2fffff] [ 3.589497] pcieport 0000:00:00.0: enabling device (0000 -> 0002) [ 3.589853] pcieport 0000:00:00.0: PME: Signaling with IRQ 37 [ 3.590302] pcieport 0000:00:00.0: AER: enabled with IRQ 37 lspci -v: 00:00.0 PCI bridge: Rockchip Electronics Co., Ltd RK3399 PCI Express Root Port (prog-if 00 [Normal decode]) Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+ Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx- Latency: 0 Interrupt: pin A routed to IRQ 37 Bus: primary=00, secondary=01, subordinate=01, sec-latency=0 Memory behind bridge: fa000000-fa2fffff [size=3M] [32-bit] Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR- BridgeCtl: Parity- SERR+ NoISA- VGA- VGA16- MAbort- >Reset- FastB2B- PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn- Capabilities: <access denied> Kernel driver in use: pcieport 01:00.0 Non-VGA unclassified device: Alta Data Technologies LLC Device 001e Subsystem: Alta Data Technologies LLC Device 001e Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx- Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx- Interrupt: pin A routed to IRQ 0 Region 0: Memory at fffffe00 (32-bit, non-prefetchable) [disabled] [size=512] Region 2: Memory at ffe00000 (32-bit, non-prefetchable) [disabled] [size=2M] Capabilities: <access denied>
JHadd
