Pszemek
  1. I managed to fix the device I downloaded u-boot.bin from that thread Then I ran it from uart using 2 commands: fatload mmc 0 0x01000000 u-boot.bin go 0x01000000 With this u-boot version, the system booted up fine. After that, I tried to overwrite the corrupted u-boot using dd command. I failed but actually, that broke uboot on emmc which allowed the device to enter usb download mode. From that, I was able to write original ROM using amlogic burning tool
  2. Nothing shows up in device manager. Even with incorrect version of burning tool when the box goes to correct mode there is a device visible in device manager. Yes, only usb cable, no external power.
  3. I was hoping there is a way to restore uboot using UART commands
  4. I did try both usb port and different Burning tool versions but it seems that the computer doesn't recognize any new devices so at this point the tools itself doesn't matter if there is no device connected.
  5. But even without UART connected nothing happens
  6. I still have the UART connected to monitor what is going on. The usb cable is 100% working as I tried to run ums 0 mmc 0 command and computer detects the SD card.
  7. Are you sure? My box goes straight to u-boot, computer doesn't recognize any new device. Looks like it ignores the reset button completely Looks like original uboot has commands like "update" and "sdc_burn" which would start update process,
  8. I have the original firmware for Amlogic USB Burning tool, but the box doesn't want to go to the correct mode now as the U-boot has been overwritten
  9. Even official docs are saying that there is armbian-install script https://docs.armbian.com/ I did use the latest official build, I did try to flash the SD card again and there is no change. I think modified armbian u-boot is broken.
  10. Okay, but the box is now dead, I need to somehow either enable SD boot again or revert the firmware. Is there a way to do it via UART? As that's the only thing that still works on the box
  11. It's Armbian_23.02.2_Aml-s9xx-box_bullseye_current_6.1.11 I run standard sd installation. And then I just run armdroid-install and selected emmc boot
  12. Hi, After running armbian-install on S905x device it stopped booting. USB Burning Tool doesn't recognize the device, nothing. After connecting to UART it looks like install script has overwritten the original u-boot. That's the boot log from UART connection without sd card: GXL:BL1:9ac50e:a1974b;FEAT:ADFC318C;POC:3;RCY:0;EMMC:0;READ:0;0.0;CHK:0; TE: 104174 BL2 Built : 11:58:42, May 27 2017. gxl gc3c9a84 - xiaobo.gu@droid05 set vcck to 1120 mv set vddee to 1000 mv Board ID = 1 CPU clk: 1200MHz DQS-corr enabled DDR scramble enabled DDR3 chl: Rank0+1 @ 912MHz - PASS Rank0: 1024MB(auto)-2T-13 Rank1: 1024MB(auto)-2T-13 DataBus test pass! AddrBus test pass! -s Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x00004000 New fip structure! Load bl30 from eMMC, src: 0x00010200, des: 0x01100000, size: 0x0000d600 Load bl31 from eMMC, src: 0x00020200, des: 0x05100000, size: 0x00018400 Load bl33 from eMMC, src: 0x0003c200, des: 0x01000000, size: 0x000af000 NOTICE: BL3-1: v1.0(release):3348978 NOTICE: BL3-1: Built : 15:44:01, May 12 2017 [BL31]: GXL CPU setup! mpu_config_enable:ok [Image: gxl_v1.1.3221-2cfba69 2017-05-27 16:03:58 qiufang.dai@droid07] OPS=0x82 8f bb f0 da ba 22 d2 cf 1 b0 31 f4 [0.359461 Inits done] secure task start! high task start! low task start! ERROR: Error initializing runtime service opteed_fast <debug_uart> U-Boot 2022.07-armbian (Nov 25 2023 - 12:50:42 +0000) libretech-cc Model: Libre Computer AML-S905X-CC SoC: Amlogic Meson GXL (S905X) Revision 21:b (82:2) DRAM: 2 GiB Core: 169 devices, 27 uclasses, devicetree: separate MMC: mmc@72000: 0, mmc@74000: 1 Loading Environment from nowhere... OK In: serial Out: serial Err: serial [BL31]: tee size: 0 [BL31]: tee size: 0 Net: eth0: ethernet@c9410000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1(part 0) is current device Scanning mmc 1:1... Found /boot/extlinux/extlinux.conf Retrieving file: /boot/extlinux/extlinux.conf 1: Armbian Retrieving file: /uInitrd ** File not found /uInitrd ** Skipping Armbian for failure retrieving initrd SCRIPT FAILED: continuing... Found U-Boot script /boot/boot.scr 8147 bytes read in 1 ms (7.8 MiB/s) ## Executing script at 08000000 U-boot default fdtfile: amlogic/meson-gxl-s905x-libretech-cc.dtb Current variant: Current fdtfile after armbianEnv: amlogic/meson-gxl-s905x-libretech-cc.dtb Mainline bootargs: root=/dev/mmcblk1p1 rootwait rootfstype=ext4 splash=verbose c onsole=ttyAML0,115200 console=tty1 consoleblank=0 coherent_pool=2M loglevel=1 ub ootpart=d27dbd06-01 libata.force=noncq usb-storage.quirks= cgroup_enable=memo ry swapaccount=1 22783841 bytes read in 500 ms (43.5 MiB/s) 27433472 bytes read in 601 ms (43.5 MiB/s) 40228 bytes read in 4 ms (9.6 MiB/s) Failed to load '/boot/dtb/amlogic/overlay/-fixup.scr' ## Loading init Ramdisk from Legacy Image at 13000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 22783777 Bytes = 21.7 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 04080000 Booting using the fdt blob at 0x4080000 Loading Ramdisk to 7a982000, end 7bf3c721 ... OK Loading Device Tree to 000000007a90f000, end 000000007a981fff ... OK "Synchronous Abort" handler, esr 0x96000004 elr: 00000000010656ec lr : 0000000001055038 (reloc) elr: 000000007dfb46ec lr : 000000007dfa4038 x0 : e14b4287a666c25d x1 : 000000007dfbc290 x2 : 0000000000000010 x3 : 000000007bf54e10 x4 : 0000000000000000 x5 : e14b4287a666c25d x6 : 0000000001000000 x7 : 0000000000000000 x8 : 0000000000000007 x9 : 0000000000000000 x10: 0000000000000178 x11: 000000007bf40eec x12: 00000000000000a4 x13: 000000007bf40ea8 x14: 000000007a90f000 x15: 0000000000000020 x16: 000000007df5946c x17: 0000000000000000 x18: 000000007bf4cdb0 x19: 000000007af41040 x20: 000000007df4fb18 x21: 000000007dfbc290 x22: 0000000000001000 x23: 000000007bf54d60 x24: 000000007dfdacb8 x25: 0000000001000000 x26: 0000000000000000 x27: 0000000001000000 x28: 0000000000001000 x29: 000000007bf40ea0 Code: eb04005f 54000061 52800000 14000006 (386468a3) Resetting CPU ... resetting ... bl31 reboot reason: 0xd bl31 reboot reason: 0x0 system cmd 1. And with sd card GXL:BL1:9ac50e:a1974b;FEAT:ADFC318C;POC:3;RCY:0;EMMC:0;READ:0;0.0;CHK:0; TE: 103545 BL2 Built : 11:58:42, May 27 2017. gxl gc3c9a84 - xiaobo.gu@droid05 set vcck to 1120 mv set vddee to 1000 mv Board ID = 1 CPU clk: 1200MHz DQS-corr enabled DDR scramble enabled DDR3 chl: Rank0+1 @ 912MHz - PASS Rank0: 1024MB(auto)-2T-13 Rank1: 1024MB(auto)-2T-13 DataBus test pass! AddrBus test pass! -s Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x00004000 New fip structure! Load bl30 from eMMC, src: 0x00010200, des: 0x01100000, size: 0x0000d600 Load bl31 from eMMC, src: 0x00020200, des: 0x05100000, size: 0x00018400 Load bl33 from eMMC, src: 0x0003c200, des: 0x01000000, size: 0x000af000 NOTICE: BL3-1: v1.0(release):3348978 NOTICE: BL3-1: Built : 15:44:01, May 12 2017 [BL31]: GXL CPU setup! mpu_config_enable:ok [Image: gxl_v1.1.3221-2cfba69 2017-05-27 16:03:58 qiufang.dai@droid07] OPS=0x82 8f bb f0 da ba 22 d2 cf 1 b0 31 f4 [0.358822 Inits done] secure task start! high task start! low task start! ERROR: Error initializing runtime service opteed_fast <debug_uart> U-Boot 2022.07-armbian (Nov 25 2023 - 12:50:42 +0000) libretech-cc Model: Libre Computer AML-S905X-CC SoC: Amlogic Meson GXL (S905X) Revision 21:b (82:2) DRAM: 2 GiB Core: 169 devices, 27 uclasses, devicetree: separate MMC: mmc@72000: 0, mmc@74000: 1 Loading Environment from nowhere... OK In: serial Out: serial Err: serial [BL31]: tee size: 0 [BL31]: tee size: 0 Net: eth0: ethernet@c9410000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found /extlinux/extlinux.conf Retrieving file: /extlinux/extlinux.conf 1: Armbian Retrieving file: /uInitrd Retrieving file: /Image append: root=UUID=a6cf29bd-49ae-4d3b-bf22-800408ae1fba rootflags=data=writeback console=ttyAML0,115200n8 console=tty0 rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 splash plymouth.ignore-serial-consoles Retrieving file: /dtb/amlogic/meson-gxl-s905x-p212.dtb Moving Image from 0x8080000 to 0x8200000, end=9cd0000 ## Loading init Ramdisk from Legacy Image at 13000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 22783777 Bytes = 21.7 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 08008000 Booting using the fdt blob at 0x8008000 Loading Ramdisk to 7a982000, end 7bf3c721 ... OK Loading Device Tree to 000000007a975000, end 000000007a98169c ... OK "Synchronous Abort" handler, esr 0x96000004 elr: 00000000010656ec lr : 0000000001055038 (reloc) elr: 000000007dfb46ec lr : 000000007dfa4038 x0 : e14b4287a666c25d x1 : 000000007dfbc290 x2 : 0000000000000010 x3 : 000000007bf54e10 x4 : 0000000000000000 x5 : e14b4287a666c25d x6 : 0000000001000000 x7 : 0000000000000000 x8 : 0000000000000007 x9 : 0000000000000000 x10: 0000000000000188 x11: 000000007bf409ec x12: 00000000000000b4 x13: 000000007bf409a8 x14: 000000007a975000 x15: 0000000000000020 x16: 000000007df7a768 x17: 0000000000000000 x18: 000000007bf4cdb0 x19: 000000007af41040 x20: 000000007df4fb18 x21: 000000007dfbc290 x22: 0000000000001000 x23: 000000007bf54d60 x24: 000000007dfdacb8 x25: 0000000001000000 x26: 0000000000000000 x27: 0000000001000000 x28: 0000000000001000 x29: 000000007bf409a0 Code: eb04005f 54000061 52800000 14000006 (386468a3) Resetting CPU ... resetting ... bl31 reboot reason: 0xd bl31 reboot reason: 0x0 system cmd 1. Is there any way to restore original firmware?
