Christian Willemsen
  1. I did the dev/mmcblk1 and yes it worked.
  2. im not using a microsd. im using the eMMC. /dev/mmcblk1p1 if im right?
  3. What device ${entire-device-to-be-used}. Do i put here /dev/zram1: LABEL="log2ram" UUID="f669e3f4-c37a-47e0-9427-9839ee24afeb" BLOCK_SIZE="4096" TYPE="ext4" /dev/mmcblk1p1: LABEL="armbi_root" UUID="de04b6b8-a4ac-493b-bee1-92d2eaff5ff0" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="586ce220-01" /dev/zram0: UUID="9a68dd65-2939-47d0-a8a7-cb19f1afe9d8" TYPE="swap" /dev/sda is externe ubs its pluged out otherwise no boot
  4. I went back to bullseye.
  5. Hi I was trying out Armbian_24.2.1_Odroidn2_bookworm_current_6.6.16_cinnamon_desktop.img.xz and its not booting when you have a usb hdd connected. It works pefectly fine on bullseye image. Also tryed some other hdd on usb Board variant: n2-plus Net: dunac_neson8b ethernet@ff3f0000: Can't get reset: -2 ethe: ethernet@ff310000 Hit any key to stop autoboot: 0 starting USB... Bus usb@ff500000: Register 3000140 MbrPorts 3 Starting the controller USB XHCI 1.10 scanning bus usbeff500000 for devices... unable to get device descriptor (error-1) WARN halted endpoint, queueing URB anyway. Unexpected XHCI event TRB, skipping... (f0f719c0 00000000 13000000 04008400) the https://paste.armbian.com/peromuzibi is the bullseye one.
