AlexK
  1. The problem was with -m flag, i forget to allocate enough memory for VM to start, so working CMD: qemu-system-aarch64 \ -machine virt -cpu cortex-a57 -m 512 \ -netdev user,id=net0 -device e1000,netdev=net0 \ -serial stdio \ -bios Armbian-unofficial_24.5.0-trunk_Qemu-uboot-arm64_bookworm_current_6.6.29_minimal.u-boot.bin \ -drive if=none,file=Armbian-unofficial_24.5.0-trunk_Qemu-uboot-arm64_bookworm_current_6.6.29_minimal.img.qcow2,id=mydisk \ -device ich9-ahci,id=ahci \ -device ide-hd,drive=mydisk,bus=ahci.0
  2. Hi! Currently try to figure out how to run my freshly builded Armbian using QEMU arm64. According to this tutorial: https://docs.armbian.com/Developer-Guide_Build-Preparation/ I prepare clean Jammy VM. Build using this CMD: ./compile.sh BOARD=qemu-uboot-arm64 BRANCH=current RELEASE=bookworm Build process was going smoothly i pick up two files from output folder: 1) Armbian-unofficial_24.5.0-trunk_Qemu-uboot-arm64_bookworm_current_6.6.29_minimal.img.qcow2 2) Armbian-unofficial_24.5.0-trunk_Qemu-uboot-arm64_bookworm_current_6.6.29_minimal.u-boot.bin Currently boot up process stucked, i can run U-boot and mount qcow2 image using this CMD: qemu-system-aarch64 \ -machine virt -cpu cortex-a57 \ -netdev user,id=net0 -device e1000,netdev=net0 \ -serial stdio \ -bios Armbian-unofficial_24.5.0-trunk_Qemu-uboot-arm64_bookworm_current_6.6.29_minimal.u-boot.bin \ -drive if=none,file=Armbian-unofficial_24.5.0-trunk_Qemu-uboot-arm64_bookworm_current_6.6.29_minimal.img.qcow2,id=mydisk \ -device ich9-ahci,id=ahci \ -device ide-hd,drive=mydisk,bus=ahci.0 U-boot see the drive with rootfs, but during boot process i had this error: Failed to load '/boot/uInitrd' Wrong Ramdisk Image Format Ramdisk image is corrupt or invalid Boot failed (err=-14) Full boot process log: U-Boot 2023.10-armbian (Mar 14 2024 - 01:18:23 +0000) DRAM: 128 MiB Core: 51 devices, 14 uclasses, devicetree: board Flash: 64 MiB Loading Environment from Flash... *** Warning - bad CRC, using default environment In: pl011@9000000 Out: pl011@9000000 Err: pl011@9000000 Net: e1000: 52:54:00:12:34:56 eth0: e1000#0 Hit any key to stop autoboot: 0 Scanning for bootflows in all bootdevs Seq Method State Uclass Part Name Filename --- ----------- ------ -------- ---- ------------------------ ---------------- Scanning global bootmeth 'efi_mgr': Scanning bootdev 'fw-cfg@9020000.bootdev': fatal: no kernel available No working controllers found scanning bus for devices... Target spinup took 0 ms. SATA link 1 timeout. SATA link 2 timeout. SATA link 3 timeout. SATA link 4 timeout. SATA link 5 timeout. AHCI 0001.0000 32 slots 6 ports 1.5 Gbps 0x3f impl SATA mode flags: 64bit ncq only Device 0: (0:0) Vendor: ATA Prod.: QEMU HARDDISK Rev: 2.5+ Type: Hard Disk Capacity: 54564.0 MB = 53.2 GB (111747072 x 512) Scanning bootdev 'ahci_scsi.id0lun0.bootdev': 0 script ready scsi 1 ahci_scsi.id0lun0.bootdev /boot/boot.scr ** Booting bootflow 'ahci_scsi.id0lun0.bootdev.part_1' with script scanning bus for devices... Device 0: (0:0) Vendor: ATA Prod.: QEMU HARDDISK Rev: 2.5+ Type: Hard Disk Capacity: 54564.0 MB = 53.2 GB (111747072 x 512) Device 0: (0:0) Vendor: ATA Prod.: QEMU HARDDISK Rev: 2.5+ Type: Hard Disk Capacity: 54564.0 MB = 53.2 GB (111747072 x 512) <DIR> 4096 . <DIR> 4096 .. <SYM> 28 Image <SYM> 24 dtb <DIR> 4096 dtb-6.6.29-current-arm64 38518 boot.bmp 0 .next <SYM> 28 uInitrd 906 boot.cmd 6040046 System.map-6.6.29-current-arm64 978 boot.scr 49178863 uInitrd-6.6.29-current-arm64 318778 config-6.6.29-current-arm64 38134272 vmlinuz-6.6.29-current-arm64 49178799 initrd.img-6.6.29-current-arm64 KERNEL LOAD ADDRESS: kernel_addr_r : 0x40400000 INITRD LOAD ADDRESS: ramdisk_addr_r: 0x44000000 FDT LOAD ADDRESS : fdt_addr : 0x40000000 38134272 bytes read in 853 ms (42.6 MiB/s) ** Reading file would overwrite reserved memory ** Failed to load '/boot/uInitrd' Wrong Ramdisk Image Format Ramdisk image is corrupt or invalid Boot failed (err=-14) --- ----------- ------ -------- ---- ------------------------ ---------------- (1 bootflow, 1 valid) Any ideas what i'm doing wrong?
