Armbian 24.2 and Orange Pi One
Update : I haven't downgrade to bullseye, but seeing there's a new update for the bookworm, I try it. it seems this latest update is making it stable: linux-dtb-current-sunxi:armhf (24.2.1, 24.5.1), linux-u-boot-orangepione-current:armhf (24.2.1, 24.5.1), linux-image-current-sunxi:armhf (24.2.1, 24.5.1) been running for 48 hours without error. I even tried to install the newest armbian-firmware yesterday.
- Armbian 24.2 and Orange Pi One
thanks for replying @Stephen Graf. I rather want to try using the older armbian-firmware package and keep the newer kernel, since the problem only shows up after I upgrade the firmware. currently it still hangs after 15-20 hours. can I extract the firmware from and image? the post from @ER Samson mention vnstat. I do not use it, and the package is not installed. i did use htop to check what's using the cpu. but nothing extensive. I haven't check the governor prior the deletion of firmware. currently is "on-demand"
I have remove the armbian-firmware #apt remove armbian-firmware just need to restart it once today. I still trying to find the deb package for older version of armbian-firmware couldn't find it on https://mirror.yandex.ru/mirrors/armbian/archive/orangepione/archive/ for info, I run the board for Pi-Hole using the cloudflared. The second service is a smbd server for low throughput usage in LAN the symtomps after armbian-firmware update to 24.2.1 is a hot cpu, so it might be the system cannot cope with the temperature and just hangs (I do not put any cooling / heatsink for 2 years and its working fine because of the low usages) any suggestion to a armbian-firmware.deb file that i can dpkg is appreciated. thanks
