DrEaD
  1. You need the "normal" non 5-1 version: https://github.com/sicXnull/armbian-build/releases/download/v24.8.0-trunk.425/Armbian-unofficial_24.11.0-trunk_X96q_bookworm_current_6.6.44_mate_desktop.img.xz
  2. Up! I've forgot device in drawer until now, when my klipper host minipc died.. Got Klipper with CAN and Klipperscreen working great to run my Voron Trident. Awesome work guys, thanks again!
  3. Thank you, this image worked!
  4. Hi! Firstly thanks put work in this box! I've a X96Q Brazilian clone named PROSB-3000, it's almost same from comment #200190 It boots D:\MiniArch-20240715-6.10.10-board-h313.x96_q_lpddr3-SD-Image.img... Compiled all links from this topic, always write only "root" partition, without boot partition(in all tests only work with boot and root partitions). In one compiling trying gets "Check MD5 sum of installed packages failed" message, like #203154 comment. So I've tried #202501 method, burned MiniArch, changed files in boot, removed root, restore armbi_root and got screen, but... Glitched splash screen, waited some minutes, nothing happen... Any advice? Images attached.
  5. You need install lightdm manually, welcome to Arch world, everything need medium/advanced knowledge in linux... 😅
  6. Connect usb cable into an Android smartphone and select "USB Thetering" in smartphone... But in new release(v20240522) Ethernet was showing working(not tested), and wifi too(tested). I've give up because can't add CAN network module(don't know how), this is necessary to run my project (3d printer with klipper and can toolhead).
  7. I get all working with USB Tethering, after install miniarch WiFi works...
  8. Hi, sorry my english Did you got a working system? I can boot MiniArch-20231112-6.7.4-board-h313.x96_q_lpddr3-SD-Image but ethernet won't work and MiniArch-20231112-6.7.4-board-h616.tanix_tx6s_axp313-SD-Image won't boot.. I'm in hope to get Klipper work on this tvbox
