`/etc/armbian-image-release` is not updated...
certainly: https://paste.armbian.com/wujesuqaro also, i would have guessed that `lsb_release -a` would show me the userland. 'bash' seems to come from bookworm as well: # apt show bash Package: bash Version: 5.2.15-2+b7 Priority: required Essential: yes Section: shells Source: bash (5.2.15-2) Maintainer: Matthias Klose <doko@debian.org> Installed-Size: 6,904 kB Pre-Depends: libc6 (>= 2.36), libtinfo6 (>= 6) Depends: base-files (>= 2.1.12), debianutils (>= 5.6-0.1) Recommends: bash-completion (>= 20060301-0) Suggests: bash-doc Conflicts: bash-completion (<< 20060301-0) Replaces: bash-completion (<< 20060301-0), bash-doc (<= 2.05-1) Homepage: http://tiswww.case.edu/php/chet/bash/bashtop.html Tag: admin::TODO, devel::TODO, devel::interpreter, implemented-in::c, interface::shell, interface::text-mode, role::program, scope::application, suite::gnu, uitoolkit::ncurses Download-Size: 1,422 kB APT-Manual-Installed: yes APT-Sources: http://deb.debian.org/debian bookworm/main armhf Packages Description: GNU Bourne Again SHell and my apt sources only list "bookworm": # find /etc/apt/sources.list* -name "*.list" -exec sed -e 's/#.*//' -e 's/ *//' -e '/^$/d' {} + deb http://apt.armbian.com bookworm main bookworm-utils bookworm-desktop deb http://deb.debian.org/debian bookworm main contrib non-free non-free-firmware deb http://security.debian.org/debian-security bookworm-security main contrib non-free non-free-firmware deb http://deb.debian.org/debian bookworm-updates main contrib non-free non-free-firmware
i'm also a bit mystified, what the motd says *buster* and at the same time correctly reports the armbian and kernel version
Back in the days, i've installed armbian on my "Odroid XU4". those where the days when "buster" was still a thing. In the meantime, I've updated the system (change apt repos; run 'apt full-upgrade'), and I'm now running "bookworm": # lsb_release -a No LSB modules are available. Distributor ID: Debian Description: Armbian 24.5.5 bookworm Release: 12 Codename: bookworm unfortunately, /etc/armbian-image-release still thinks i'm running buster (and armbian-20.02.7): # PLEASE DO NOT EDIT THIS FILE BOARD=odroidxu4 BOARD_NAME="Odroid XU4" BOARDFAMILY=odroidxu4 BUILD_REPOSITORY_URL=https://github.com/armbian/rkbin BUILD_REPOSITORY_COMMIT=3e533c9 DISTRIBUTION_CODENAME=buster DISTRIBUTION_STATUS=supported VERSION=20.02.7 LINUXFAMILY=odroidxu4 BRANCH=legacy ARCH=arm IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm KERNEL_IMAGE_TYPE=Image IMAGE_UUID=164e4ab3-9157-48a3-bbe1-6525c2b9a086 i wouldn't mind very much, if the login-screen wouldn't scream everytime i log in: Welcome to Armbian 24.5.5 *Buster* with Linux 6.6.31-current-odroidxu4 No end-user support: unsupported (buster) userspace! I'm a bit mystified, why it wrongly says *Buster*, and at the same time reports the correct kernel and armbian version. Anyhow: How can I fix this? note: there's already a similar topic here (from 2 years ago), but since it is so old, i was asked to start a new thread:
umlaeute
